[mapserver-commits] r8225 - in trunk/docs: howto installation
Tue Dec 9 20:34:22 EST 2008
Author: hobu
Date: 2008-12-09 20:34:22 -0500 (Tue, 09 Dec 2008)
New Revision: 8225
Added:
   trunk/docs/installation/iis.txt
Removed:
   trunk/docs/howto/setupiis.txt
   trunk/docs/installation/index.txt
mv iis doc into installation section
Deleted: trunk/docs/howto/setupiis.txt
--- trunk/docs/howto/setupiis.txt	2008-12-10 01:23:11 UTC (rev 8224)
+++ trunk/docs/howto/setupiis.txt	2008-12-10 01:34:22 UTC (rev 8225)
@@ -1,156 +0,0 @@
-.. _iis:
- IIS Setup for MapServer
-:Author: Debbie Paqurek
-:Last Updated: 2005/12/12
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-.. index:: IIS, php, cgi
-Some help on how to set up MapServer/Chameleon/PhpPgAdmin on Microsoft IIS
-(v5.0). Contains note on changes to the php.ini file and necessary changes to
-the MapServer mapfiles. Please contribute or make changes as required.
-Base configuration
-* Windows 2000
-* IIS 5.0
-* MS4W 1.2.1
-* Chameleon 2.2
-* PHP 4.3.11
-* MapServer 4.7
-* PhpPgAdmin 3.5.4 (if using postgresql/postgis)
-* Postgres 8.0.3 (if using postgresql/postgis)
-* Postgis 1.0.3 (if using postgresql/postgis)
-This setup assumes that MS4W was unzipped to form c:\ms4w\ directory.<br>
-Php.ini file
-* session.save_path (absolute path to your tmp directory)
-* extension_dir (relative path to your php/extensions directory)
-* cgi.force_redirect = 0</li>
-* enable the pg_sql extension (php_pgsql.dll) (for Postgresql)
-Internet Services Manager
-Under your website tree, create a new website (e.g. msprojects). View the
-properties for the new website.
-Web Site Tab
-    * set the IP address and under the Advanced tab put the complete Host
-      Header name (e.g.msprojects.gc.ca).
-Home Directory Tab
-    - content should come from: A directory located on this computer.
-    - Local Path: c:\ms4w\Apache\htdocs
-    - Read access + whatever else you need
-    - Execute Permissions: Scripts only
-    - Configuration button - App Mappings (Add extensions .php and .phtml,
-      Executable is c:\ms4w\Apache\cgi-bin\php.exe,select All verbs, Script
-      Engine, and check that file exists<br>
-Documents Tab
-    * Add index.phtml and index.html
-    * Directory Security Tab
-        - Anonymous access amd authentication control
-        - Select Anonymous access and the edit button should indicate the
-          IUSR_ account
-Server Extensions Tab
-    * Enable authoring is selected and client scripting says Javascript
-Under the tree for your new website - add virtual directories for
-cgi-bin
-    Under Properties, virtual directory tab Local Path should point to
-    c:\ms4w\apache\cgi-bin. Select Read. Execute Permissions should say
-    "scripts and executables"
-ms_tmp
-    c:\ms4w\tmp\ms_tmp. Select Read, Write. Execute Permissions should say
-    "scripts only". This is where temporary images are written to so in the
-    File system Security tab (use windows explorer), the c:\ms4w\tmp\ms_tmp
-    directory should have permissions set for the Internet Guest Account
-    (Read and execute, Read, Write, List Folder Contents).
-tmp
-    c:\ms4w\tmp. Select Read, Write. Execute Permissions should say "scripts
-    only". This is where chameleon writes sessions to so in the File system
-    Security tab (use windows explorer), the c:\ms4w\tmp directory should have
-    permissions set for the Internet Guest Accounnt (Read and execute, Read,
-    Write, List Folder Contents).
-chameleon
-    C:\ms4w\apps\chameleon\htdocs. Select Read. Execute Permissions should say
-    "scripts only".
-	Under the Chameleon tree, you can add virtual directories for admin
-    (c:\ms4w\apps\chameleon\admin\htdocs), samples
-    (c:\ms4w\apps\chameleon\samples\htdocs), cwc2
-    (c:\ms4w\apps\chameleon\cwc2\htdocs)
-phppgadmin
-    (if using postgresql/postgis) Under Properties, virtual directory tab
-    Local Path should point to C:\ms4w\Apache\htdocs\phpPgAdmin. Select Read,
-    Write. Execute Permissions should say "scripts and executables". Under
-    Documents - add index.php.
-	Please note that We had to unzip the phppgadmin package into this directory
-    in order to get phppgadmin to show us the login page at
-    http://yourserver/phppgadmin/index.php. You might want additional security on
-    this directory.
-gmap
-    Good for testing purposes. Remember to change your mapfiles as discussed
-    in Mapfiles for IIS below. Under Properties, virtual directory tab Local
-    Path should point to C:\ms4w\apps\gmap\htdocs. Select Read. Execute
-    Permissions should say "scripts only".
-Test PHP
-In a command line window, navigate to c:\ms4w\apache\cgi-bin and run php -i.
-This should return the output that the phpinfo() function returns. I got an
-error about how it couldn't find ntwdblib.dll. I found this in
-c:\ms4w\apache\php\dlls and I copied it to the cgi-bin directory.
-Mapfiles for IIS
-* Add a config line to the MAP level of the mapfile
-    - CONFIG PROJ_LIB "path/to/proj/nad/"
-        CONFIG PROJ_LIB "c:\ms4w\proj\nad\"
-* change the IMAGEPATH to be an absolute path to your tmp/ms_tmp folder
-        IMAGEPATH "c:\ms4w\tmp\ms_tmp"</li>
-Configuration files:
-For Chameleon
-* C:\ms4w\apps\chameleon\config\chameleon.xml
-* C:\ms4w\apps\chameleon\config\cwc2.xml
-For phppgadmin: (if using postgresql/postgis)
-* C:\ms4w\apps\phpPgAdmin\conf\config.inc.php
Copied: trunk/docs/installation/iis.txt (from rev 8224, trunk/docs/howto/setupiis.txt)
--- trunk/docs/installation/iis.txt	                        (rev 0)
+++ trunk/docs/installation/iis.txt	2008-12-10 01:34:22 UTC (rev 8225)
@@ -0,0 +1,163 @@
+.. _iis:
+ IIS Setup for MapServer
+:Author: Debbie Paqurek
+:Last Updated: 2005/12/12
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+.. index:: IIS, php, cgi
+Some help on how to set up MapServer/Chameleon/PhpPgAdmin on Microsoft IIS
+(v5.0). Contains note on changes to the php.ini file and necessary changes to
+the MapServer mapfiles. Please contribute or make changes as required.
+Base configuration
+* Windows 2000
+* IIS 5.0
+* MS4W 1.2.1
+* Chameleon 2.2
+* PHP 4.3.11
+* MapServer 4.7
+* PhpPgAdmin 3.5.4 (if using postgresql/postgis)
+* Postgres 8.0.3 (if using postgresql/postgis)
+* Postgis 1.0.3 (if using postgresql/postgis)
+This setup assumes that MS4W was unzipped to form c:\\ms4w\\ directory.<br>
+Php.ini file
+* session.save_path (absolute path to your tmp directory)
+* extension_dir (relative path to your php/extensions directory)
+* cgi.force_redirect = 0</li>
+* enable the pg_sql extension (php_pgsql.dll) (for Postgresql)
+Internet Services Manager
+Under your website tree, create a new website (e.g. msprojects). View the
+properties for the new website.
+Web Site Tab
+    * set the IP address and under the Advanced tab put the complete Host
+      Header name (e.g.msprojects.gc.ca).
+Home Directory Tab
+    - content should come from: A directory located on this computer.
+    - Local Path: c:\\ms4w\\Apache\\htdocs
+    - Read access + whatever else you need
+    - Execute Permissions: Scripts only
+    - Configuration button - App Mappings (Add extensions .php and .phtml,
+      Executable is c:\\ms4w\\Apache\\cgi-bin\\php.exe,select All verbs, Script
+      Engine, and check that file exists<br>
+Documents Tab
+    * Add index.phtml and index.html
+    * Directory Security Tab
+        - Anonymous access amd authentication control
+        - Select Anonymous access and the edit button should indicate the
+          IUSR_account
+Server Extensions Tab
+    * Enable authoring is selected and client scripting says Javascript
+Under the tree for your new website - add virtual directories for
+cgi-bin
+    Under Properties, virtual directory tab Local Path should point to
+    c:\\ms4w\\apache\\cgi-bin. Select Read. Execute Permissions should say
+    "scripts and executables"
+ms_tmp
+    c:\\ms4w\\tmp\\ms_tmp. Select Read, Write. Execute Permissions should say
+    "scripts only". This is where temporary images are written to so in the
+    File system Security tab (use windows explorer), the c:\\ms4w\\tmp\\ms_tmp
+    directory should have permissions set for the Internet Guest Account
+    (Read and execute, Read, Write, List Folder Contents).
+tmp
+    c:\\ms4w\\tmp. Select Read, Write. Execute Permissions should say "scripts
+    only". This is where chameleon writes sessions to so in the File system
+    Security tab (use windows explorer), the c:\\ms4w\\tmp directory should have
+    permissions set for the Internet Guest Accounnt (Read and execute, Read,
+    Write, List Folder Contents).
+chameleon
+    C:\\ms4w\\apps\\chameleon\\htdocs. Select Read. Execute Permissions should say
+    "scripts only". Under the Chameleon tree, you can add virtual directories for admin
+    (c:\\ms4w\\apps\\chameleon\\admin\\htdocs), samples
+    (c:\\ms4w\\apps\\chameleon\\samples\\htdocs), cwc2
+    (c:\\ms4w\\apps\\chameleon\\cwc2\\htdocs)
+phppgadmin
+    If using postgresql/postgis, under Properties, virtual directory tab
+    Local Path should point to C:\\ms4w\\Apache\\htdocs\\phpPgAdmin. Select Read,
+    Write. Execute Permissions should say "scripts and executables". Under
+    Documents - add index.php.
+.. note::
+    We had to unzip the phppgadmin package into this directory in order to
+    get phppgadmin to show us the login page at
+    http://yourserver/phppgadmin/index.php. You might want additional
+    security on this directory.
+gmap
+    Good for testing purposes. Remember to change your mapfiles as discussed
+    in Mapfiles for IIS below. Under Properties, virtual directory tab Local
+    Path should point to C:\\ms4w\\apps\\gmap\\htdocs. Select Read. Execute
+    Permissions should say "scripts only".
+Test PHP
+In a command line window, navigate to c:\\ms4w\\apache\\cgi-bin and run php -i.
+This should return the output that the phpinfo() function returns. I got an
+error about how it couldn't find ntwdblib.dll. I found this in
+c:\\ms4w\\apache\\php\\dlls and I copied it to the cgi-bin directory.
+Mapfiles for IIS
+* Add a config line to the MAP level of the mapfile
+    CONFIG PROJ_LIB "c:\ms4w\proj\nad\"
+* change the IMAGEPATH to be an absolute path to your tmp/ms_tmp folder
+    IMAGEPATH "c:\ms4w\tmp\ms_tmp"
+Configuration files:
+For Chameleon
+    C:\ms4w\apps\chameleon\config\chameleon.xml
+    C:\ms4w\apps\chameleon\config\cwc2.xml
+For phppgadmin: (if using postgresql/postgis)
+    C:\ms4w\apps\phpPgAdmin\conf\config.inc.php
Modified: trunk/docs/installation/index.txt
--- trunk/docs/installation/index.txt	2008-12-10 01:23:11 UTC (rev 8224)
+++ trunk/docs/installation/index.txt	2008-12-10 01:34:22 UTC (rev 8225)
@@ -12,4 +12,5 @@
    win32
    php
    dotnet
+   iis
