[mapserver-commits] r7164 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Dec 12 01:25:38 EST 2007
Author: sdlime
Date: 2007-12-12 01:25:38 -0500 (Wed, 12 Dec 2007)
New Revision: 7164
trunk/mapserver/mapprimitive.c
Fixed a bug in outer ring detection where two rings touch at exactly one point. Affects shapeObj to GML or GEOS geometry conversion in rare cases. (bug 2434)
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2007-12-10 17:29:43 UTC (rev 7163)
+++ trunk/mapserver/mapprimitive.c 2007-12-12 06:25:38 UTC (rev 7164)
@@ -209,13 +209,27 @@
static int isOuterRing(shapeObj *shape, int r)
int i, status=MS_TRUE;
+ int result1, result2;
if(shape->numlines == 1) return(MS_TRUE);
for(i=0; i<shape->numlines; i++) {
if(i == r) continue;
- if(msPointInPolygon(&(shape->line[r].point[0]), &(shape->line[i])) == MS_TRUE)
- status = !status;
+ ** We have to test 2, or perhaps 3 points on the shape against the ring because
+ ** it is possible that at most one point could touch the ring and the function
+ ** msPointInPolygon() is indeterminite in that case. (bug #2434)
+ result1 = msPointInPolygon(&(shape->line[r].point[0]), &(shape->line[i]));
+ result2 = msPointInPolygon(&(shape->line[r].point[1]), &(shape->line[i]));
+ if(result1 == result2) { /* same result twice, neither point was on the edge */
+ if(result1 == MS_TRUE) status = !status;
+ } else { /* one of the first 2 points were on the edge of the ring, the next one isn't */
+ if(msPointInPolygon(&(shape->line[r].point[2]), &(shape->line[i])) == MS_TRUE)
+ status = !status;
return(status);
More information about the mapserver-commits
