King.Oracle 0.3.3
Joel Carranza jec at gatekeeper.com
Wed Oct 25 14:10:37 EDT 2006
Andy,
I agree with you completely. The approach is really quite odd.  Autodesk
told  me one that one workaround is to delete the style sections of Layer
Definition XML which don't correspond to the geometry you want to display.
Kindof silly, but could be easily added to web studio.
Being able to simply specify a key field in studio would be ideal, although
I don't know if the architecture supports it. I wonder what happens when a
key field is specified incorrectly, and you dump out multiple objects with
the same key to the AJAX or DWF viewer. I hope this error would be tolerated
gracefully.
Joel
Andy Morsell wrote:
> I agree that being able to specify geometry type is important.  The
> Autodesk
> Oracle provider works the same way.  Instead of relying on database stored
> metadata, it seems that this could be defined at the layer definition
> level
> in the MGOS repository.  When publishing the layer through Studio or
> whatever means, an option to simply say "this layer is polygonal only" and
> then have the legend reflect this would be good.   Same goes for the key
> field - I would like to be able to specify this on an MGOS layer by layer
> basis.
> Andy
> -----Original Message-----
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Wednesday, October 25, 2006 10:42 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: King.Oracle 0.3.3
> Its seems to me that eventually you will have to rely on user supplied
> metadata to solve this problem. For each table or view, a user would be
> able
> to specify a key column and also maybe what type of geometry (point,line,
> poly, mixed, etc...) is in the table. Specifying a type of geometry would
> be
> nice, so that layers created from feature classes are correctly displayed
> in
> legend. Eventually, you will probably need to allow for other types of
> metadata as well. This info could be stored in a table within Oracle or in
> a
> config file internal to the provider. I'm not sure that it matters.
> Joel
> haris kurtagic wrote:
>> Hi Joel,
>> Regarding selecting, I tested it again and I am able to select layers
>> wich comes from tables with primary keys.
>> Right now primary key is only way to tell provider to use that column
>> as identity.
>> Any sugestions are welcome.
>> I should do something for views also.
>> Note:
>>  It seems there is an issue in viewer regarding selecting:
>> If you have a large scale layer and then zoom in much smaller and then
>> you click on feature, mg will send wrong coordinates for selecting on
>> that click hence tooltip will work, it send different coordinates to
>> provider for tooltip and click on.
>> If you take that same layer and put in the map, and give map a smaller
>> extents, click on and tooltip works.
>> Haris
>> Sent: Tuesday, October 24, 2006 8:05 PM
>> Subject: Re: [mapguide-users] King.Oracle 0.3.3
>> Fantastic! Talk about agile development. My views showed up and are
>> now displaying. I'm having some performance problems, but those could
>> easily be my fault. Too much data on too small a machine. Still, I
>> have a gig of ram on my machine, and while I was browsing a map, I
>> completely filled it up. I don't think that should happen?
>> Weirdest thing I have found is that none of my map features in DWF or
>> AJAX are selectable, even though I set them up to be in map definition
>>> Hi,
>>> newer version of King.Oracle 0.3.3 provider:
>>> *	Support for Spatial Views
>>> 	It will display views based on spatial tables. Views needs to be
>>> added into sdo_geom_metadata for provider to find them.
>>> Get it here: www.sl-king.com/fdooracle
>>> Haris
>> View this message in context:
>> http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978386
>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6996820
View this message in context: http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6997300
More information about the Mapguide_users mailing list
