[mapserver-commits] r8210 - in trunk/docs: compilation mapscript/php
Mon Dec 8 15:00:32 EST 2008
Author: hobu
Date: 2008-12-08 15:00:32 -0500 (Mon, 08 Dec 2008)
New Revision: 8210
Added:
   trunk/docs/compilation/php.txt
Removed:
   trunk/docs/mapscript/php/install.txt
   trunk/docs/compilation/index.txt
   trunk/docs/mapscript/php/index.txt
move php install into compilation section
Modified: trunk/docs/compilation/index.txt
--- trunk/docs/compilation/index.txt	2008-12-08 19:59:30 UTC (rev 8209)
+++ trunk/docs/compilation/index.txt	2008-12-08 20:00:32 UTC (rev 8210)
@@ -10,5 +10,6 @@
    unix
    win32
+   php
    dotnet
Copied: trunk/docs/compilation/php.txt (from rev 8209, trunk/docs/mapscript/php/install.txt)
--- trunk/docs/compilation/php.txt	                        (rev 0)
+++ trunk/docs/compilation/php.txt	2008-12-08 20:00:32 UTC (rev 8210)
@@ -0,0 +1,468 @@
+.. _php_install:
+.. index::
+    pair: php; installation
+ PHP MapScript Installation
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Last Updated: 2007/09/11
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+The PHP/MapScript module is a PHP dynamically loadable module that makes
+MapServer's MapScript functions and classes available in a PHP environment.
+The original version of MapScript (in Perl) uses `SWIG`_, but since SWIG does not
+support the PHP language, the module has to be maintained separately and may
+not always be in sync with the Perl version.
+The PHP module was developed and is currently maintained by `DM Solutions Group`_.
+This document assumes that you are already familiar with certain aspects of
+your operating system:
+- For Unix/Linux users, a familiarity with the build environment, notably *make*.
+- For Windows users, some compilation skills if you don't have ready access to
+  a pre-compiled installation and need to compile your own copy of MapServer with
+  the PHP/MapScript module.
+Which version of PHP is supported?
+PHP MapScript was originally developed for PHP-3.0.14 but after MapServer 3.5
+support for PHP3 has been dropped and as of the last update of this document,
+PHP 4.3.11 or more recent was required (PHP5 is well supported).
+The best combinations of MapScript and PHP versions are:
+- MapScript 4.10 with PHP 5.2.1 and up
+- MapScript 4.10 with PHP 4.4.6 and up
+How to Get More Information on the PHP/MapScript Module for MapServer
+- For a list of all classes, properties, and methods available in the module
+  see the :ref:`php`.
+- More information on the PHP/MapScript module can be found on the
+  `PHP/MapScript page`_ on MapTools.org.
+- The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
+  and some php code snippets.
+- Questions regarding the module should be forwarded to the `MapServer mailing list`_.
+Obtaining, Compiling, and Installing PHP and the PHP/MapScript Module
+.. index::
+    pair: php; download
+Download PHP and PHP/MapScript
+- The PHP source or the Win32 binaries can be obtained from the `PHP web site`_.
+- Once you have verified that PHP is installed and is running, you need to get
+  the latest `MapServer source`_ and compile MapServer and the PHP module.
+Setting Up PHP on Your Server
+**Unix**
+- Check if you have PHP already installed (several Linux distributions have it built in).
+- If not, see the PHP manual's "`Installation on Unix systems`_" section.
+**Windows**
+- `MS4W (MapServer For Windows)`_ is a package that contains Apache, PHP, and
+  PHP/MapScript ready to use in a simple zipfile. Several Open Source applications
+  are also available for use in MS4W.
+- Windows users can follow steps in the `Installing Apache, PHP and MySQL on Windows tutorial`_
+  to install Apache and PHP manually on their system.
+- Window users running PWS/IIS can follow `php.net's howto`_ for installing PHP for PWS/IIS 3,
+  PWS 4 or newer, and IIS 4 or newer.
+.. - The SourceForge project `FoxServ`_ also provides a single Windows installer containing
+..  versions of Apache, mySQL, and PHP; however, it appears that the FoxServ
+..  project may be abandonned, so MS4W is recommended.
+.. note::
+    When setting up PHP on Windows, make sure that PHP is configured as a CGI and not
+    as an Apache module because php_mapscript.dll is not thread-safe and does not work
+    as an Apache module (See the `Example Steps of a Full Windows Installation section`_
+    of this document).
+Build/Install the PHP/MapScript Module
+**Building on a Linux Box**
+NOTE: For UNIX users, see the README.CONFIGURE file in the MapServer source, or see the :ref:`unix`.
+- The main MapServer configure script will automatically setup the main makefile
+  to compile php_mapscript.so if you pass the *--with-php=DIR* argument to the configure script.
+- Copy the php_mapscript.so library to your PHP extensions directory, and then
+  use the dl() function to load the module at the beginning of your PHP scripts.
+  See also the PHP function `extension_loaded()`_ to check whether an extension is
+  already loaded.
+- The file *mapscript/php3/examples/phpinfo_mapscript.phtml* will test that the
+  php_mapscript module is properly installed and can be loaded.
+- If you get an error from PHP complaining that it cannot load the library, then
+  make sure that you recompiled and reinstalled PHP with support for dynamic
+  libraries. On RedHat 5.x and 6.x, this means adding "-rdynamic" to the CLDFLAGS
+  in the main PHP3 Makefile after running ./configure Also make sure all directories
+  in the path to the location of php_mapscript.so are at least r-x for the HTTPd user
+  (usually 'nobody'), otherwise dl() may complain that it cannot find the file even
+  if it's there.
+**Building on Windows**
+- For Windows users, it is recommended to look for a precompiled binary for your
+  PHP version on the `MapServer download page`_ or on `MapTools.org`_.
+- If for some reason you really need to compile your own Windows binary then see the
+  README.WIN32 file in the MapServer source (good luck!).
+Installing PHP/MapScript
+Simply copy the file php4_mapscript.dll to your PHP4 extensions directory
+(pathto/php/extensions)
+Using phpinfo()
+To verify that PHP and PHP/MapScript were installed properly, create a '.php' file
+containing the following code and try to access it through your web server:
+    <HTML>
+    <BODY>
+    <?php
+      if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
+        dl("php_mapscript.dll");
+      else
+        dl("php_mapscript.so");
+      phpinfo();
+    </BODY>
+    </HTML>
+If PHP and PHP/MapScript were installed properly, several tables should be
+displayed on your page, and 'MapScript' should be listed in the 'Extensions'
+table.
+Example Steps of a Full Windows Installation
+**Using MS4W (MapServer for Windows)**
+1. Download the latest `MS4W base package`_.
+2. Extract the files in the archive to the root of one of your drives
+   (e.g. C:/ or D:/).
+3. Double-click the file /ms4w/apache-install.bat to install and start the
+   Apache Web server.
+4. In a web browser goto http://127.0.0.1. You should see an MS4W opening page.
+   You are now running PHP, PHP/MapScript, and Apache.
+5. You can now optionally install other applications that are pre-configured
+   for MS4W, which are located on the `MS4W download page`_.
+**Manual Installation Using Apache Server**
+1. Download the `Apache Web Server`_ and extract it to the root of a directory
+   (eg. D:/Apache).
+2. Download `PHP4`_ and extract it to your Apache folder (eg. D:/Apache/PHP4).
+3. Create a temp directory to store MapServer created GIFs. NOTE: This directory
+   is specified in the IMAGEPATH parameter of the WEB Object in the `mapfile`_.
+   For this example we will call the temp directory "ms_tmp" (eg. E:/tmp/ms_tmp).
+4. Locate the file *httpd.conf* in the conf directory of Apache, and open it
+   in a text viewer (eg. TextPad, Emacs, Notepad).
+   In the *Alias* section of this file, add aliases to the ms_tmp folder and any
+   other folder you require (for this example we will use the *msapps* folder):
+      Alias   /ms_tmp/   "path/to/ms_tmp/"
+      Alias   /msapps/   "path/to/msapps/"
+   In the *ScriptAlias* section of this file, add an alias for the PHP4 folder.
+      ScriptAlias    /cgi-php4/     "pathto/apache/php4/"
+   In the *AddType* section of this file, add a type for php4 files.
+      AddType application/x-httpd-php4   .php
+   In the *Action* section of this file, add an action for the php.exe file.
+      Action application/x-httpd-php4    "/cgi-php4/php.exe"
+5. Copy the file *php4.ini-dist* located in your Apache/php4 directory and
+   paste it into your WindowsNT folder (eg. c:/winnt), and then rename this
+   file to *php.ini* in your WindowsNT folder.
+6. If you want specific extensions loaded by default, open the *php.ini* file
+   in a text viewer and uncomment the appropriate extension.
+7. Place the file php_mapscript.dll into your Apache/php4/extensions folder.
+**Installation Using Microsoft's IIS**
+(please see the `MapServer IIS Setup howto`_ for uptodate steps)
+1. Install IIS if required (see the `IIS 4.0 installation procedure`_).
+2. Install PHP and PHP/MapScript (see above).
+3. Open the Internet Service Manager (eg. C/WINNT/system32/inetsrv/inetmgr.exe).
+4. Select the Default web site and create a virtual directory (right click,
+   select New/Virtual directory). For this example we will call the directory
+   *msapps*.
+5. In the Alias field enter *msapps* and click Next.
+6. Enter the path to the root of your application (eg. "c:/msapps") and click Next.
+7. Set the directory permissions and click Finish.
+8. Select the msapps virtual directory previously created and open the directory
+   property sheets (by right clicking and selecting properties) and then click
+   on the Virtual directory tab.
+9. Click on the Configuration button and then click the App Mapping tab.
+10. Click Add and in the Executable box type: *path/to/php4/php.exe %s %s*. You
+    MUST have the *%s %s* on the end, PHP will not function properly if you fail
+    to do this. In the Extension box, type the file name extension to be associated
+    with your PHP scripts. Usual extensions needed to be associated are phtml and php.
+    You must repeat this step for each extension.
+11. Create a temp directory in Explorer to store MapServer created GIFs. NOTE: This
+    directory is specified in the IMAGEPATH parameter of the WEB Object in the `mapfile`_.
+    For this example we will call the temp directory *ms_tmp* (eg. C:/tmp/ms_tmp).
+12. Open the Internet Service Manager again.
+13. Select the Default web site and create a virtual directory called *ms_tmp*
+    (right click, select New/Virtual directory). Set the path to the ms_tmp directory
+    (eg. C:/tmp/ms_tmp) . The directory permissions should at least be set to
+    Read/Write Access.
+FAQ / Common Problems
+Questions Regarding Documentation
+:Q: **Is there any documentation available?**
+:A: The main reference document is the :ref:`php`,
+    which describes all of the current classes, properties and methods
+    associated with the PHP/MapScript module.
+    To get a more complete description of each class and the meaning of
+    their member variables, see the :ref:`mapscript`
+    and the :ref:`mapfile`.
+    The `MapServer Wiki`_ also has PHP/MapScript build and installation
+    notes and some php code snippets.
+:Q: **Where can I find sample scripts?**
+:A: Some examples are included in directory *mapserver/mapscript/php3/examples/*
+    in the MapServer source distribution. A good one to get started is
+    *test_draw_map.phtml*: it's a very simple script that just draws a map,
+    legend and scalebar in an HTML page.
+    A good intermediate example is the :ref:`php_example`
+    (note that this document was created for an earlier MapServer version
+    but the code might be still useful).
+    The next example is the `GMap demo`_. You can download the whole source and
+    data files from the `MapTools.org download page`_.
+Questions About Installation
+:Q: **How can I tell that the module is properly installed on my server?**
+:A: Create a file called phpinfo.phtml with the following contents:
+       <?php  dl("php_mapscript.so");
+              phpinfo();
+    Make sure you replace the php_mapscript.so with the name under which you
+    installed it, it could be php_mapscript_46.so on Unix, or php_mapscript_46.dll
+    on Windows
+    You can then try the second test page *mapserver/mapscript/php3/examples/test_draw_map.phtml*.
+    This page simply opens a MapServer .map file and inserts its map, legend,
+    and scalebar in an HTML page. Modify the page to access one of your own
+    MapServer .map files, and if you get the expected result, then everything
+    is probably working fine.
+:Q: **I try to display my .phtml or .php page in my browser but the page is
+    shown as it would it Notepad.**
+:A: The problem is that your PHP installation does not recognize ".phtml"
+    as a PHP file extension. Assuming you're using PHP4 under Apache then you
+    need to add the following line with the other PHP-related AddType
+    lines in the httpd.conf:
+       AddType application/x-httpd-php .phtml
+    For a more detailed explanation, see the `Example Steps of a Full Windows Installation section`_
+    section of this document.
+:Q: **I installed the PROJ.4, GDAL, or one of the support libraries on my system,
+    it is recognized by MapServer's "configure" as a system lib but at runtime
+    I get an error: "libproj.so.0: No such file or directory".**
+:A: You are probably running a RedHat Linux system if this happened to you.
+    This happens because the libraries install themselves under /usr/local/lib
+    but this directory is not part of the runtime library path by default on
+    your system.
+    (I'm still surprised that "configure" picked proj.4 as a system lib since
+    it's not in the system's lib path...probably something magic in autoconf
+    that we'll have to look into)
+    There are a couple of possible solutions:
+    1. Add a "setenv LD_LIBRARY_PATH" to your httpd.conf to contain that directory
+    2. Edit /etc/ld.so.conf to add /usr/local/lib, and then run "/sbin/ldconfig".
+       This will permanently add /usr/local/lib to your system's runtime lib path.
+    3. Configure MapServer with the following options:
+           --with-proj=/usr/local --enable-runpath
+       and the /usr/local/lib directory will be hardcoded in the exe and .so files
+    I (Daniel Morissette) personally prefer option #2 because it is permanent
+    and applies to everything running on your system.
+:Q: **Does PHP/MapScript have to be setup as a CGI? If so, why?**
+:A: Yes, please see the `PHP/MapScript CGI page`_ in the Mapserver Wiki for details.
+:Q: **I have compiled PHP as a CGI and when PHP tries to load the php_mapscript.so,
+    I get an "undefined symbol: _register_list_destructors" error. What's wrong?**
+:A: Your PHP CGI executable is probably not linked to support loading shared libraries.
+    The MapServer configure script must have given you a message about a flag to add
+    to the PHP Makefile to enable shared libs.
+    Edit the main PHP Makefile and add "-rdynamic" to the LDFLAGS at the top of the
+    Makefile, then relink your PHP executable.
+    **Note:** The actual parameter to add to LDFLAGS may vary depending on the system
+    you're running on. On Linux it is "-rdynamic", and on \*BSD it is "-export-dynamic".
+:Q: **What are the best combinations of MapScript and PHP versions?**
+:A: The best combinations are:
+    - MapScript 4.10 with PHP 5.2.1 and up
+    - MapScript 4.10 with PHP 4.4.6 and up
+:Q: **I am dynamically loading gd.so and php_mapscript.so and running into problems, why?**
+:A: The source of the problems could be a mismatch of GD versions. The PHP GD module compiles
+    its own version of libgd, and if the GD library is loaded before the mapscript library,
+    mapscript will use the php-specific version.  Wherever possible you should use a gd.so
+    built with the same GD as PHPMapScript.  A workaround is to load the php_mapscript
+    module before the GD module.
+.. #### rST Link Section ####
+.. _`SWIG`: http://www.swig.org/
+.. _`DM Solutions Group`: http://www.dmsolutions.ca/
+.. _`PHP/MapScript page`: http://www.maptools.org/php_mapscript/
+.. _`MapServer Wiki`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
+.. _`MapServer mailing list`: http://mapserver.gis.umn.edu/community/mailinglists/
+.. _`PHP web site`: http://www.php.net/
+.. _`MapServer source`: http://mapserver.gis.umn.edu/download
+.. _`Installation on Unix systems`: http://php.net/manual/en/install.unix.php
+.. _`MS4W (MapServer For Windows)`: http://www.maptools.org/ms4w/
+.. _`Installing Apache, PHP and MySQL on Windows tutorial`: http://www.php-mysql-tutorial.com/install-apache-php-mysql.php
+.. _`php.net's howto`: http://www.php.net/manual/en/install.iis.php
+.. _`Example Steps of a Full Windows Installation section`: http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#example-steps-of-a-full-windows-installation
+.. _`extension_loaded()`: http://www.php.net/manual/en/function.extension-loaded.php
+.. _`MapServer download page`: http://mapserver.gis.umn.edu/download/current/windows/
+.. _`MapTools.org`: http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html
+.. _`MS4W base package`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
+.. _`MS4W download page`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
+.. _`Apache Web Server`: http://httpd.apache.org/
+.. _`PHP4`: http://www.php.net/
+.. _`IIS 4.0 installation procedure`: http://support.microsoft.com/support/iis/install/install_iis4.asp
+.. _`MapServer IIS Setup howto`: http://mapserver.gis.umn.edu/docs/howto/setupiis
+.. _`MapTools.org download page`: http://www.maptools.org/dl/
+.. _`GMap demo`: http://www.mapsherpa.com/gmap/
+.. _`PHP/MapScript CGI page`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
Modified: trunk/docs/mapscript/php/index.txt
--- trunk/docs/mapscript/php/index.txt	2008-12-08 19:59:30 UTC (rev 8209)
+++ trunk/docs/mapscript/php/index.txt	2008-12-08 20:00:32 UTC (rev 8210)
@@ -15,7 +15,6 @@
 .. toctree::
    :maxdepth: 2
-   install
    class-intro
    by_example
Deleted: trunk/docs/mapscript/php/install.txt
--- trunk/docs/mapscript/php/install.txt	2008-12-08 19:59:30 UTC (rev 8209)
+++ trunk/docs/mapscript/php/install.txt	2008-12-08 20:00:32 UTC (rev 8210)
@@ -1,468 +0,0 @@
-.. _php_install:
-.. index::
-    pair: php; installation
- PHP MapScript Installation
-:Author: Jeff McKenna
-:Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2007/09/11
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-Introduction
-The PHP/MapScript module is a PHP dynamically loadable module that makes
-MapServer's MapScript functions and classes available in a PHP environment.
-The original version of MapScript (in Perl) uses `SWIG`_, but since SWIG does not
-support the PHP language, the module has to be maintained separately and may
-not always be in sync with the Perl version.
-The PHP module was developed and is currently maintained by `DM Solutions Group`_.
-This document assumes that you are already familiar with certain aspects of
-your operating system:
-- For Unix/Linux users, a familiarity with the build environment, notably *make*.
-- For Windows users, some compilation skills if you don't have ready access to
-  a pre-compiled installation and need to compile your own copy of MapServer with
-  the PHP/MapScript module.
-Which version of PHP is supported?
-PHP MapScript was originally developed for PHP-3.0.14 but after MapServer 3.5
-support for PHP3 has been dropped and as of the last update of this document,
-PHP 4.3.11 or more recent was required (PHP5 is well supported).
-The best combinations of MapScript and PHP versions are:
-- MapScript 4.10 with PHP 5.2.1 and up
-- MapScript 4.10 with PHP 4.4.6 and up
-How to Get More Information on the PHP/MapScript Module for MapServer
-- For a list of all classes, properties, and methods available in the module
-  see the :ref:`php`.
-- More information on the PHP/MapScript module can be found on the
-  `PHP/MapScript page`_ on MapTools.org.
-- The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
-  and some php code snippets.
-- Questions regarding the module should be forwarded to the `MapServer mailing list`_.
-Obtaining, Compiling, and Installing PHP and the PHP/MapScript Module
-.. index::
-    pair: php; download
-Download PHP and PHP/MapScript
-- The PHP source or the Win32 binaries can be obtained from the `PHP web site`_.
-- Once you have verified that PHP is installed and is running, you need to get
-  the latest `MapServer source`_ and compile MapServer and the PHP module.
-Setting Up PHP on Your Server
-**Unix**
-- Check if you have PHP already installed (several Linux distributions have it built in).
-- If not, see the PHP manual's "`Installation on Unix systems`_" section.
-**Windows**
-- `MS4W (MapServer For Windows)`_ is a package that contains Apache, PHP, and
-  PHP/MapScript ready to use in a simple zipfile. Several Open Source applications
-  are also available for use in MS4W.
-- Windows users can follow steps in the `Installing Apache, PHP and MySQL on Windows tutorial`_
-  to install Apache and PHP manually on their system.
-- Window users running PWS/IIS can follow `php.net's howto`_ for installing PHP for PWS/IIS 3,
-  PWS 4 or newer, and IIS 4 or newer.
-.. - The SourceForge project `FoxServ`_ also provides a single Windows installer containing
-..  versions of Apache, mySQL, and PHP; however, it appears that the FoxServ
-..  project may be abandonned, so MS4W is recommended.
-.. note::
-    When setting up PHP on Windows, make sure that PHP is configured as a CGI and not
-    as an Apache module because php_mapscript.dll is not thread-safe and does not work
-    as an Apache module (See the `Example Steps of a Full Windows Installation section`_
-    of this document).
-Build/Install the PHP/MapScript Module
-**Building on a Linux Box**
-NOTE: For UNIX users, see the README.CONFIGURE file in the MapServer source, or see the :ref:`unix`.
-- The main MapServer configure script will automatically setup the main makefile
-  to compile php_mapscript.so if you pass the *--with-php=DIR* argument to the configure script.
-- Copy the php_mapscript.so library to your PHP extensions directory, and then
-  use the dl() function to load the module at the beginning of your PHP scripts.
-  See also the PHP function `extension_loaded()`_ to check whether an extension is
-  already loaded.
-- The file *mapscript/php3/examples/phpinfo_mapscript.phtml* will test that the
-  php_mapscript module is properly installed and can be loaded.
-- If you get an error from PHP complaining that it cannot load the library, then
-  make sure that you recompiled and reinstalled PHP with support for dynamic
-  libraries. On RedHat 5.x and 6.x, this means adding "-rdynamic" to the CLDFLAGS
-  in the main PHP3 Makefile after running ./configure Also make sure all directories
-  in the path to the location of php_mapscript.so are at least r-x for the HTTPd user
-  (usually 'nobody'), otherwise dl() may complain that it cannot find the file even
-  if it's there.
-**Building on Windows**
-- For Windows users, it is recommended to look for a precompiled binary for your
-  PHP version on the `MapServer download page`_ or on `MapTools.org`_.
-- If for some reason you really need to compile your own Windows binary then see the
-  README.WIN32 file in the MapServer source (good luck!).
-Installing PHP/MapScript
-Simply copy the file php4_mapscript.dll to your PHP4 extensions directory
-(pathto/php/extensions)
-Using phpinfo()
-To verify that PHP and PHP/MapScript were installed properly, create a '.php' file
-containing the following code and try to access it through your web server:
-    <HTML>
-    <BODY>
-    <?php
-      if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
-        dl("php_mapscript.dll");
-      else
-        dl("php_mapscript.so");
-      phpinfo();
-    </BODY>
-    </HTML>
-If PHP and PHP/MapScript were installed properly, several tables should be
-displayed on your page, and 'MapScript' should be listed in the 'Extensions'
-table.
-Example Steps of a Full Windows Installation
-**Using MS4W (MapServer for Windows)**
-1. Download the latest `MS4W base package`_.
-2. Extract the files in the archive to the root of one of your drives
-   (e.g. C:/ or D:/).
-3. Double-click the file /ms4w/apache-install.bat to install and start the
-   Apache Web server.
-4. In a web browser goto http://127.0.0.1. You should see an MS4W opening page.
-   You are now running PHP, PHP/MapScript, and Apache.
-5. You can now optionally install other applications that are pre-configured
-   for MS4W, which are located on the `MS4W download page`_.
-**Manual Installation Using Apache Server**
-1. Download the `Apache Web Server`_ and extract it to the root of a directory
-   (eg. D:/Apache).
-2. Download `PHP4`_ and extract it to your Apache folder (eg. D:/Apache/PHP4).
-3. Create a temp directory to store MapServer created GIFs. NOTE: This directory
-   is specified in the IMAGEPATH parameter of the WEB Object in the `mapfile`_.
-   For this example we will call the temp directory "ms_tmp" (eg. E:/tmp/ms_tmp).
-4. Locate the file *httpd.conf* in the conf directory of Apache, and open it
-   in a text viewer (eg. TextPad, Emacs, Notepad).
-   In the *Alias* section of this file, add aliases to the ms_tmp folder and any
-   other folder you require (for this example we will use the *msapps* folder):
-      Alias   /ms_tmp/   "path/to/ms_tmp/"
-      Alias   /msapps/   "path/to/msapps/"
-   In the *ScriptAlias* section of this file, add an alias for the PHP4 folder.
-      ScriptAlias    /cgi-php4/     "pathto/apache/php4/"
-   In the *AddType* section of this file, add a type for php4 files.
-      AddType application/x-httpd-php4   .php
-   In the *Action* section of this file, add an action for the php.exe file.
-      Action application/x-httpd-php4    "/cgi-php4/php.exe"
-5. Copy the file *php4.ini-dist* located in your Apache/php4 directory and
-   paste it into your WindowsNT folder (eg. c:/winnt), and then rename this
-   file to *php.ini* in your WindowsNT folder.
-6. If you want specific extensions loaded by default, open the *php.ini* file
-   in a text viewer and uncomment the appropriate extension.
-7. Place the file php_mapscript.dll into your Apache/php4/extensions folder.
-**Installation Using Microsoft's IIS**
-(please see the `MapServer IIS Setup howto`_ for uptodate steps)
-1. Install IIS if required (see the `IIS 4.0 installation procedure`_).
-2. Install PHP and PHP/MapScript (see above).
-3. Open the Internet Service Manager (eg. C/WINNT/system32/inetsrv/inetmgr.exe).
-4. Select the Default web site and create a virtual directory (right click,
-   select New/Virtual directory). For this example we will call the directory
-   *msapps*.
-5. In the Alias field enter *msapps* and click Next.
-6. Enter the path to the root of your application (eg. "c:/msapps") and click Next.
-7. Set the directory permissions and click Finish.
-8. Select the msapps virtual directory previously created and open the directory
-   property sheets (by right clicking and selecting properties) and then click
-   on the Virtual directory tab.
-9. Click on the Configuration button and then click the App Mapping tab.
-10. Click Add and in the Executable box type: *path/to/php4/php.exe %s %s*. You
-    MUST have the *%s %s* on the end, PHP will not function properly if you fail
-    to do this. In the Extension box, type the file name extension to be associated
-    with your PHP scripts. Usual extensions needed to be associated are phtml and php.
-    You must repeat this step for each extension.
-11. Create a temp directory in Explorer to store MapServer created GIFs. NOTE: This
-    directory is specified in the IMAGEPATH parameter of the WEB Object in the `mapfile`_.
-    For this example we will call the temp directory *ms_tmp* (eg. C:/tmp/ms_tmp).
-12. Open the Internet Service Manager again.
-13. Select the Default web site and create a virtual directory called *ms_tmp*
-    (right click, select New/Virtual directory). Set the path to the ms_tmp directory
-    (eg. C:/tmp/ms_tmp) . The directory permissions should at least be set to
-    Read/Write Access.
-FAQ / Common Problems
-Questions Regarding Documentation
-:Q: **Is there any documentation available?**
-:A: The main reference document is the :ref:`php`,
-    which describes all of the current classes, properties and methods
-    associated with the PHP/MapScript module.
-    To get a more complete description of each class and the meaning of
-    their member variables, see the :ref:`mapscript`
-    and the :ref:`mapfile`.
-    The `MapServer Wiki`_ also has PHP/MapScript build and installation
-    notes and some php code snippets.
-:Q: **Where can I find sample scripts?**
-:A: Some examples are included in directory *mapserver/mapscript/php3/examples/*
-    in the MapServer source distribution. A good one to get started is
-    *test_draw_map.phtml*: it's a very simple script that just draws a map,
-    legend and scalebar in an HTML page.
-    A good intermediate example is the :ref:`php_example`
-    (note that this document was created for an earlier MapServer version
-    but the code might be still useful).
-    The next example is the `GMap demo`_. You can download the whole source and
-    data files from the `MapTools.org download page`_.
-Questions About Installation
-:Q: **How can I tell that the module is properly installed on my server?**
-:A: Create a file called phpinfo.phtml with the following contents:
-       <?php  dl("php_mapscript.so");
-              phpinfo();
-    Make sure you replace the php_mapscript.so with the name under which you
-    installed it, it could be php_mapscript_46.so on Unix, or php_mapscript_46.dll
-    on Windows
-    You can then try the second test page *mapserver/mapscript/php3/examples/test_draw_map.phtml*.
-    This page simply opens a MapServer .map file and inserts its map, legend,
-    and scalebar in an HTML page. Modify the page to access one of your own
-    MapServer .map files, and if you get the expected result, then everything
-    is probably working fine.
-:Q: **I try to display my .phtml or .php page in my browser but the page is
-    shown as it would it Notepad.**
-:A: The problem is that your PHP installation does not recognize ".phtml"
-    as a PHP file extension. Assuming you're using PHP4 under Apache then you
-    need to add the following line with the other PHP-related AddType
-    lines in the httpd.conf:
-       AddType application/x-httpd-php .phtml
-    For a more detailed explanation, see the `Example Steps of a Full Windows Installation section`_
-    section of this document.
-:Q: **I installed the PROJ.4, GDAL, or one of the support libraries on my system,
-    it is recognized by MapServer's "configure" as a system lib but at runtime
-    I get an error: "libproj.so.0: No such file or directory".**
-:A: You are probably running a RedHat Linux system if this happened to you.
-    This happens because the libraries install themselves under /usr/local/lib
-    but this directory is not part of the runtime library path by default on
-    your system.
-    (I'm still surprised that "configure" picked proj.4 as a system lib since
-    it's not in the system's lib path...probably something magic in autoconf
-    that we'll have to look into)
-    There are a couple of possible solutions:
-    1. Add a "setenv LD_LIBRARY_PATH" to your httpd.conf to contain that directory
-    2. Edit /etc/ld.so.conf to add /usr/local/lib, and then run "/sbin/ldconfig".
-       This will permanently add /usr/local/lib to your system's runtime lib path.
-    3. Configure MapServer with the following options:
-           --with-proj=/usr/local --enable-runpath
-       and the /usr/local/lib directory will be hardcoded in the exe and .so files
-    I (Daniel Morissette) personally prefer option #2 because it is permanent
-    and applies to everything running on your system.
-:Q: **Does PHP/MapScript have to be setup as a CGI? If so, why?**
-:A: Yes, please see the `PHP/MapScript CGI page`_ in the Mapserver Wiki for details.
-:Q: **I have compiled PHP as a CGI and when PHP tries to load the php_mapscript.so,
-    I get an "undefined symbol: _register_list_destructors" error. What's wrong?**
-:A: Your PHP CGI executable is probably not linked to support loading shared libraries.
-    The MapServer configure script must have given you a message about a flag to add
-    to the PHP Makefile to enable shared libs.
-    Edit the main PHP Makefile and add "-rdynamic" to the LDFLAGS at the top of the
-    Makefile, then relink your PHP executable.
-    **Note:** The actual parameter to add to LDFLAGS may vary depending on the system
-    you're running on. On Linux it is "-rdynamic", and on \*BSD it is "-export-dynamic".
-:Q: **What are the best combinations of MapScript and PHP versions?**
-:A: The best combinations are:
-    - MapScript 4.10 with PHP 5.2.1 and up
-    - MapScript 4.10 with PHP 4.4.6 and up
-:Q: **I am dynamically loading gd.so and php_mapscript.so and running into problems, why?**
-:A: The source of the problems could be a mismatch of GD versions. The PHP GD module compiles
-    its own version of libgd, and if the GD library is loaded before the mapscript library,
-    mapscript will use the php-specific version.  Wherever possible you should use a gd.so
-    built with the same GD as PHPMapScript.  A workaround is to load the php_mapscript
-    module before the GD module.
-.. #### rST Link Section ####
-.. _`SWIG`: http://www.swig.org/
-.. _`DM Solutions Group`: http://www.dmsolutions.ca/
-.. _`PHP/MapScript page`: http://www.maptools.org/php_mapscript/
-.. _`MapServer Wiki`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
-.. _`MapServer mailing list`: http://mapserver.gis.umn.edu/community/mailinglists/
-.. _`PHP web site`: http://www.php.net/
-.. _`MapServer source`: http://mapserver.gis.umn.edu/download
-.. _`Installation on Unix systems`: http://php.net/manual/en/install.unix.php
-.. _`MS4W (MapServer For Windows)`: http://www.maptools.org/ms4w/
-.. _`Installing Apache, PHP and MySQL on Windows tutorial`: http://www.php-mysql-tutorial.com/install-apache-php-mysql.php
-.. _`php.net's howto`: http://www.php.net/manual/en/install.iis.php
-.. _`Example Steps of a Full Windows Installation section`: http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#example-steps-of-a-full-windows-installation
-.. _`extension_loaded()`: http://www.php.net/manual/en/function.extension-loaded.php
-.. _`MapServer download page`: http://mapserver.gis.umn.edu/download/current/windows/
-.. _`MapTools.org`: http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html
-.. _`MS4W base package`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
-.. _`MS4W download page`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
-.. _`Apache Web Server`: http://httpd.apache.org/
-.. _`PHP4`: http://www.php.net/
-.. _`IIS 4.0 installation procedure`: http://support.microsoft.com/support/iis/install/install_iis4.asp
-.. _`MapServer IIS Setup howto`: http://mapserver.gis.umn.edu/docs/howto/setupiis
-.. _`MapTools.org download page`: http://www.maptools.org/dl/
-.. _`GMap demo`: http://www.mapsherpa.com/gmap/
-.. _`PHP/MapScript CGI page`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
