Selection based on a polygon...
Bill MacDonald blmacdonald at agri.ns.ca
Thu Oct 26 10:47:34 EDT 2006
I'm trying to query map features by drawing a polygon on the map and am
having nothing but trouble with this.
Here is a sample of the code I'm using:
Dim sLayerName As String = "Points"
      Dim layerObj As MgLayer
      layerObj = map.GetLayers().GetItem(sLayerName)
      Dim featureResId As MgResourceIdentifier
      featureResId = New
MgResourceIdentifier(layerObj.GetFeatureSourceId())
      Dim featureGeometryName As String
      featureGeometryName = layerObj.GetFeatureGeometryName()
      Dim sClassName As String
      sClassName = layerObj.GetFeatureClassName()
      Dim queryOptions As New MgFeatureQueryOptions()
        Dim sFilter As String = ""
        queryOptions.SetFilter(sFilter)
        Dim wktRW As New MgWktReaderWriter()
        Dim geom As MgGeometry
        Dim sPolygon As String
        sPolygon = "POLYGON XY (("
        While i < dCoords.Length
            sPolygon = sPolygon & dCoords(0, 0) & " " & dCoords(0, 1) &
            i = i + 1
        End While
        If Right(sPolygon, 2) = ", " Then sPolygon = Left(sPolygon,
Len(sPolygon) - 2)
        sPolygon = sPolygon & "))"
        geom = wktRW.Read(sPolygon)
        queryOptions.SetSpatialFilter(featureGeometryName, geom,
MgFeatureSpatialOperations.Inside)
        Dim featureReader As MgFeatureReader
        featureReader = featureService.SelectFeatures(featureResId,
sClassName, queryOptions)
        ' Process each item in the MgFeatureReader, displaying the owner
name And address
        While featureReader.ReadNext()
            Dim val As String
            val = featureReader.GetString("NAME") & ", " &
featureReader.GetString("RPROPAD")
            Response.Write(val & "<br />")
        End While
I think I may have problems with the creation of the POLYGON but I'm
sure there are other things I am missing.
Any help would be greatly appreciated
Thanks
Billy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061026/0c3e97d3/attachment.html
More information about the Mapguide_users mailing list
