[MapProxy-dev] PSC Voting required - Plugin infrastructure
    Matt Walker
    walkermatt at longwayaround.org.uk
    Wed Mar 23 03:04:47 PDT 2022
+1 from me regarding a plugin system
On Wed, 23 Mar 2022, 09:00 Tobias Wendorff, <tobias.wendorff at tu-dortmund.de>
wrote:
> Hi,
> I'm not a PSC, but have a question to this (I'd give a +1).
> MapProxy has always lacked the ability to access GDAL raster datasets
> directly, e.g. GeoTIFF/COG or PDF (GeoPDF or via VRT). This required
> external services (e.g. a WMS) or custom code.
> Since HIPS service seems to use GDAL, couldn't these bindings be
> provided as additional input source? For some projects this would open
> up completely new possibilities: you could simply add a raster dataset
> in YAML and use it in MapProxy.
> Best regards,
> Tobias
> Am 22.03.2022 um 13:45 schrieb Johannes Weskamm:
> > Recently I've done an exploratory work for CNES to add new capabilities
> > to MapProxy, to add the support for a new standard, called HIPS, used by
> > the planetology and astronomy communities, as a MapProxy source and
> > service, and bridging with the traditional OGC protocols (WMS, WMTS...):
> > that is e.g. exposing a WMS source as a HIPS service, and vice-verca.
> MapProxy-dev mailing list
> MapProxy-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapproxy-dev
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20220323/bf8e9069/attachment.html>
More information about the MapProxy-dev
