Re-4: [mapguide-users] EPSG-WKT Conversion Problems
Axel Dörr a.doerr at doerrib.de
Fri Sep 15 10:14:54 EDT 2006
Hello List,
does anybody have already a translation for EPSG:31467? Maybe somebody from Germany.
Otherwise, what is needed to create the correct command? I would try to deliver the required
information?
I would be very pleased for help! I´m just a geologist and not a programmer, surveyor, ...
Axel
Original Message        processed by David InfoCenter
Subject: RE: Re-2: [mapguide-users] EPSG-WKT Conversion Problems (13-Sep-2006 19:02)
To:      mapserver_user_discussion at doerrib.de
The only reason it is working with EPSG:4326 at all right now is because a translate statement has been added to OgcWmsService.config.awd (even though it is commented out, it is being read due to a bug that Autodesk has also acknowledged).  That line is:
 <translate from="EPSG:4326">GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]</translate>
So, if you can come up with proper translation for EPSG:31467, add it to this file, then it might work.  Other than that, you might be able to take your demo data set and convert it to WGS84 latitude/longitude and then utilize those layers for your WMS calls.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, September 13, 2006 8:44 AM
Subject: Re-2: [mapguide-users] EPSG-WKT Conversion Problems
I hope the bug can be fixed soon, because i have the same problem with
espg code 31467 in germany and a demo end of September. I hope it will
work untill then. Unfortunatly i'm not a programmer and can help.
Axel
Subject: RE: [mapguide-users] EPSG-WKT Conversion Problems (13-Sep-2006 17:05)
This sounds like a known bug:
https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=2911
Jason
Sent: Wednesday, September 13, 2006 07:52
Subject: [mapguide-users] EPSG-WKT Conversion Problems
Hi !
I have problem to send 4326 (WGS84) epsg code to MapGuide in my WMS request.
WMS request is related to Sheboygan sample. It is :
http://localhost/mapguide/mapagent/mapagent.fcgi?request=GetMap&service=WMS&layers=Samples/Sheboygan/Layers/Buildings&srs=EPSG:4326&bbox=- 87.74,43.68,- 87.69,43.815&width=500&height=500&format=image/png&version=1.0.0
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060915/58231fc2/attachment.html
More information about the Mapguide_users mailing list
