[mapserver-commits] r8224 - trunk/docs/howto
Tue Dec 9 20:23:12 EST 2008
Author: hobu
Date: 2008-12-09 20:23:11 -0500 (Tue, 09 Dec 2008)
New Revision: 8224
   trunk/docs/howto/setupiis.txt
convert to ReST
Modified: trunk/docs/howto/setupiis.txt
--- trunk/docs/howto/setupiis.txt	2008-12-09 21:12:22 UTC (rev 8223)
+++ trunk/docs/howto/setupiis.txt	2008-12-10 01:23:11 UTC (rev 8224)
@@ -1,68 +1,156 @@
-Windows 2000<br>
-IIS 5.0<br>
-MS4W 1.2.1<br>
-Chameleon 2.2<br>
-PHP 4.3.11<br>
-MapServer 4.7<br>
-PhpPgAdmin 3.5.4 (if using postgresql/postgis)<br>
-Postgres 8.0.3 (if using postgresql/postgis)<br>
-Postgis 1.0.3 (if using postgresql/postgis)<br>
-<br>
+.. _iis:
+ IIS Setup for MapServer
+:Author: Debbie Paqurek
+:Last Updated: 2005/12/12
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+.. index:: IIS, php, cgi
+Some help on how to set up MapServer/Chameleon/PhpPgAdmin on Microsoft IIS
+(v5.0). Contains note on changes to the php.ini file and necessary changes to
+the MapServer mapfiles. Please contribute or make changes as required.
+Base configuration
+* Windows 2000
+* IIS 5.0
+* MS4W 1.2.1
+* Chameleon 2.2
+* PHP 4.3.11
+* MapServer 4.7
+* PhpPgAdmin 3.5.4 (if using postgresql/postgis)
+* Postgres 8.0.3 (if using postgresql/postgis)
+* Postgis 1.0.3 (if using postgresql/postgis)
 This setup assumes that MS4W was unzipped to form c:\ms4w\ directory.<br>
-<h4>Php.ini file:</h4>
-<ul>
-<li>session.save_path (absolute path to your tmp directory)</li>
-<li>extension_dir (relative path to your php/extensions directory)</li>
-<li>cgi.force_redirect = 0</li>
-<li>enable the pg_sql extension (php_pgsql.dll) (for Postgresql)</li>
-</ul>
+Php.ini file
-<h4>Internet Services Manager</h4>
-Under your website tree, create a new website (e.g. msprojects). View the properties for the new website.
-<ul>
-<li><strong>Web Site Tab:</strong> set the IP address and under the Advanced tab put the complete Host Header name (e.g.msprojects.gc.ca).</li>
-<li><strong>Home Directory Tab:</strong></li>
--content should come from: A directory located on this computer.<br>
--Local Path: c:\ms4w\Apache\htdocs<br>
--Read access + whatever else you need<br>
--Execute Permissions: Scripts only<br>
--Configuration button - App Mappings (Add extensions .php and .phtml, Executable is c:\ms4w\Apache\cgi-bin\php.exe,select All verbs, Script Engine, and check that file exists<br>
-<li><strong>Documents Tab:</strong> Add index.phtml and index.html</li>
-<li><strong>Directory Security Tab:</strong> Anonymous access amd authentication control: Select Anonymous access and the edit button should indicate the IUSR_ account</li>
-<li><strong>Server Extensions Tab:</strong> Enable authoring is selected and client scripting says Javascript</li>
-</ul>
+* session.save_path (absolute path to your tmp directory)
+* extension_dir (relative path to your php/extensions directory)
+* cgi.force_redirect = 0</li>
+* enable the pg_sql extension (php_pgsql.dll) (for Postgresql)
+Internet Services Manager
+Under your website tree, create a new website (e.g. msprojects). View the
+properties for the new website.
+Web Site Tab
+    * set the IP address and under the Advanced tab put the complete Host
+      Header name (e.g.msprojects.gc.ca).
+Home Directory Tab
+    - content should come from: A directory located on this computer.
+    - Local Path: c:\ms4w\Apache\htdocs
+    - Read access + whatever else you need
+    - Execute Permissions: Scripts only
+    - Configuration button - App Mappings (Add extensions .php and .phtml,
+      Executable is c:\ms4w\Apache\cgi-bin\php.exe,select All verbs, Script
+      Engine, and check that file exists<br>
+Documents Tab
+    * Add index.phtml and index.html
+    * Directory Security Tab
+        - Anonymous access amd authentication control
+        - Select Anonymous access and the edit button should indicate the
+          IUSR_ account
+Server Extensions Tab
+    * Enable authoring is selected and client scripting says Javascript
-<h4>Under the tree for your new website - add virtual directories for:</h4>
-<ul>
-<li><strong>cgi-bin</strong> - under Properties, virtual directory tab Local Path should point to c:\ms4w\apache\cgi-bin. Select Read. Execute Permissions should say "scripts and executables"</li>
-<li><strong>ms_tmp</strong> - Under Properties, virtual directory tab Local Path should point to c:\ms4w\tmp\ms_tmp. Select Read, Write. Execute Permissions should say "scripts only". This is where temporary images are written to so in the File system Security tab (use windows explorer), the c:\ms4w\tmp\ms_tmp directory should have permissions set for the Internet Guest Accounnt (Read and execute, Read, Write, List Folder Contents).</li>
-<li><strong>tmp</strong> -Under Properties, virtual directory tab Local Path should point to c:\ms4w\tmp. Select Read, Write. Execute Permissions should say "scripts only". This is where chameleon writes sessions to so in the File system Security tab (use windows explorer), the c:\ms4w\tmp directory should have permissions set for the Internet Guest Accounnt (Read and execute, Read, Write, List Folder Contents).</li>
-<li><strong>chameleon</strong> -Under Properties, virtual directory tab Local Path should point to C:\ms4w\apps\chameleon\htdocs. Select Read. Execute Permissions should say "scripts only".
-	Under the Chameleon tree, you can add virtual directories for admin (c:\ms4w\apps\chameleon\admin\htdocs), samples (c:\ms4w\apps\chameleon\samples\htdocs), cwc2 (c:\ms4w\apps\chameleon\cwc2\htdocs)</li>
-<li><strong>phppgadmin</strong> - (if using postgresql/postgis) Under Properties, virtual directory tab Local Path should point to C:\ms4w\Apache\htdocs\phpPgAdmin. Select Read, Write. Execute Permissions should say "scripts and executables". Under Documents - add index.php.
-	Please note that We had to unzip the phppgadmin package into this directory in order to get phppgadmin to show us the login page at http://yourserver/phppgadmin/index.php. You might want additional security on this directory.</li>
-<li><strong>gmap</strong> -Good for testing purposes. Remember to change your mapfiles as discussed in Mapfiles for IIS below. Under Properties, virtual directory tab Local Path should point to C:\ms4w\apps\gmap\htdocs. Select Read. Execute Permissions should say "scripts only".</li>
-</ul>
+Under the tree for your new website - add virtual directories for
+cgi-bin
+    Under Properties, virtual directory tab Local Path should point to
+    c:\ms4w\apache\cgi-bin. Select Read. Execute Permissions should say
+    "scripts and executables"
+ms_tmp
+    c:\ms4w\tmp\ms_tmp. Select Read, Write. Execute Permissions should say
+    "scripts only". This is where temporary images are written to so in the
+    File system Security tab (use windows explorer), the c:\ms4w\tmp\ms_tmp
+    directory should have permissions set for the Internet Guest Account
+    (Read and execute, Read, Write, List Folder Contents).
+tmp
+    c:\ms4w\tmp. Select Read, Write. Execute Permissions should say "scripts
+    only". This is where chameleon writes sessions to so in the File system
+    Security tab (use windows explorer), the c:\ms4w\tmp directory should have
+    permissions set for the Internet Guest Accounnt (Read and execute, Read,
+    Write, List Folder Contents).
+chameleon
+    C:\ms4w\apps\chameleon\htdocs. Select Read. Execute Permissions should say
+    "scripts only".
+	Under the Chameleon tree, you can add virtual directories for admin
+    (c:\ms4w\apps\chameleon\admin\htdocs), samples
+    (c:\ms4w\apps\chameleon\samples\htdocs), cwc2
+    (c:\ms4w\apps\chameleon\cwc2\htdocs)
+phppgadmin
+    (if using postgresql/postgis) Under Properties, virtual directory tab
+    Local Path should point to C:\ms4w\Apache\htdocs\phpPgAdmin. Select Read,
+    Write. Execute Permissions should say "scripts and executables". Under
+    Documents - add index.php.
+	Please note that We had to unzip the phppgadmin package into this directory
+    in order to get phppgadmin to show us the login page at
+    http://yourserver/phppgadmin/index.php. You might want additional security on
+    this directory.
+gmap
+    Good for testing purposes. Remember to change your mapfiles as discussed
+    in Mapfiles for IIS below. Under Properties, virtual directory tab Local
+    Path should point to C:\ms4w\apps\gmap\htdocs. Select Read. Execute
+    Permissions should say "scripts only".
-<h4>Test PHP:</h4>
-In a command line window, navigate to c:\ms4w\apache\cgi-bin and run php -i. This should return the output that the phpinfo() function returns. I got an error about how it couldn't find ntwdblib.dll. I found this in c:\ms4w\apache\php\dlls and I copied it to the cgi-bin directory.
+Test PHP
-<h4>Mapfiles for IIS:</h4>
-<ul>
-<li>Add a config line to the MAP level of the mapfile:<br>
-CONFIG PROJ_LIB "path/to/proj/nad/"<br>
-e.g. CONGIG PROJ_LIB "c:\ms4w\proj\nad\"</li><br>
+In a command line window, navigate to c:\ms4w\apache\cgi-bin and run php -i.
+This should return the output that the phpinfo() function returns. I got an
+error about how it couldn't find ntwdblib.dll. I found this in
+c:\ms4w\apache\php\dlls and I copied it to the cgi-bin directory.
-<li>change the IMAGEPATH to be an absolute path to your tmp/ms_tmp folder<br>
-e.g. IMAGEPATH "c:\ms4w\tmp\ms_tmp"</li>
-</ul>
+Mapfiles for IIS
-<h4>Configuration files:</h4>
-For Chameleon:<br>
-C:\ms4w\apps\chameleon\config\chameleon.xml<br>
-C:\ms4w\apps\chameleon\config\cwc2.xml <br>
-<br>
-For phppgadmin: (if using postgresql/postgis)<br>
-C:\ms4w\apps\phpPgAdmin\conf\config.inc.php<br>
+* Add a config line to the MAP level of the mapfile
+    - CONFIG PROJ_LIB "path/to/proj/nad/"
+        CONFIG PROJ_LIB "c:\ms4w\proj\nad\"
+* change the IMAGEPATH to be an absolute path to your tmp/ms_tmp folder
+        IMAGEPATH "c:\ms4w\tmp\ms_tmp"</li>
+Configuration files:
+For Chameleon
+* C:\ms4w\apps\chameleon\config\chameleon.xml
+* C:\ms4w\apps\chameleon\config\cwc2.xml
+For phppgadmin: (if using postgresql/postgis)
+* C:\ms4w\apps\phpPgAdmin\conf\config.inc.php
