[mapguide-users] An exception occurred in FDOcomponent.The Oracle runtime wasnot found (module
Kim Woynowskie kimw at ci.grandjct.co.us
Wed Sep 13 16:34:55 EDT 2006
Andy and Haris
Well I checked everything and found all in order, so re-booted the server "again" and now Oracle is working, did not change a thing.  So guess it just needed and extra KICK to get things moving.  Thanks for all your suggestions, I am sure I will be asking for more help again.
Kim
To:<users at mapguide.osgeo.org>
Date: Tuesday, September 12, 2006
Subject: RE: [mapguide-users] An exception occurred in FDOcomponent.The Oracle runtime wasnot found (module
I've tested Autodesk Oracle provider with 10.2 and i've connected to db.
Perhaps your path to client\bin?
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Tuesday, September 12, 2006 11:30 PM
10.2 oracle client
I also tested for the SQL server and it works/connects with no problem
Subject: RE: [mapguide-users] An exception occurred in FDO component.The Oracle runtime wasnot found (module
Which Oracle provider are using Autodesk or King, and which version of Oracle client ?
Haris
Sent: Tuesday, September 12, 2006 8:22 PM
The client is installed, I did double check to make sure.  (actually reinstalled the client) I also looked in the directory structure and found the oci.dll file.
Subject: RE: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
Sound like you don't have Oracle client installed.
It will find tables which have record in xxx_sdo_geom_metadata view in Oracle.
Haris
Sent: Tuesday, September 12, 2006 6:26 PM
Subject: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
I keep getting this error of being unable to connect to Oracle when I try to establish a connection with Studio.
When I work from the server, it does find the Oracle tables.
This is my first attempt at setting up a connection, any help will be appreciated.
Thanks
Kim
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060913/78aae13f/attachment.html
More information about the Mapguide_users mailing list
