[mapserver-commits] r7163 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Dec 10 12:29:44 EST 2007
Author: tomkralidis
Date: 2007-12-10 12:29:43 -0500 (Mon, 10 Dec 2007)
New Revision: 7163
trunk/mapserver/mapwcs11.c
fix warnings about casting
Modified: trunk/mapserver/mapwcs11.c
--- trunk/mapserver/mapwcs11.c 2007-12-10 15:42:35 UTC (rev 7162)
+++ trunk/mapserver/mapwcs11.c 2007-12-10 17:29:43 UTC (rev 7163)
@@ -192,7 +192,7 @@
status = msWCSGetCoverageMetadata(layer, &cm);
if(status != MS_SUCCESS) return MS_FAILURE;
- psCSummary = xmlNewChild( psContents, NULL, "CoverageSummary", NULL );
+ psCSummary = xmlNewChild( psContents, NULL, BAD_CAST "CoverageSummary", NULL );
/* Title (from description) */
@@ -200,12 +200,12 @@
value = msOWSLookupMetadata( &(layer->metadata), "COM", "description");
if( value == NULL )
value = layer->name;
- xmlNewChild( psCSummary, psOwsNs, "Title", value );
+ xmlNewChild( psCSummary, psOwsNs, BAD_CAST "Title", BAD_CAST value );
/* Identifier (layer name) */
- xmlNewChild( psCSummary, NULL, "Identifier", layer->name );
+ xmlNewChild( psCSummary, NULL, BAD_CAST "Identifier", BAD_CAST layer->name );
/* Keywords */
@@ -215,12 +215,12 @@
if (value) {
xmlNodePtr psNode;
- psNode = xmlNewChild(psCSummary, psOwsNs, "Keywords", NULL);
+ psNode = xmlNewChild(psCSummary, psOwsNs, BAD_CAST "Keywords", NULL);
tokens = msStringSplit(value, ',', &n);
if (tokens && n > 0) {
for (i=0; i<n; i++) {
- xmlNewChild(psNode, NULL, "Keyword", tokens[i] );
+ xmlNewChild(psNode, NULL, BAD_CAST "Keyword", BAD_CAST tokens[i] );
msFreeCharArray(tokens, n);
@@ -328,22 +328,22 @@
/* Create document. */
- psDoc = xmlNewDoc("1.0");
+ psDoc = xmlNewDoc(BAD_CAST "1.0");
- psRootNode = xmlNewNode(NULL, "Capabilities");
+ psRootNode = xmlNewNode(NULL, BAD_CAST "Capabilities");
xmlDocSetRootElement(psDoc, psRootNode);
/* Name spaces */
- xmlSetNs(psRootNode, xmlNewNs(psRootNode, "http://www.opengis.net/wcs/1.1", NULL));
- psOwsNs = xmlNewNs(psRootNode, MS_OWSCOMMON_OWS_NAMESPACE_URI, MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
- psXLinkNs = xmlNewNs(psRootNode, MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
- xmlNewNs(psRootNode, MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX);
- xmlNewNs(psRootNode, MS_OWSCOMMON_OGC_NAMESPACE_URI, MS_OWSCOMMON_OGC_NAMESPACE_PREFIX );
+ xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/wcs/1.1", NULL));
+ psOwsNs = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
+ psXLinkNs = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
+ xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX);
+ xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OGC_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OGC_NAMESPACE_PREFIX );
- xmlNewProp(psRootNode, "version", params->version );
+ xmlNewProp(psRootNode, BAD_CAST "version", BAD_CAST params->version );
/* Service metadata. */
@@ -430,7 +430,7 @@
/* Contents section. */
- psMainNode = xmlNewChild( psRootNode, NULL, "Contents", NULL );
+ psMainNode = xmlNewChild( psRootNode, NULL, BAD_CAST "Contents", NULL );
for(i=0; i<map->numlayers; i++)
@@ -511,7 +511,7 @@
/* Create CoverageDescription node. */
- psCD = xmlNewChild( psRootNode, NULL, "CoverageDescription", NULL );
+ psCD = xmlNewChild( psRootNode, NULL, BAD_CAST "CoverageDescription", NULL );
@@ -519,12 +519,12 @@
if( value == NULL )
- xmlNewChild( psCD, psOwsNs, "Title", value );
+ xmlNewChild( psCD, psOwsNs, BAD_CAST "Title", BAD_CAST value );
- xmlNewChild( psCD, NULL, "Identifier", layer->name );
+ xmlNewChild( psCD, NULL, BAD_CAST "Identifier", BAD_CAST layer->name );
/* Keywords */
@@ -533,18 +533,18 @@
if (value)
msLibXml2GenerateList(
- xmlNewChild(psCD, psOwsNs, "Keywords", NULL),
+ xmlNewChild(psCD, psOwsNs, BAD_CAST "Keywords", NULL),
NULL, "Keyword", value, ',' );
/* Domain */
- psDomain = xmlNewChild( psCD, NULL, "Domain", NULL );
+ psDomain = xmlNewChild( psCD, NULL, BAD_CAST "Domain", NULL );
/* SpatialDomain */
- psSD = xmlNewChild( psDomain, NULL, "SpatialDomain", NULL );
+ psSD = xmlNewChild( psDomain, NULL, BAD_CAST "SpatialDomain", NULL );
/* imageCRS bounding box. */
@@ -578,24 +578,24 @@
char format_buf[500];
- psGridCRS = xmlNewChild( psSD, NULL, "GridCRS", NULL );
+ psGridCRS = xmlNewChild( psSD, NULL, BAD_CAST "GridCRS", NULL );
- xmlNewChild( psGridCRS, NULL, "GridBaseCRS", cm.srs_urn );
- xmlNewChild( psGridCRS, NULL, "GridType",
- "urn:ogc:def:method:WCS:1.1:2dSimpleGrid" );
+ xmlNewChild( psGridCRS, NULL, BAD_CAST "GridBaseCRS", BAD_CAST cm.srs_urn );
+ xmlNewChild( psGridCRS, NULL, BAD_CAST "GridType",
+ BAD_CAST "urn:ogc:def:method:WCS:1.1:2dSimpleGrid" );
sprintf( format_buf, "%.15g %.15g",
cm.geotransform[0]+cm.geotransform[1]/2+cm.geotransform[2]/2,
cm.geotransform[3]+cm.geotransform[4]/2+cm.geotransform[5]/2);
- xmlNewChild( psGridCRS, NULL, "GridOrigin", format_buf );
+ xmlNewChild( psGridCRS, NULL, BAD_CAST "GridOrigin", BAD_CAST format_buf );
cm.geotransform[1], cm.geotransform[5] );
- xmlNewChild( psGridCRS, NULL, "GridOffsets", format_buf );
+ xmlNewChild( psGridCRS, NULL, BAD_CAST "GridOffsets", BAD_CAST format_buf );
- xmlNewChild( psGridCRS, NULL, "GridCS",
- "urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS" );
+ xmlNewChild( psGridCRS, NULL, BAD_CAST "GridCS",
+ BAD_CAST "urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS" );
@@ -627,37 +627,37 @@
psField =
xmlNewChild(
- xmlNewChild( psCD, NULL, "Range", NULL ),
- NULL, "Field", NULL );
+ xmlNewChild( psCD, NULL, BAD_CAST "Range", NULL ),
+ NULL, BAD_CAST "Field", NULL );
value = msOWSGetEncodeMetadata( &(layer->metadata), "COM",
"rangeset_label", NULL );
if( value )
- xmlNewChild( psField, psOwsNs, "Title", value );
+ xmlNewChild( psField, psOwsNs, BAD_CAST "Title", BAD_CAST value );
/* ows:Abstract? TODO */
"rangeset_name", "bands" );
- xmlNewChild( psField, NULL, "Identifier", value );
+ xmlNewChild( psField, NULL, BAD_CAST "Identifier", BAD_CAST value );
/* <NullValue> TODO */
psInterpMethods =
- xmlNewChild( psField, NULL, "InterpolationMethods", NULL );
+ xmlNewChild( psField, NULL, BAD_CAST "InterpolationMethods", NULL );
xmlNewChild( psInterpMethods, NULL,
- "DefaultMethod", "nearest neighbour" );
- xmlNewChild( psInterpMethods, NULL, "OtherMethod", "bilinear" );
+ BAD_CAST "DefaultMethod", BAD_CAST "nearest neighbour" );
+ xmlNewChild( psInterpMethods, NULL, BAD_CAST "OtherMethod", BAD_CAST "bilinear" );
/* Do axes properly later... */
- psAxis = xmlNewChild( psField, NULL, "Axis", NULL );
- xmlNewProp( psAxis, "identifier", "Band" );
+ psAxis = xmlNewChild( psField, NULL, BAD_CAST "Axis", NULL );
+ xmlNewProp( psAxis, BAD_CAST "identifier", BAD_CAST "Band" );
- xmlNewChild(psAxis, NULL, "AvailableKeys", NULL),
+ xmlNewChild(psAxis, NULL, BAD_CAST "AvailableKeys", NULL),
NULL, "Key", "1", ',' );
@@ -760,22 +760,22 @@
- psRootNode = xmlNewNode(NULL, "CoverageDescriptions");
+ psRootNode = xmlNewNode(NULL, BAD_CAST "CoverageDescriptions");
/* Name spaces */
/* Generate a CoverageDescription for each requested coverage. */
More information about the mapserver-commits
