loading data thru Webstudio/ MGStudio expires Oct 1st .
Zeeshan
mshailze at yahoo.com
Fri Sep 29 00:47:01 EDT 2006
Mapguide Studio expires Oct 1st and suddenly I realized that I would be
crippled without it.
and altough I have started to use webstudio to access my repositories on
the server,
I am somehow not comfortable and find many things missing
My biggest worry now is -
How to upload data do we upload data in Webs studio? There are no load
procedures
Searching some threads i found this
(http://www.nabble.com/MapGuide-Open-Source-Web-Studio-tf1737544.html#a5545973)
<?xml version="1.0" encoding="utf-8" ?>
> > <FeatureSource
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-
> > instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> > xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> > <Provider>OSGeo.SDF.3.0</Provider>
> > <Parameter>
> > <Name>File</Name>
> > <Value>%MG_DATA_FILE_PATH%Parcels.sdf</Value>
> > </Parameter>
> > <Parameter>
> > <Name>ReadOnly</Name>
> > <Value>TRUE</Value>
> > </Parameter>
> > </FeatureSource>
> > If you replace the %MG_DATA_FILE_PATH% with a physical path to the
> > file on the servers file system you can effectively "reference"
> > data and not worry about uploading it. A similar technique can be
> > used for SHP files, Raster files, etc.
My understanding about the above is
1) I will have to FTP the sdf from local system on to a Directory on the
server
this directory would be the repository folder
C:\Program Files\MapGuideOpenSource\Server\Repositories\Library\DataFiles
2) Then i will have to search for the above code and write physical path
3) then use webstudio to access it-- tooltips and colors and build maps
etc etc
but no idea where to Find the file and what/Where to write , We do not
have programming expertise ,
So can some one please Tell us where to find the above code in which file
the help files are also missing webstudio
Thanks in Advance
View this message in context: http://www.nabble.com/loading-data-thru-Webstudio--MGStudio-expires-Oct-1st-.-tf2355021.html#a6559349
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users
