[mapguide-users] RE: King.Oracle 0.3.3
Haris Kurtagic haris at sl-king.com
Wed Oct 25 14:26:19 EDT 2006
I will look at MG repository stuff and what can be defined there.
Haris
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, October 25, 2006 7:51 PM
Subject: RE: [mapguide-users] RE: King.Oracle 0.3.3
I agree that being able to specify geometry type is important.  The
Autodesk Oracle provider works the same way.  Instead of relying on
database stored metadata, it seems that this could be defined at the
layer definition level in the MGOS repository.  When publishing the
layer through Studio or whatever means, an option to simply say "this
layer is polygonal only" and
then have the legend reflect this would be good.   Same goes for the key
field - I would like to be able to specify this on an MGOS layer by
layer basis.
Andy
Sent: Wednesday, October 25, 2006 10:42 AM
Subject: [mapguide-users] RE: King.Oracle 0.3.3
Its seems to me that eventually you will have to rely on user supplied
metadata to solve this problem. For each table or view, a user would be
able
to specify a key column and also maybe what type of geometry
(point,line,
poly, mixed, etc...) is in the table. Specifying a type of geometry
would be
nice, so that layers created from feature classes are correctly
displayed in
legend. Eventually, you will probably need to allow for other types of
metadata as well. This info could be stored in a table within Oracle or
in a
config file internal to the provider. I'm not sure that it matters.
Joel
haris kurtagic wrote:
> Hi Joel,
> Regarding selecting, I tested it again and I am able to select layers
> wich comes from tables with primary keys.
> Right now primary key is only way to tell provider to use that column
> as identity.
> Any sugestions are welcome.
> I should do something for views also.
> Note:
>  It seems there is an issue in viewer regarding selecting:
> If you have a large scale layer and then zoom in much smaller and then
> you click on feature, mg will send wrong coordinates for selecting on
> that click hence tooltip will work, it send different coordinates to
> provider for tooltip and click on.
> If you take that same layer and put in the map, and give map a smaller
> extents, click on and tooltip works.
> Haris
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Tuesday, October 24, 2006 8:05 PM
> Subject: Re: [mapguide-users] King.Oracle 0.3.3
> Fantastic! Talk about agile development. My views showed up and are
> now displaying. I'm having some performance problems, but those could
> easily be my fault. Too much data on too small a machine. Still, I
> have a gig of ram on my machine, and while I was browsing a map, I
> completely filled it up. I don't think that should happen?
> Weirdest thing I have found is that none of my map features in DWF or
> AJAX are selectable, even though I set them up to be in map definition
>> Hi,
>> newer version of King.Oracle 0.3.3 provider:
>> *	Support for Spatial Views
>> 	It will display views based on spatial tables. Views needs to be
>> added into sdo_geom_metadata for provider to find them.
>> Get it here: www.sl-king.com/fdooracle
>> Haris
> http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978386
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6996820
More information about the Mapguide_users mailing list
