[mapguide-users] loading data thru Webstudio/ MGStudio expires Oct 1st .
Paul Spencer
pspencer at dmsolutions.ca
Fri Sep 29 06:51:23 EDT 2006
The latest SVN version of webstudio contains bug fixes for file
uploads for SDF and SHP feature sources and it seems pretty stable
now. There are no load procedures, though, you have to create a new
feature source directly.
While it is possible and quite straight-forward to create the ability
to configure other feature source providers, this has not been done yet.
Contributions to this part of web studio (and to a WebLayout editing
capability) would be most timely :)
Cheers
Paul
On 29-Sep-06, at 12:47 AM, Zeeshan wrote:
> Mapguide Studio expires Oct 1st and suddenly I realized that I
> would be
> crippled without it.
> and altough I have started to use webstudio to access my
> repositories on
> the server,
> I am somehow not comfortable and find many things missing
> My biggest worry now is -
> How to upload data do we upload data in Webs studio? There are no
> load
> procedures
> Searching some threads i found this
> (http://www.nabble.com/MapGuide-Open-Source-Web-Studio-
> tf1737544.html#a5545973)
> <?xml version="1.0" encoding="utf-8" ?>
>>> <FeatureSource
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-
>>> instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>> <Provider>OSGeo.SDF.3.0</Provider>
>>> <Parameter>
>>> <Name>File</Name>
>>> <Value>%MG_DATA_FILE_PATH%Parcels.sdf</Value>
>>> </Parameter>
>>> <Parameter>
>>> <Name>ReadOnly</Name>
>>> <Value>TRUE</Value>
>>> </Parameter>
>>> </FeatureSource>
>>> If you replace the %MG_DATA_FILE_PATH% with a physical path to the
>>> file on the servers file system you can effectively "reference"
>>> data and not worry about uploading it. A similar technique can be
>>> used for SHP files, Raster files, etc.
> My understanding about the above is
> 1) I will have to FTP the sdf from local system on to a
> Directory on the
> server
> this directory would be the repository folder
> C:\Program Files\MapGuideOpenSource\Server\Repositories\Library
> \DataFiles
> 2) Then i will have to search for the above code and write
> physical path
> 3) then use webstudio to access it-- tooltips and colors and build
> maps
> etc etc
> but no idea where to Find the file and what/Where to write , We
> do not
> have programming expertise ,
> So can some one please Tell us where to find the above code in
> which file
> the help files are also missing webstudio
> Thanks in Advance
> View this message in context: http://www.nabble.com/loading-data-
> thru-Webstudio--MGStudio-expires-Oct-1st-.-tf2355021.html#a6559349
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide_users
