[mapserver-commits] r8227 - in trunk/docs: howto input/vector
svn at osgeo.org
svn at osgeo.org
Tue Dec 9 20:37:07 EST 2008
Author: hobu
Date: 2008-12-09 20:37:07 -0500 (Tue, 09 Dec 2008)
New Revision: 8227
Added:
trunk/docs/input/vector/mysql.txt
Removed:
trunk/docs/howto/ogrmysql.txt
trunk/docs/input/vector/mygis.txt
remove mygis docs, replace with OGR MySQL docs
Deleted: trunk/docs/howto/ogrmysql.txt
--- trunk/docs/howto/ogrmysql.txt 2008-12-10 01:34:57 UTC (rev 8226)
+++ trunk/docs/howto/ogrmysql.txt 2008-12-10 01:37:07 UTC (rev 8227)
@@ -1,106 +0,0 @@
-.. sectnum::
-Introduction
-This method takes advantage of OGR's MySQL driver and avoids the need to set up an ODBC connection.
-This is the primitive MySQL support for point data, not the recently added `MySQL spatial support found in GDAL/OGR 1.3.2`_ .
-Support for this functionality is found in GDAL/OGR 1.2.6 and older on Windows and GDAL/OGR 1.3.2 on Linux.
-**Needed**
-- MySQL database containing a table with fields containing x and y coordinates
-- .ovf file, a small xml file you will create
-- MapServer compiled with OGR version supporting this functinality
-Create .ovf file
-Here is the .ovf file named aqidata.ovf
- <OGRVRTDataSource>
- <OGRVRTLayer name="aqidata">
- <SrcDataSource>MYSQL:aqiTest,user=uuuuu,password=ppppp,host=192.170.1.100,port=3306,tables=testdata</SrcDataSource>
- <SrcSQL>SELECT areaID, x, y, sampleValue FROM testdata</SrcSQL>
- <GeometryType>wkbPoint</GeometryType>
- <GeometryField encoding="PointFromColumns" x="x" y="y"/>
- </OGRVRTLayer>
- </OGRVRTDataSource>
-If you look at the connection string in <SrcDataSource>
-- The MySQL database name is 'aqiTest'
-- 'testdata' is the table containing the coordinate data
-- host and port are for MySQL server
-Use the GeometryField element to tell OGR which fields store the x and y coordinate data. Mine are simply named x and y.
-Test Connection with ogrinfo
- # usr/local/bin/ogrinfo /maps/aqidata.ovf
-ogrinfo returns
- ERROR 4: Update access not supported for VRT datasources.
- Had to open data source read-only.
- INFO: Open of `/maps/aqidata.ovf'
- using driver `VRT' successful.
- 1: aqidata (Point)
-*Don't worry about the error, this is just telling you that it is a read-only driver.
-If it really bugs you, call ogrinfo with the -ro (read only) flag.*
-To see the actual data
-# usr/local/bin/ogrinfo /maps/aqidata.ovf -al
-Create MapServer Layer
- LAYER
- NAME "MyAqi"
- STATUS DEFAULT
- TYPE POINT
- CONNECTIONTYPE OGR
- CONNECTION "aqidata.ovf"
- DATA "aqidata"
- CLASS
- NAME "MyClass"
- STYLE
- SYMBOL 'circle'
- SIZE 15
- COLOR 0 255 0
- END
- END
- END
-DATA in the LAYER definition should be the same as the name attribute of the OGRVRTLayer element in the ovf file.
-*For this to draw, you need to have a SYMBOLSET defined in your mapfile and have a symbol called 'circle' in your symbols.sym file.*
-More Information
- `MapServer OGR HowTo`_
- `MapServer Vector Data Reference - Virtual Spatial Data`_
-.. #### rST Link Section ####
-.. _`MySQL spatial support found in GDAL/OGR 1.3.2`: http://www.gdal.org/ogr/drv_mysql.html
-.. _`MapServer OGR HowTo`: http://mapserver.gis.umn.edu/docs/howto/ogr_howto
-.. _`MapServer Vector Data Reference - Virtual Spatial Data`: http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
\ No newline at end of file
Deleted: trunk/docs/input/vector/mygis.txt
--- trunk/docs/input/vector/mygis.txt 2008-12-10 01:34:57 UTC (rev 8226)
+++ trunk/docs/input/vector/mygis.txt 2008-12-10 01:37:07 UTC (rev 8227)
@@ -1,56 +0,0 @@
-.. _mygis:
- MyGIS
-MyGIS reference
-The MyGIS reference documentation can be found at:
-http://dev.mysql.com/doc/refman/4.1/en/spatial-extensions.html
-Adding a MyGIS layer
-*Note: the following instructions have been extracted from the the mapmygis.c source and I have not tried them myself. I am adding them here only to fill a gap in the documentation; comments and suggestions are welcome.*
-Standard ways of specifiying a MyGIS connection are:
-(1) 'geometry_column from geometry_table'
-(2) 'geometry_column from (<sub query>) as foo using unique <column name>; using SRID=<srid#>'
-NOTE: for (2) 'using unique' and 'SRID=' are optional, but its highly recommended that you use them!!!
-The most common problem with (1) is incorrectly uploading your data. There must be an entry in the geometry_columns table. This will be automatically done if you used the shp2mysql program or created your geometry column with the AddGeometryColumn() MYGIS function.
-Another important thing to check is that the MYGIS user specified in the CONNECTION string does have SELECT permissions on the table(s) specified in your DATA string.
-If you are using the (2) method (and have errors), you've probably made a typo.
-Example:
-'the_geom from (select the_geom,oid from mytable) as foo using unique oid using SRID=76'
-This is very much like the (1) example. The subquery ('select the_geom,oid from mytable') will be executed, and mapserver will use 'oid' (a postgresql system column) for uniquely specifying a geometry (for mapserver queries). The geometry (the_geom) must have a SRID of 76.
-Example:
-'roads from (select table1.roads,table1.rd_segment_id,table2.rd_name,table2.rd_type from table1,table2 where table1.rd_segment_id=table2.rd_segment_id) as foo using unique rd_segment_id using SRID=89'
-This is a more complex sub-query involving joining two tables. The resulting geometry (column 'roads') has SRID=89, and mapserver will use rd_segment_id to uniquely identify a geometry. The attributes rd_type and rd_name are useable by other parts of mapserver.
-To use a view, do something like:
-'<geometry_column> from (SELECT * FROM <view>) as foo using unique <column name> using SRID=<srid#>'
-For example:
-'the_geom from (SELECT * FROM myview) as foo using unique gid using SRID=-1'
-NOTE: for the (2) case, the ' as foo ' is requred. The 'using unique <column>' and 'using SRID=' are case sensitive.
Copied: trunk/docs/input/vector/mysql.txt (from rev 8219, trunk/docs/howto/ogrmysql.txt)
--- trunk/docs/input/vector/mysql.txt (rev 0)
+++ trunk/docs/input/vector/mysql.txt 2008-12-10 01:37:07 UTC (rev 8227)
@@ -0,0 +1,106 @@
+.. sectnum::
+Introduction
+This method takes advantage of OGR's MySQL driver and avoids the need to set up an ODBC connection.
+This is the primitive MySQL support for point data, not the recently added `MySQL spatial support found in GDAL/OGR 1.3.2`_ .
+Support for this functionality is found in GDAL/OGR 1.2.6 and older on Windows and GDAL/OGR 1.3.2 on Linux.
+**Needed**
+- MySQL database containing a table with fields containing x and y coordinates
+- .ovf file, a small xml file you will create
+- MapServer compiled with OGR version supporting this functinality
+Create .ovf file
+Here is the .ovf file named aqidata.ovf
+ <OGRVRTDataSource>
+ <OGRVRTLayer name="aqidata">
+ <SrcDataSource>MYSQL:aqiTest,user=uuuuu,password=ppppp,host=192.170.1.100,port=3306,tables=testdata</SrcDataSource>
+ <SrcSQL>SELECT areaID, x, y, sampleValue FROM testdata</SrcSQL>
+ <GeometryType>wkbPoint</GeometryType>
+ <GeometryField encoding="PointFromColumns" x="x" y="y"/>
+ </OGRVRTLayer>
+ </OGRVRTDataSource>
+If you look at the connection string in <SrcDataSource>
+- The MySQL database name is 'aqiTest'
+- 'testdata' is the table containing the coordinate data
+- host and port are for MySQL server
+Use the GeometryField element to tell OGR which fields store the x and y coordinate data. Mine are simply named x and y.
+Test Connection with ogrinfo
+ # usr/local/bin/ogrinfo /maps/aqidata.ovf
+ogrinfo returns
+ ERROR 4: Update access not supported for VRT datasources.
+ Had to open data source read-only.
+ INFO: Open of `/maps/aqidata.ovf'
+ using driver `VRT' successful.
+ 1: aqidata (Point)
+*Don't worry about the error, this is just telling you that it is a read-only driver.
+If it really bugs you, call ogrinfo with the -ro (read only) flag.*
+To see the actual data
+# usr/local/bin/ogrinfo /maps/aqidata.ovf -al
+Create MapServer Layer
+ LAYER
+ NAME "MyAqi"
+ STATUS DEFAULT
+ TYPE POINT
+ CONNECTIONTYPE OGR
+ CONNECTION "aqidata.ovf"
+ DATA "aqidata"
+ CLASS
+ NAME "MyClass"
+ STYLE
+ SYMBOL 'circle'
+ SIZE 15
+ COLOR 0 255 0
+ END
+ END
+ END
+DATA in the LAYER definition should be the same as the name attribute of the OGRVRTLayer element in the ovf file.
+*For this to draw, you need to have a SYMBOLSET defined in your mapfile and have a symbol called 'circle' in your symbols.sym file.*
+More Information
+ `MapServer OGR HowTo`_
+ `MapServer Vector Data Reference - Virtual Spatial Data`_
+.. #### rST Link Section ####
+.. _`MySQL spatial support found in GDAL/OGR 1.3.2`: http://www.gdal.org/ogr/drv_mysql.html
+.. _`MapServer OGR HowTo`: http://mapserver.gis.umn.edu/docs/howto/ogr_howto
+.. _`MapServer Vector Data Reference - Virtual Spatial Data`: http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
More information about the mapserver-commits
