[mapguide-users] An exception occurred in FDO component.The Oracle runtime wasnot found (module
Haris Kurtagic haris at sl-king.com
Tue Sep 12 15:54:53 EDT 2006
Which Oracle provider are using Autodesk or King, and which version of
Oracle client ?
Haris
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Tuesday, September 12, 2006 8:22 PM
Subject: RE: [mapguide-users] An exception occurred in FDO component.The
The client is installed, I did double check to make sure.  (actually
reinstalled the client) I also looked in the directory structure and
found the oci.dll file.
To:	 <users at mapguide.osgeo.org>
Date: 	Tuesday, September 12, 2006
component. The Oracle runtime wasnot found (module OCI.dll)
Sound like you don't have Oracle client installed.
It will find tables which have record in xxx_sdo_geom_metadata view in
Oracle.
Haris
Sent: Tuesday, September 12, 2006 6:26 PM
Subject: [mapguide-users] An exception occurred in FDO component. The
I keep getting this error of being unable to connect to Oracle when I
try to establish a connection with Studio.
When I work from the server, it does find the Oracle tables.
This is my first attempt at setting up a connection, any help will be
appreciated.
Thanks
Kim
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060912/829ae384/attachment.html
More information about the Mapguide_users mailing list
