[Mapguide_users] KML files and Localhost
Andy Morsell
amorsell at spatialgis.com
Thu Jan 4 13:16:08 EST 2007
Well, I guess there's our answer as to what will happen if you use a pre
Beta 4 release of Google Earth client. ;)
Andy
_____
From: Scott Hameister [mailto:ScottH at mPower-tech.com]
Sent: Thursday, January 04, 2007 10:00 AM
To: 'Chris Claydon'; 'Andy Morsell'; mapguide_users at lists.osgeo.org
Subject: RE: [Mapguide_users] KML files and Localhost
BINGO.We have a solution and I feel dumb as a box of Rocks. Thanks for the
Persistence guys.
_____
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Chris Claydon
Sent: Thursday, January 04, 2007 11:55 AM
To: Andy Morsell; mapguide_users at lists.osgeo.org
Interesting. Are you using the latest Google Earth beta? I'm using version
4.0.2416. MapGuide uses elements only supported by version 2.1 of the KML
spec, and you need a fairly recent version of the GE beta for it to work
properly. I'm not sure what'll happen if you feed MapGuide-generated KML
into an old version of GE.
Chris.
_____
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: January 4, 2007 10:49 AM
To: mapguide_users at lists.osgeo.org
No, I do not get a NetworkLinkControl element in my KML. The only
difference I can see between Scott's and mine is that I do not have any
CDATA tags in mine. I am using the only version of RC1 I have available
which is installed on Linux Fedora 4 from the latest tarballs last week. I
am also not using localhost.
I just realized that this the KML when saved from Google Earth. I saved the
KMZ from the GetMapKml request and extracted and looked at the KML file.
That one does contain the NetworkLinkControl element.
Andy
_____
From: Chris Claydon [mailto:chris.claydon at autodesk.com]
Sent: Thursday, January 04, 2007 9:30 AM
Hi Andy,
If you issue a GetMapKml request, do you get a NetworkLinkControl element
near the top of the KML document? It should be there, but it's not present
in Scott's example. I have a suspicion that something in his installation is
out-of-date.
Scott,
Did you get my second email regarding the DLL versions yesterday?
Chris.
_____
Sent: January 4, 2007 10:23 AM
Scott,
That screenshot shows the Sheboygan network link folder as turned off and
the error coming from your MyWeather map. Does Sheboygan work or are all
localhost GetMapKml and GetLayerKml requests not working? The KML you
included looks fine for the network link definitions.
Andy
_____
Sent: Thursday, January 04, 2007 8:00 AM
To: 'Andy Morsell'
<kml xmlns="http://earth.google.com/kml/2.0">
<Document>
<name>Sheboygan</name>
<open>1</open>
<Region><LatLonAltBox><north>43.797520</north><south>43.691398</south><east>
-87.695522</east><west>-87.764987</west></LatLonAltBox></Region>
<NetworkLink>
<name>Roads</name>
<Url>
</Url>
<Link><href>http://localhost:80/mapguide/mapagent/mapagent.fcgi?OPERATION=Ge
tLayerKml<![CDATA[&VERSION=1]]><![CDATA[&LAYERDEFINITION=Library://Samples/S
heboygan/Layers/Roads.LayerDefinition]]><![CDATA[&DRAWORDER=8]]><![CDATA[&FO
RMAT=KMZ]]><![CDATA[&SESSION=01ef0442-0000-1000-800b-00c09ffd5d3f_en
]]></href><viewRefreshMode>onStop</viewRefreshMode><viewRefreshTime>1</viewR
efreshTime><viewFormat>BBOX=[bboxWest],[bboxSouth],[bboxEast],[bboxNorth]<![
CDATA[&WIDTH=[horizPixels]]]><![CDATA[&HEIGHT=[vertPixels]]]></viewFormat></
Link>
</NetworkLink>
<NetworkLink>
<name>Rail Lines</name>
<visibility>0</visibility>
<Url>
--------------------snip------------------------
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20070104/66b9ebdb/attachment.html
More information about the Mapguide_users
