[mapguide-users] An exception occurred in FDO component.
The Oracle runtime wasnot found (module
Kim Woynowskie
kimw at ci.grandjct.co.us
Tue Sep 12 14:22:18 EDT 2006
The client is installed, I did double check to make sure. (actually reinstalled the client) I also looked in the directory structure and found the oci.dll file.
To:<users at mapguide.osgeo.org>
Date: Tuesday, September 12, 2006
Subject: RE: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
Sound like you don't have Oracle client installed.
It will find tables which have record in xxx_sdo_geom_metadata view in Oracle.
Haris
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Tuesday, September 12, 2006 6:26 PM
Subject: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
I keep getting this error of being unable to connect to Oracle when I try to establish a connection with Studio.
When I work from the server, it does find the Oracle tables.
This is my first attempt at setting up a connection, any help will be appreciated.
Thanks
Kim
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060912/f3b49ec4/attachment.html
More information about the Mapguide_users
