[mapguide-users] POOL:DWF or AJAX
Ivan Miličević ivan at ineo.hr
Fri Sep 15 11:16:31 EDT 2006
Jason, where can i find a list of changes from 1.0.1. until today (talking
about mapguides server)?
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 15. rujan 2006 17:09
Subject: RE: [mapguide-users] POOL:DWF or AJAX
You can actually use these tools in conjunction.  I have both installed, and
will sometimes use the Tortoise tool when I know a single file has changed
and I don't want to go through the whole process.  However, I prefer the
commandline tools because they allow me to script the update/export/build
process.  My process is something like:
- Update FDO (using a version of the batch file provided in the repository,
changed from checkout to update)
- Export FDO to a build directory
- Build FDO third party tools
- Build FDO
- Update MapGuide
- Export MapGuide to a build directory
- Install FDO into the MapGuide OEM structure
- Build MapGuide
- Transfer MapGuide to my VMWare server.
With command line tools, I've been able to script most of this, with the
exception of building MapGuide.
Ivan, you've probably figured this out from the path that Kenneth provided,
but this is the command to check out MapGuide
svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev
"D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
Jason
  _____
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: Friday, September 15, 2006 07:26
Subject: Re: [mapguide-users] POOL:DWF or AJAX
If you feel uncomfortable using commandline tools, I would recommend that
you try
TortoiseSVN, which is an Explorer extension.
http://tortoisesvn.tigris.org/
That way, you can check out, or update simply by right clicking on the
folder in Explorer.
Using this approach, you only need the URL of the repository, which can be
found on the osgeo website under "Subversion".
FDO: https://fdo.osgeo.org/svn/fdo/trunk
MapGuide: https://mapguide.osgeo.org/svn/mapguide/trunk
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060915/82fbbe37/attachment.html
More information about the Mapguide_users mailing list
