[mapserver-commits] r8228 - trunk/docs/input/vector
svn at osgeo.org
svn at osgeo.org
Tue Dec 9 20:41:09 EST 2008
Author: hobu
Date: 2008-12-09 20:41:09 -0500 (Tue, 09 Dec 2008)
New Revision: 8228
trunk/docs/input/vector/index.txt
trunk/docs/input/vector/mysql.txt
finish excising mygis
Modified: trunk/docs/input/vector/index.txt
--- trunk/docs/input/vector/index.txt 2008-12-10 01:37:07 UTC (rev 8227)
+++ trunk/docs/input/vector/index.txt 2008-12-10 01:41:09 UTC (rev 8228)
@@ -68,7 +68,7 @@
inline
kml
oracle_spatial
- mygis
+ mysql
ntf
sdts
tiger
Modified: trunk/docs/input/vector/mysql.txt
--- trunk/docs/input/vector/mysql.txt 2008-12-10 01:37:07 UTC (rev 8227)
+++ trunk/docs/input/vector/mysql.txt 2008-12-10 01:41:09 UTC (rev 8228)
@@ -1,13 +1,30 @@
-.. sectnum::
+.. _mysql:
+MySQL
+:Revision: $Revision$
+:Date: $Date$
+:Author: David Fawcett
+:Contact: david.fawcett at moea.state.mn.us
+.. contents::
+ :depth: 2
+ :backlinks: top
Introduction
-This method takes advantage of OGR's MySQL driver and avoids the need to set up an ODBC connection.
+This method takes advantage of OGR's MySQL driver and avoids the need to set
+up an ODBC connection.
-This is the primitive MySQL support for point data, not the recently added `MySQL spatial support found in GDAL/OGR 1.3.2`_ .
+This is the primitive MySQL support for point data, not the recently added
+`MySQL spatial support found in GDAL/OGR 1.3.2`_ .
-Support for this functionality is found in GDAL/OGR 1.2.6 and older on Windows and GDAL/OGR 1.3.2 on Linux.
+Support for this functionality is found in GDAL/OGR 1.2.6 and older on Windows
+and GDAL/OGR 1.3.2 on Linux.
**Needed**
@@ -37,7 +54,8 @@
- 'testdata' is the table containing the coordinate data
- host and port are for MySQL server
-Use the GeometryField element to tell OGR which fields store the x and y coordinate data. Mine are simply named x and y.
+Use the GeometryField element to tell OGR which fields store the x and y
+coordinate data. Mine are simply named x and y.
Test Connection with ogrinfo
@@ -88,19 +106,18 @@
END
END
-DATA in the LAYER definition should be the same as the name attribute of the OGRVRTLayer element in the ovf file.
+DATA in the LAYER definition should be the same as the name attribute of the
+OGRVRTLayer element in the ovf file.
-*For this to draw, you need to have a SYMBOLSET defined in your mapfile and have a symbol called 'circle' in your symbols.sym file.*
+*For this to draw, you need to have a SYMBOLSET defined in your mapfile and
+have a symbol called 'circle' in your symbols.sym file.*
More Information
- `MapServer OGR HowTo`_
+* :ref:`ogr`
+* :ref:`vector`
- `MapServer Vector Data Reference - Virtual Spatial Data`_
.. #### rST Link Section ####
.. _`MySQL spatial support found in GDAL/OGR 1.3.2`: http://www.gdal.org/ogr/drv_mysql.html
-.. _`MapServer OGR HowTo`: http://mapserver.gis.umn.edu/docs/howto/ogr_howto
-.. _`MapServer Vector Data Reference - Virtual Spatial Data`: http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
\ No newline at end of file
More information about the mapserver-commits
