[Mapguide_users] Import DWG fails
Jim O'Leary joleary.public at gmail.com
Mon Jan 8 17:50:58 EST 2007
The Autodesk MapGuide site at
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7176643 indicates
that you can import DWG files. However, when i try to do this with Studio I
soon get the error:
Found when opening C:\Program
Files\MapGuideOpenSource\Server\cmn\squamish\cadastral.dwg ...
An error occured.
If I continue, the DETE.exe process eventually uses up all memory and I must
reboot. I'm using MGOS 1.1.0, and am dragging the DWG file into Studio. I am
reluctant to try the same with our MGE server, as it would likely bring it
down.
Any suggestions?
View this message in context: http://www.nabble.com/Import-DWG-fails-tf2942668.html#a8228372
More information about the Mapguide_users mailing list
