[mapserver-commits] r7129 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 30 12:51:26 EST 2007
Author: warmerdam
Date: 2007-11-30 12:51:26 -0500 (Fri, 30 Nov 2007)
New Revision: 7129
trunk/mapserver/mapwcs.c
various fixes in GetCoverage related to different bbox semantics in 1.0/1.1
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2007-11-30 17:49:36 UTC (rev 7128)
+++ trunk/mapserver/mapwcs.c 2007-11-30 17:51:26 UTC (rev 7129)
@@ -340,6 +340,10 @@
msSetError(MS_WMSERR, "Wrong number of arguments for BOUNDINGBOX.", "msWCSParseRequest()");
return msWCSException(map, params->version, "InvalidParameterValue", "boundingbox");
+ /* NOTE: WCS 1.1 boundingbox is center of pixel oriented, not edge
+ like in WCS 1.0. So bbox semantics are wonky till this is fixed
+ later in the GetCoverage processing. */
params->bbox.minx = atof(tokens[0]);
params->bbox.miny = atof(tokens[1]);
params->bbox.maxx = atof(tokens[2]);
@@ -1191,10 +1195,19 @@
/* did we get BBOX values? if not use the exent stored in the coverageMetadataObj */
- if( fabs((params->bbox.maxx - params->bbox.minx)) < 0.000000000001 || fabs(params->bbox.maxy - params->bbox.miny) < 0.000000000001 ) {
- params->bbox = cm.extent;
- /* msSetError( MS_WCSERR, "Required parameter BBOX missing or specifies an empty region.", "msWCSGetCoverage()" ); */
- /* return msWCSException(params->version); */
+ if( fabs((params->bbox.maxx - params->bbox.minx)) < 0.000000000001
+ || fabs(params->bbox.maxy - params->bbox.miny) < 0.000000000001 ) {
+ params->bbox = cm.extent;
+ /* WCS 1.1 boundbox is center of pixel oriented. */
+ if( strncasecmp(params->version,"1.1",3) == 0 )
+ params->bbox.minx += cm.geotransform[1]/2 + cm.geotransform[2]/2;
+ params->bbox.maxx -= cm.geotransform[1]/2 + cm.geotransform[2]/2;
+ params->bbox.miny += cm.geotransform[4]/2 + cm.geotransform[5]/2;
+ params->bbox.maxy -= cm.geotransform[4]/2 + cm.geotransform[5]/2;
/* if necessary, project the BBOX */
@@ -1210,14 +1223,40 @@
/* compute width/height from BBOX and cellsize. */
if( (params->resx == 0.0 || params->resy == 0.0) && params->width != 0 && params->height != 0 ) {
- params->resx = (params->bbox.maxx - params->bbox.minx) / params->width;
- params->resy = (params->bbox.maxy - params->bbox.miny) / params->height;
+ params->resx = (params->bbox.maxx - params->bbox.minx)
+ / (params->width-1);
+ params->resy = (params->bbox.maxy - params->bbox.miny)
+ / (params->height-1);
+ else
+ params->resx = (params->bbox.maxx -params->bbox.minx) / params->width;
+ params->resy = (params->bbox.maxy -params->bbox.miny) / params->height;
/* compute cellsize/res from bbox and raster size. */
if( (params->width == 0 || params->height == 0) && params->resx != 0 && params->resy != 0 ) {
- params->width = (int) ((params->bbox.maxx - params->bbox.minx) / params->resx + 0.5);
- params->height = (int) ((params->bbox.maxy - params->bbox.miny) / params->resy + 0.5);
+ params->width = (int) ((params->bbox.maxx - params->bbox.minx)
+ / params->resx + 1.5);
+ params->height = (int) ((params->bbox.maxy - params->bbox.miny)
+ / params->resy + 1.5);
+ else
+ / params->resx + 0.5);
+ / params->resy + 0.5);
/* are we still underspecified? */
@@ -1259,10 +1298,14 @@
map->height = params->height;
/* adjust OWS BBOX to MapServer's pixel model */
- params->bbox.minx += params->resx*0.5;
- params->bbox.miny += params->resy*0.5;
- params->bbox.maxx -= params->resx*0.5;
- params->bbox.maxy -= params->resy*0.5;
+ if( strncasecmp(params->version,"1.0",3) == 0 )
+ params->bbox.minx += params->resx*0.5;
+ params->bbox.miny += params->resy*0.5;
+ params->bbox.maxx -= params->resx*0.5;
+ params->bbox.maxy -= params->resy*0.5;
map->extent = params->bbox;
map->cellsize = params->resx; /* pick one, MapServer only supports square cells (what about msAdjustExtent here!) */
More information about the mapserver-commits
