[mapserver-commits] r8209 - in trunk/docs: compilation input input/vector mapfile mapscript mapscript/php
Mon Dec 8 14:59:30 EST 2008
Author: hobu
Date: 2008-12-08 14:59:30 -0500 (Mon, 08 Dec 2008)
New Revision: 8209
Added:
   trunk/docs/compilation/dotnet.txt
Removed:
   trunk/docs/mapscript/dotnet_compile.txt
   trunk/docs/compilation/index.txt
   trunk/docs/input/raster_data.txt
   trunk/docs/input/vector/ogr.txt
   trunk/docs/mapfile/layer.txt
   trunk/docs/mapscript/index.txt
   trunk/docs/mapscript/php/install.txt
reorg a little bit, tweak formatting
Copied: trunk/docs/compilation/dotnet.txt (from rev 8203, trunk/docs/mapscript/dotnet_compile.txt)
--- trunk/docs/compilation/dotnet.txt	                        (rev 0)
+++ trunk/docs/compilation/dotnet.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -0,0 +1,366 @@
+.. _dotnet_compile:
+ .NET MapScript Compilation
+:Author: Tamas Szekerest
+:Contact: szekerest at gmail.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2006/10/11
+Compilation
+Before compiling C# mapscript you should compile mapserver with the options
+for your requirements. For more information about the compilation of
+MapServer please see :ref:`Win32 Compilation and Installation <win32>`. It is highly
+recommended to minimize the library dependency of your application, so when
+compiling mapserver enable only the features really needed. To compile the
+C# binding SWIG 1.3.31 or later is required.
+Win32 compilation targeting the MS.NET framework 1.1
+You should compile mapserver, mapscript and all of the subsequent libraries
+using Visual Studio 2003. Download and uncompress the latest SWIGWIN package
+that contains the precompiled swig.exe Open the Visual Studio .NET 2003
+Command Prompt and step into the /mapscript/csharp directory. Edit makefile.vc
+and set the SWIG variable to the location of your swig.exe
+Use
+    nmake -f makefile.vc
+to compile mapscript.dll and mapscript_csharp.dll.
+Win32 compilation targeting the MS.NET framework 2.0
+using Visual Studio 2005. Download and uncompress the latest SWIGWIN package
+that contains the precompiled swig.exe Open the Visual Studio 2005 Command
+Prompt and step into the /mapscript/csharp directory Edit makefile.vc and set
+the SWIG variable to the location of your swig.exe.
+Use
+Win32 compilation targeting the MONO framework
+Before the compilation you should download and install the recent mono
+Win32 setup package (eg. mono-1.1.13.2-gtksharp-2.8.1-win32-1.exe) Edit makefile.vc
+and set the CSC variable to the location of your mcs.exe. Alternatively
+you can define
+    MONO = YES
+in your nmake.opt file.
+You should use the same compiler for compiling MapScript as the compiler has
+been used for the MapServer compilation. To compile MapScript open the Command
+Prompt supplied with your compiler and use
+Alternative compilation methods on Windows
+Beginning from mapserver 4.8.3 you can invoke the C# compilation from the
+MapServer directory by uncommenting DOT_NET in nmake.opt
+# .NET/C# MapScript
+# .NET will of course only work with MSVC 7.0 and 7.1.  Also note that
+# you will definitely want USE_THREAD defined.
+#DOT_NET = YES
+and invoking the compilation by
+    nmake -f makefile.vc csharp
+You can also use
+    nmake -f makefile.vc install
+for making the compilation an copying the targets into a common output
+directory.
+Testing the compilation
+For testing the compilation and the runtime environment you can use
+      nmake -f makefile.vc test
+within the csharp directory for starting the sample applications compiled
+previously. Before making the test the location of the corresponding libraries
+should be included in the system PATH.
+Linux compilation targeting the MONO framework
+Linux package. Some distributions have pre-compiled binaries to install,
+but for using the latest version you might want to compile and install it
+from the source. Download and uncompress the latest SWIG release. You should
+probably compile it from the source if pre-compiled binaries are not available
+for your platform.
+Before compiling mapscript mapserver should be configured and compiled.
+Beginning from MapServer 4.8.2 during configuration the
+mapscript/csharp/Makefile will be created according to the configuration
+options. Edit this file and set the SWIG and CSC for the corresponding
+executable pathes if the files could not be accessed by default. To
+compile at a console step into the /mapscript/csharp directory use.
+      make
+to compile libmapscript.so and mapscript_csharp.dll.
+      make test
+for starting the sample applications compiled previously.
+OSX compilation targeting the MONO framework
+Beginning from 4.10.0 the csharp/Makefile supports the OSX builds. Before
+making the build the recent MONO package should be installed on the system.
+Beginning from mapserver 4.8.2 during configuration the
+executable pathes if the files could not be accessed by default. To compile
+at a console step into the /mapscript/csharp directory use
+      make
+to compile libmapscript.dylib and mapscript_csharp.dll.
+      make test
+To run the applications mapscript_csharp.dll.config is needed along with the
+mapscript_csharp.dll file. This file is created during the make process
+Installation
+The files required for your application should be manually installed. It is
+highly recommended to copy the files into the same folder as the executable
+resides.
+Known issues
+Visual Studio 2005 requires a manifest file to load the CRT native assembly wrapper
+If you have compiled mapserver for using the CRT libraries and you are using
+the MS.NET framework 2.0 as the execution runtime you should supply a proper
+manifest file along with your executable, like:
+<?xml version="1.0" encoding="utf-8"?>
+<assembly xsi:schemaLocation="urn:schemas-microsoft-com:asm.v1 assembly.adaptive.xsd" manifestVersion="1.0" xmlns:asmv1="urn:schemas-microsoft-com:asm.v1" xmlns:asmv2="urn:schemas-microsoft-com:asm.v2" xmlns:dsig="http://www.w3.org/2000/09/xmldsig#" xmlns="urn:schemas-microsoft-com:asm.v1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
+<assemblyIdentity name="drawmap.exe" version="1.0.0.0" type="win32" />
+<dependency>
+<dependentAssembly asmv2:dependencyType="install" asmv2:codebase="Microsoft.VC80.CRT.manifest" asmv2:size="522">
+<assemblyIdentity name="Microsoft.VC80.CRT" version="8.0.50608.0" publicKeyToken="1fc8b3b9a1e18e3b" processorArchitecture="x86" type="win32" />
+<hash xmlns="urn:schemas-microsoft-com:asm.v2">
+<dsig:Transforms>
+<dsig:Transform Algorithm="urn:schemas-microsoft-com:HashTransforms.Identity" />
+</dsig:Transforms>
+<dsig:DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1" />
+<dsig:DigestValue>UMOlhUBGeKRrrg9DaaPNgyhRjyM=</dsig:DigestValue>
+</hash>
+</dependentAssembly>
+</dependency>
+</assembly>
+This will inform the CLR that your exe depends on the CRT and the proper
+assembly wrapper is to be used. If you are using the IDE the manifest file
+could be pregenerated by adding a reference to Microsoft.VC80.CRT.manifest
+within the /Microsoft Visual Studio 8/VC/redist/x86/Microsoft.VC80.CRT
+directory.
+Manifests for the dll-s must be embedded as a resource
+According to the windows makefile the mapscript compilation target
+(mapscript.dll) is linked with the /MD option. In this case the VS2005
+linker will generate a manifest file containing the unmanaged assembly
+dependency. The sample contents of the manifest file are:
+<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
+<assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
+<dependency>
+<dependentAssembly>
+<assemblyIdentity type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b' />
+</dependency>
+</assembly>
+Like previously mentioned if you are creating a windows application the
+common language runtime will search for a manifest file for the application.
+The name of the manifest file should be the same as the executable append
+and end with the .manifest extension. However if the host process is not
+controlled by you (like web mapping applications using aspnet_wp.exe as
+the host process) you will not be certain if the host process (.exe) will
+have a manifest containing a reference to the CRT wrapper. In this case you
+may have to embed the manifest into the dll as a resource using the mt tool like:
+ mt /manifest mapscript.dll.manifest /outputresource:mapscript.dll;#2
+the common language runtime will search for the embedded resource and load
+the CRT assembly properly.
+Normally it is enough to load the CRT with the root dll (mapscript.dll),
+but it is not harmful embedding the manifest into the dependent libraries as well.
+Issue with regex and Visual Studio 2005
+When compiling with Microsoft Visual Studio 2005 variable name collision
+may occur between regex.c
+and crtdefs.h. For more details see:
+http://trac.osgeo.org/mapserver/ticket/1651
+C# mapscript library name mapping with MONO
+Using the mapscript interface created by the SWIG interface generator the
+communication between the C# wrapper classes (mapscript_csharp.dll) and the
+C code (mapscript.dll) takes place using platform invoke like:
+ [DllImport("mapscript", EntryPoint="CSharp_new_mapObj")]
+ public static extern IntPtr new_mapObj(string jarg1);
+The DllImport declaration contains the library name, however to transform
+the library name into a file name is platform dependent. On Windows the library
+name is simply appended with the .dll extension (mapscript.dll). On the Unix
+systems the library file name normally starts with the lib prefix and appended
+with the .so extension (libmapscript.so).
+Mapping of the library name may be manually controlled using a dll.config
+file. This simply maps the library file the DllImport is looking for to its
+unix equivalent. The file normally contains the following information
+(mapscript_csharp.dll.config):
+<configuration>
+<dllmap dll="mapscript" target="libmapscript.so" />
+</configuration>
+and with the OSX builds:
+<configuration>
+<dllmap dll="mapscript" target="libmapscript.dylib" />
+</configuration>
+The file should be placed along with the corresponding mapscript_csharp.dll
+file, and created by default during the make process. For more information see:
+http://trac.osgeo.org/mapserver/ticket/1596
+http://www.mono-project.com/Interop_with_Native_Libraries
+Localization issues with MONO/Linux
+According to http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1762 MapServer
+may not operate equally well on different locale settings. Especially when the
+decimal separator is other than "." inside the locale of the process may cause
+parse errors when the mapfile contains float numbers. Since the MONO process
+takes over the locale settings of the environment it is worth considering to
+set the default locale to "C" of the host process, like:
+ LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp.png
+Most frequent errors
+This chapter will summarize the most frequent problems the user can run into.
+The issues were collected mainly from the -users list and the IRC.
+Unable to load dll (mapscript)
+You can get this problem on Windows and in most cases it can be dedicated to a
+missing or an unloadable shared library. The error message talks about
+mapscript.dll but surely one or more of the dll-s are missing that libmap.dll
+depends on. So firstly you might want to check for the dependencies of your
+libmap.dll in your application directory. You can use the Visual Studio
+Dependency Walker to accomplish this task. You can also use a file monitoring
+tool (like SysInternal's filemon) to detect the dll-s that could not be loaded.
+I propose to store all of the dll-s required by your application in the
+application folder. If you can run the drawmap C# sample application with
+your mapfile your compilation might be correct and all of the dlls are available.
+You may find that the mapscript C# interface behaves differently for the
+desktop and the ASP.NET applications. Although you can run the drawmap sample
+correctly you may encounter the dll loading problem with the ASP.NET
+applications. When creating an ASP.NET project your application folder will
+be '\Inetpub\wwwroot\[YourApp]\bin' by default. The host process of the
+application will aspnet_wp.exe or w3wp.exe depending on your system. The
+application will run under a different security context than the interactive
+user (under the context of the ASPNET user by default). When placing the
+dll-s outside of your application directory you should consider that the PATH
+environment variable may differ between the interactive and the ASPNET user
+and/or you may not have enough permission to access a dll outside of your
+Bug reports
+If you find a problem dedicated to the mapscript C# interface feel free to
+file a bug report to Trac.
Modified: trunk/docs/compilation/index.txt
--- trunk/docs/compilation/index.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/compilation/index.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -10,4 +10,5 @@
    unix
    win32
+   dotnet
Modified: trunk/docs/input/raster_data.txt
--- trunk/docs/input/raster_data.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/input/raster_data.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -389,8 +389,8 @@
 Special Processing Directives
-As of MapServer 4.0, the PROCESSING parameter was added to the `LAYER object`_
-of the mapfile. It is primariliy used to pass specialized raster processing
+As of MapServer 4.0, the PROCESSING parameter was added to the :ref:`LAYER` of
+the :ref:`mapfile`. It is primarily used to pass specialized raster processing
 options to the GDAL based raster renderer. The following processing options
 are supported in MapServer 4.0 and newer.
@@ -586,7 +586,7 @@
 million which would take on the order of 100MB of RAM.
 Query results can be returned as HTML via the normal substitution into query
-template HTML. Query results are also accessable via WMS GetFeatureInfo calls,
+template HTML. Query results are also accessible via WMS GetFeatureInfo calls,
 and from MapScript. The following example shows executing a feature query from
 Python MapScript and fetching back the results:
@@ -615,7 +615,7 @@
   layer.close()
-This following is a simple example query TEMPLATE file. The raster pixel attributes
+This following is a simple example query :ref:`TEMPLATE <template>` file. The raster pixel attributes
 will be substituted in before the query result is returned to the user as HTML.
Modified: trunk/docs/input/vector/ogr.txt
--- trunk/docs/input/vector/ogr.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/input/vector/ogr.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -316,19 +316,7 @@
 and `MS4W`_). It is an executable that can be used to obtain layer information
 about OGR supported files. The parameters are:
-.. program:: ogrinfo
-.. cmdoption:: -ro
-    opens the file as read only (optional)
-.. cmdoption:: -q
-    executes in quiet mode, only the layer index line will be returned (optional)
-    :option:`ogrinfo -q`
-    ogrinfo [-ro] [-q] datasource_name [layer [layer...]]
+  *ogrinfo* [-ro] [-q] datasource_name [layer [layer...]]
   - -ro opens the file as read only (optional)
Modified: trunk/docs/mapfile/layer.txt
--- trunk/docs/mapfile/layer.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/mapfile/layer.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -355,7 +355,7 @@
     processing directives vary by layer type, and the underlying driver that
     processes them. Here we see the SCALE and BANDs directives used to
     autoscale raster data and alter the band mapping.  All raster processing
-    options are described in the Raster Data Access HOWTO.
+    options are described in :ref:`raster`.
Deleted: trunk/docs/mapscript/dotnet_compile.txt
--- trunk/docs/mapscript/dotnet_compile.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/mapscript/dotnet_compile.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -1,364 +0,0 @@
- .NET MapScript Compilation
-:Author: Tamas Szekerest
-:Contact: szekerest at gmail.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2006/10/11
-Compilation
-Before compiling C# mapscript you should compile mapserver with the options
-for your requirements. For more information about the compilation of
-MapServer please see :ref:`Win32 Compilation and Installation <win32>`. It is highly
-recommended to minimize the library dependency of your application, so when
-compiling mapserver enable only the features really needed. To compile the
-C# binding SWIG 1.3.31 or later is required.
-Win32 compilation targeting the MS.NET framework 1.1
-You should compile mapserver, mapscript and all of the subsequent libraries
-using Visual Studio 2003. Download and uncompress the latest SWIGWIN package
-that contains the precompiled swig.exe Open the Visual Studio .NET 2003
-Command Prompt and step into the /mapscript/csharp directory. Edit makefile.vc
-and set the SWIG variable to the location of your swig.exe
-Use
-    nmake -f makefile.vc
-to compile mapscript.dll and mapscript_csharp.dll.
-Win32 compilation targeting the MS.NET framework 2.0
-using Visual Studio 2005. Download and uncompress the latest SWIGWIN package
-that contains the precompiled swig.exe Open the Visual Studio 2005 Command
-Prompt and step into the /mapscript/csharp directory Edit makefile.vc and set
-the SWIG variable to the location of your swig.exe.
-Use
-Win32 compilation targeting the MONO framework
-Before the compilation you should download and install the recent mono
-Win32 setup package (eg. mono-1.1.13.2-gtksharp-2.8.1-win32-1.exe) Edit makefile.vc
-and set the CSC variable to the location of your mcs.exe. Alternatively
-you can define
-    MONO = YES
-in your nmake.opt file.
-You should use the same compiler for compiling MapScript as the compiler has
-been used for the MapServer compilation. To compile MapScript open the Command
-Prompt supplied with your compiler and use
-Alternative compilation methods on Windows
-Beginning from mapserver 4.8.3 you can invoke the C# compilation from the
-MapServer directory by uncommenting DOT_NET in nmake.opt
-# .NET/C# MapScript
-# .NET will of course only work with MSVC 7.0 and 7.1.  Also note that
-# you will definitely want USE_THREAD defined.
-#DOT_NET = YES
-and invoking the compilation by
-    nmake -f makefile.vc csharp
-You can also use
-    nmake -f makefile.vc install
-for making the compilation an copying the targets into a common output
-directory.
-Testing the compilation
-For testing the compilation and the runtime environment you can use
-      nmake -f makefile.vc test
-within the csharp directory for starting the sample applications compiled
-previously. Before making the test the location of the corresponding libraries
-should be included in the system PATH.
-Linux compilation targeting the MONO framework
-Linux package. Some distributions have pre-compiled binaries to install,
-but for using the latest version you might want to compile and install it
-from the source. Download and uncompress the latest SWIG release. You should
-probably compile it from the source if pre-compiled binaries are not available
-for your platform.
-Before compiling mapscript mapserver should be configured and compiled.
-Beginning from MapServer 4.8.2 during configuration the
-mapscript/csharp/Makefile will be created according to the configuration
-options. Edit this file and set the SWIG and CSC for the corresponding
-executable pathes if the files could not be accessed by default. To
-compile at a console step into the /mapscript/csharp directory use.
-      make
-to compile libmapscript.so and mapscript_csharp.dll.
-      make test
-for starting the sample applications compiled previously.
-OSX compilation targeting the MONO framework
-Beginning from 4.10.0 the csharp/Makefile supports the OSX builds. Before
-making the build the recent MONO package should be installed on the system.
-Beginning from mapserver 4.8.2 during configuration the
-executable pathes if the files could not be accessed by default. To compile
-at a console step into the /mapscript/csharp directory use
-      make
-to compile libmapscript.dylib and mapscript_csharp.dll.
-      make test
-To run the applications mapscript_csharp.dll.config is needed along with the
-mapscript_csharp.dll file. This file is created during the make process
-Installation
-The files required for your application should be manually installed. It is
-highly recommended to copy the files into the same folder as the executable
-resides.
-Known issues
-Visual Studio 2005 requires a manifest file to load the CRT native assembly wrapper
-If you have compiled mapserver for using the CRT libraries and you are using
-the MS.NET framework 2.0 as the execution runtime you should supply a proper
-manifest file along with your executable, like:
-<?xml version="1.0" encoding="utf-8"?>
-<assembly xsi:schemaLocation="urn:schemas-microsoft-com:asm.v1 assembly.adaptive.xsd" manifestVersion="1.0" xmlns:asmv1="urn:schemas-microsoft-com:asm.v1" xmlns:asmv2="urn:schemas-microsoft-com:asm.v2" xmlns:dsig="http://www.w3.org/2000/09/xmldsig#" xmlns="urn:schemas-microsoft-com:asm.v1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
-<assemblyIdentity name="drawmap.exe" version="1.0.0.0" type="win32" />
-<dependency>
-<dependentAssembly asmv2:dependencyType="install" asmv2:codebase="Microsoft.VC80.CRT.manifest" asmv2:size="522">
-<assemblyIdentity name="Microsoft.VC80.CRT" version="8.0.50608.0" publicKeyToken="1fc8b3b9a1e18e3b" processorArchitecture="x86" type="win32" />
-<hash xmlns="urn:schemas-microsoft-com:asm.v2">
-<dsig:Transforms>
-<dsig:Transform Algorithm="urn:schemas-microsoft-com:HashTransforms.Identity" />
-</dsig:Transforms>
-<dsig:DigestMethod Algorithm="http://www.w3.org/2000/09/xmldsig#sha1" />
-<dsig:DigestValue>UMOlhUBGeKRrrg9DaaPNgyhRjyM=</dsig:DigestValue>
-</hash>
-</dependentAssembly>
-</dependency>
-</assembly>
-This will inform the CLR that your exe depends on the CRT and the proper
-assembly wrapper is to be used. If you are using the IDE the manifest file
-could be pregenerated by adding a reference to Microsoft.VC80.CRT.manifest
-within the /Microsoft Visual Studio 8/VC/redist/x86/Microsoft.VC80.CRT
-directory.
-Manifests for the dll-s must be embedded as a resource
-According to the windows makefile the mapscript compilation target
-(mapscript.dll) is linked with the /MD option. In this case the VS2005
-linker will generate a manifest file containing the unmanaged assembly
-dependency. The sample contents of the manifest file are:
-<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
-<assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
-<dependency>
-<dependentAssembly>
-<assemblyIdentity type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b' />
-</dependency>
-</assembly>
-Like previously mentioned if you are creating a windows application the
-common language runtime will search for a manifest file for the application.
-The name of the manifest file should be the same as the executable append
-and end with the .manifest extension. However if the host process is not
-controlled by you (like web mapping applications using aspnet_wp.exe as
-the host process) you will not be certain if the host process (.exe) will
-have a manifest containing a reference to the CRT wrapper. In this case you
-may have to embed the manifest into the dll as a resource using the mt tool like:
- mt /manifest mapscript.dll.manifest /outputresource:mapscript.dll;#2
-the common language runtime will search for the embedded resource and load
-the CRT assembly properly.
-Normally it is enough to load the CRT with the root dll (mapscript.dll),
-but it is not harmful embedding the manifest into the dependent libraries as well.
-Issue with regex and Visual Studio 2005
-When compiling with Microsoft Visual Studio 2005 variable name collision
-may occur between regex.c
-and crtdefs.h. For more details see:
-http://trac.osgeo.org/mapserver/ticket/1651
-C# mapscript library name mapping with MONO
-Using the mapscript interface created by the SWIG interface generator the
-communication between the C# wrapper classes (mapscript_csharp.dll) and the
-C code (mapscript.dll) takes place using platform invoke like:
- [DllImport("mapscript", EntryPoint="CSharp_new_mapObj")]
- public static extern IntPtr new_mapObj(string jarg1);
-The DllImport declaration contains the library name, however to transform
-the library name into a file name is platform dependent. On Windows the library
-name is simply appended with the .dll extension (mapscript.dll). On the Unix
-systems the library file name normally starts with the lib prefix and appended
-with the .so extension (libmapscript.so).
-Mapping of the library name may be manually controlled using a dll.config
-file. This simply maps the library file the DllImport is looking for to its
-unix equivalent. The file normally contains the following information
-(mapscript_csharp.dll.config):
-<configuration>
-<dllmap dll="mapscript" target="libmapscript.so" />
-</configuration>
-and with the OSX builds:
-<configuration>
-<dllmap dll="mapscript" target="libmapscript.dylib" />
-</configuration>
-The file should be placed along with the corresponding mapscript_csharp.dll
-file, and created by default during the make process. For more information see:
-http://trac.osgeo.org/mapserver/ticket/1596
-http://www.mono-project.com/Interop_with_Native_Libraries
-Localization issues with MONO/Linux
-According to http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1762 MapServer
-may not operate equally well on different locale settings. Especially when the
-decimal separator is other than "." inside the locale of the process may cause
-parse errors when the mapfile contains float numbers. Since the MONO process
-takes over the locale settings of the environment it is worth considering to
-set the default locale to "C" of the host process, like:
- LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp.png
-Most frequent errors
-This chapter will summarize the most frequent problems the user can run into.
-The issues were collected mainly from the -users list and the IRC.
-Unable to load dll (mapscript)
-You can get this problem on Windows and in most cases it can be dedicated to a
-missing or an unloadable shared library. The error message talks about
-mapscript.dll but surely one or more of the dll-s are missing that libmap.dll
-depends on. So firstly you might want to check for the dependencies of your
-libmap.dll in your application directory. You can use the Visual Studio
-Dependency Walker to accomplish this task. You can also use a file monitoring
-tool (like SysInternal's filemon) to detect the dll-s that could not be loaded.
-I propose to store all of the dll-s required by your application in the
-application folder. If you can run the drawmap C# sample application with
-your mapfile your compilation might be correct and all of the dlls are available.
-You may find that the mapscript C# interface behaves differently for the
-desktop and the ASP.NET applications. Although you can run the drawmap sample
-correctly you may encounter the dll loading problem with the ASP.NET
-applications. When creating an ASP.NET project your application folder will
-be '\Inetpub\wwwroot\[YourApp]\bin' by default. The host process of the
-application will aspnet_wp.exe or w3wp.exe depending on your system. The
-application will run under a different security context than the interactive
-user (under the context of the ASPNET user by default). When placing the
-dll-s outside of your application directory you should consider that the PATH
-environment variable may differ between the interactive and the ASPNET user
-and/or you may not have enough permission to access a dll outside of your
-Bug reports
-If you find a problem dedicated to the mapscript C# interface feel free to
-file a bug report to Trac.
Modified: trunk/docs/mapscript/index.txt
--- trunk/docs/mapscript/index.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/mapscript/index.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -15,7 +15,6 @@
    introduction
    mapscript
    php/index
-   dotnet_compile
    python
    imagery
    mapfile
Modified: trunk/docs/mapscript/php/install.txt
--- trunk/docs/mapscript/php/install.txt	2008-12-08 15:35:51 UTC (rev 8208)
+++ trunk/docs/mapscript/php/install.txt	2008-12-08 19:59:30 UTC (rev 8209)
@@ -4,7 +4,7 @@
     pair: php; installation
- Installation
+ PHP MapScript Installation
 :Author: Jeff McKenna
