[Mapguide_users] MapGuide OS Package to Ent Inpot Issues with
CordSystems
Bruce Dechant
bruce.dechant at autodesk.com
Mon Jan 8 17:05:27 EST 2007
Chris,
The problem is that MGOS and MGE use different coordinate system
libraries that have some differences like what you have below.
My suggestion to you is to use a coordinate system that is compatible
with both if you really need to work with both MGOS and MGE.
If you happen to be an Autodesk Map user the coordinate system library
that MGE uses is the same so picking a system compatible with Map will
automatically make it compatible with MGE.
Thanks,
Bruce
_____
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: January 8, 2007 2:56 PM
To: mapguide_users at lists.osgeo.org
Subject: [Mapguide_users] MapGuide OS Package to Ent Inpot Issues with
CordSystems
When a MapGuide project is packaged (MGP) from an Open Source MapGuide
seems there is issues viewing layers once imported to Enterprise. Is
there a work around to fix the cord systems so once imported to an Ent
Server everything works the same. I am sure others might run into this
working with diff customer needs and such.
*******************ERROR*******************
The coordinate system is invalid. PROJCS["NAD83 Ohio State Planes,
Northern Zone, US
Foot",GEOGCS["NAD83",DATUM["D_NAD83",SPHEROID["Geodetic_Reference_System
_of_1980",6378137,298.2572221009113]],PRIMEM["Greenwich",0],UNIT["Degree
",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER
["standard_parallel_1",41.7],PARAMETER["standard_parallel_2",40.43333333
33333],PARAMETER["latitude_of_origin",39.6666666666667],PARAMETER["centr
al_meridian",-82.5],PARAMETER["false_easting",1968500],PARAMETER["false_
northing",0],UNIT["Foot_US",0.3048006]] Could not convert OGC WKT to
Mentor. wktFlvrNone - WKT string referenced datum named 'D_NAD83'. This
datum name could not be mapped to a dictionary definition wktFlvrOgc -
The PROJECTION specification contained within the text presented as a
WKT definition specified an unsupported projection
(Lambert_Conformal_Conic). wktFlvrGeoTiff - The PROJECTION specification
contained within the text presented as a WKT definition specified an
unsupported projection (Lambert_Conformal_Conic). wktFlvrEsri - WKT
string referenced datum named 'D_NAD83'. This datum name could not be
mapped to a dictionary definition wktFlvrOracle - The PROJECTION
specification contained within the text presented as a WKT definition
specified an unsupported projection (Lambert_Conformal_Conic).
wktFlvrGeoTools - The PROJECTION specification contained within the text
presented as a WKT definition specified an unsupported projection
(Lambert_Conformal_Conic). wktFlvrEpsg - WKT system named NAD83 Ohio
State Planes uses a parameter arrangement unsupported by CS-MAP. None of
the Mentor flavors could parse the specified OGC WKT.
Northern Zone, US
the Mentor flavors could parse the specified OGC WKT. Exception occurred
in method MgCoordinateSystem.MgCoordinateSystem at line 76 in file
c:\build_tux_area\mgdev\common\service\coordinatesystem\CoordinateSystem
.cpp
Chris
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20070108/1e51f723/attachment-0001.html
More information about the Mapguide_users
