[mapguide-users] POOL:DWF or AJAX
Jason Birch Jason.Birch at nanaimo.ca
Fri Sep 15 11:08:50 EDT 2006
You can actually use these tools in conjunction.  I have both installed,
and will sometimes use the Tortoise tool when I know a single file has
changed and I don't want to go through the whole process.  However, I
prefer the commandline tools because they allow me to script the
update/export/build process.  My process is something like:
- Update FDO (using a version of the batch file provided in the
repository, changed from checkout to update)
- Export FDO to a build directory
- Build FDO third party tools
- Build FDO
- Update MapGuide
- Export MapGuide to a build directory
- Install FDO into the MapGuide OEM structure
- Build MapGuide
- Transfer MapGuide to my VMWare server.
With command line tools, I've been able to script most of this, with the
exception of building MapGuide.
Ivan, you've probably figured this out from the path that Kenneth
provided, but this is the command to check out MapGuide
svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev
"D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
Jason
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: Friday, September 15, 2006 07:26
Subject: Re: [mapguide-users] POOL:DWF or AJAX
If you feel uncomfortable using commandline tools, I would recommend
that you try
TortoiseSVN, which is an Explorer extension.
http://tortoisesvn.tigris.org/
That way, you can check out, or update simply by right clicking on the
folder in Explorer.
Using this approach, you only need the URL of the repository, which can
be found on the osgeo website under "Subversion".
FDO: https://fdo.osgeo.org/svn/fdo/trunk
MapGuide: https://mapguide.osgeo.org/svn/mapguide/trunk
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060915/b3ba5348/attachment.html
More information about the Mapguide_users mailing list
