[mapguide-users] POOL:DWF or AJAX
Jason Birch Jason.Birch at nanaimo.ca
Fri Sep 15 11:30:19 EDT 2006
I don't think that it's published anywhere in an easy-to-read format.
You can either mine the Project Tracker (this is used extensively) for items with a target release of 1.0.2:
https://mapguide.osgeo.org/servlets/Scarab
or search through the Issues or Commits mailing lists depending on the amount of detail you want:
https://mapguide.osgeo.org/servlets/SummarizeList?listName=issues
https://mapguide.osgeo.org/servlets/SummarizeList?listName=commits
Jason
Sent: Friday, September 15, 2006 08:17
Subject: RE: [mapguide-users] POOL:DWF or AJAX
Jason, where can i find a list of changes from 1.0.1. until today (talking about mapguides server)?
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 15. rujan 2006 17:09
You can actually use these tools in conjunction.  I have both installed, and will sometimes use the Tortoise tool when I know a single file has changed and I don't want to go through the whole process.  However, I prefer the commandline tools because they allow me to script the update/export/build process.  My process is something like:
- Update FDO (using a version of the batch file provided in the repository, changed from checkout to update)
- Export FDO to a build directory
- Build FDO third party tools
- Build FDO
- Update MapGuide
- Export MapGuide to a build directory
- Install FDO into the MapGuide OEM structure
- Build MapGuide
- Transfer MapGuide to my VMWare server.
With command line tools, I've been able to script most of this, with the exception of building MapGuide.
Ivan, you've probably figured this out from the path that Kenneth provided, but this is the command to check out MapGuide
svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev "D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
Jason
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: Friday, September 15, 2006 07:26
Subject: Re: [mapguide-users] POOL:DWF or AJAX
If you feel uncomfortable using commandline tools, I would recommend that you try
TortoiseSVN, which is an Explorer extension.
http://tortoisesvn.tigris.org/
That way, you can check out, or update simply by right clicking on the folder in Explorer.
Using this approach, you only need the URL of the repository, which can be found on the osgeo website under "Subversion".
FDO: https://fdo.osgeo.org/svn/fdo/trunk
MapGuide: https://mapguide.osgeo.org/svn/mapguide/trunk
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060915/2a94b03f/attachment.html
More information about the Mapguide_users mailing list
