[mapserver-commits] r8226 - trunk/docs/howto
Tue Dec 9 20:34:58 EST 2008
Author: hobu
Date: 2008-12-09 20:34:57 -0500 (Tue, 09 Dec 2008)
New Revision: 8226
Removed:
   trunk/docs/howto/symbologyexchange.txt
   trunk/docs/howto/symbologyexchange_pixmap.txt
   trunk/docs/howto/symbologyexchange_ttf.txt
   trunk/docs/howto/symbologyexchange_vector.txt
symbology exchange has been moved to Trac
Deleted: trunk/docs/howto/symbologyexchange.txt
--- trunk/docs/howto/symbologyexchange.txt	2008-12-10 01:34:22 UTC (rev 8225)
+++ trunk/docs/howto/symbologyexchange.txt	2008-12-10 01:34:57 UTC (rev 8226)
@@ -1 +0,0 @@
-<h2>The Symbology Exchange</h2><p>Making a two-color square is easy, but a two-color star looks crummy unless you have the sizes just right -- it took me hours to make up a set of icons at 6 sizes apiece. And I knew I wasn't alone. So welcome to the Symbology Exchange!</p><p><br />Please post a comment to the appropriate "sub-howto" showing your icon(s). Ideally, there would be the code for it in a code box (the style selector at the top, highlight it and select Literal) and maybe even an image to show what it looks like. Thanks for sharing, and we hope you find something you like!</p><br /><ul><li><a href="/docs/howto/symbologyexchange_pixmap">Pixmap (image) symbols</a></li><li><a href="/docs/howto/symbologyexchange_vector">Vector symbols</a></li><li><a href="/docs/howtos/symbologyexchange_ttf">TrueType Font (TTF) Symbols</a><br /></li></ul><br /><p><br /></p><h2>Other Documents of Interest</h2><ul><li><a href="/docs/reference/mapfile/style">Mapfile reference: Style object</a> -- The most basic documentation about how to use symbols.</li><li><a href="/docs/reference/symbology">Symbology</a> -- A manual about symbology and how it works. Includes some examples, too.</li><li><a href="/docs/howto/cartosymbols">Construction of Cartographic Symbols by Peter Freimuth</a> -- A document outlining the concept of using multiple styles for a class to achieve more complex or multi-colored symbols.<br /></li></ul><br /><br />
\ No newline at end of file
Deleted: trunk/docs/howto/symbologyexchange_pixmap.txt
--- trunk/docs/howto/symbologyexchange_pixmap.txt	2008-12-10 01:34:22 UTC (rev 8225)
+++ trunk/docs/howto/symbologyexchange_pixmap.txt	2008-12-10 01:34:57 UTC (rev 8226)
@@ -1,9 +0,0 @@
-If you have a symbol to share, or want to share the URL of a cartographic icon or set of icons, please post it as a comment.
-<p><br />
-</p>
-<p>Guidelines:<br />
-</p>
-<ul><li>Please post a description of your symbols. "Various symbols" is nice, but if you can list what they are or at least say whether there's a focus, that would be great.<br />
-  </li><li>If you're able to post a link to seeing the symbol in action, be
-it a static image or its usage in a real map, that would be ideal.</li></ul>
-<br />
Deleted: trunk/docs/howto/symbologyexchange_ttf.txt
--- trunk/docs/howto/symbologyexchange_ttf.txt	2008-12-10 01:34:22 UTC (rev 8225)
+++ trunk/docs/howto/symbologyexchange_ttf.txt	2008-12-10 01:34:57 UTC (rev 8226)
@@ -1,9 +0,0 @@
-<p>If you have a symbol-font to share, or want to share the URL of such a fontset, please post it as a comment.
-</p>
-</p>
-nice, but if you can list what they are or at least say whether there's
-a focus, that would be great.<br />
Deleted: trunk/docs/howto/symbologyexchange_vector.txt
--- trunk/docs/howto/symbologyexchange_vector.txt	2008-12-10 01:34:22 UTC (rev 8225)
+++ trunk/docs/howto/symbologyexchange_vector.txt	2008-12-10 01:34:57 UTC (rev 8226)
@@ -1 +0,0 @@
-If you have a symbol to share, or want to share the URL of a symbolfile, please post it as a comment.<p><br /></p><p>Guidelines:<br /></p><ul><li>Please post a description of your symbols. While "railroad" is useful, it doesn't indicate how your railroad symbol differs from anyone else's. Is it just different? Does it handle antialiasing and transparency at the same time? Does it look good at a wide variety of sizes?<br /></li><li>If you're able to post a link to seeing the symbol in action, be it a static image or its usage in a real map, that would be ideal.</li></ul><br /><br />
