[mapserver-commits] r7130 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 30 17:08:04 EST 2007
Author: warmerdam
Date: 2007-11-30 17:08:03 -0500 (Fri, 30 Nov 2007)
New Revision: 7130
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapresample.c
fix RAWMODE multiband average/bilinear (#2364)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2007-11-30 17:51:26 UTC (rev 7129)
+++ trunk/mapserver/HISTORY.TXT 2007-11-30 22:08:03 UTC (rev 7130)
@@ -124,7 +124,10 @@
and is indicated by USE_LIBXML2 definition. Use @ALL_ENABLED@ in
DEFINEs and mapscriptvars generation.
+- mapresample.c: Fixed support for multi-band data in RAW mode for bilinear
+ and nearest neighbour resamplers (#2364).
Version 5.0.0 (2007-09-17)
Modified: trunk/mapserver/mapresample.c
--- trunk/mapserver/mapresample.c 2007-11-30 17:51:26 UTC (rev 7129)
+++ trunk/mapserver/mapresample.c 2007-11-30 22:08:03 UTC (rev 7130)
@@ -597,21 +597,21 @@
psDstImage->img.raw_16bit[
nDstX + nDstY * psDstImage->width
+ band*psDstImage->width*psDstImage->height]
- = (short) padfPixelSum[0];
+ = (short) padfPixelSum[band];
else if( psSrcImage->format->imagemode == MS_IMAGEMODE_FLOAT32)
psDstImage->img.raw_float[
- = (float) padfPixelSum[0];
+ = (float) padfPixelSum[band];
else if( psSrcImage->format->imagemode == MS_IMAGEMODE_BYTE )
psDstImage->img.raw_byte[
- = (unsigned char) padfPixelSum[0];
+ = (unsigned char) padfPixelSum[band];
@@ -863,21 +863,21 @@
More information about the mapserver-commits
