[mapserver-commits] r8232 - trunk/docs/input/vector
Tue Dec 9 21:26:54 EST 2008
Author: hobu
Date: 2008-12-09 21:26:54 -0500 (Tue, 09 Dec 2008)
New Revision: 8232
Added:
   trunk/docs/input/vector/oracle.txt
Removed:
   trunk/docs/input/vector/oracle_spatial.txt
   trunk/docs/input/vector/index.txt
rename
Modified: trunk/docs/input/vector/index.txt
--- trunk/docs/input/vector/index.txt	2008-12-10 02:21:50 UTC (rev 8231)
+++ trunk/docs/input/vector/index.txt	2008-12-10 02:26:54 UTC (rev 8232)
@@ -67,7 +67,7 @@
    pgeo
    inline
    kml
-   oracle_spatial
+   oracle
    mysql
    ntf
    sdts
Copied: trunk/docs/input/vector/oracle.txt (from rev 8229, trunk/docs/input/vector/oracle_spatial.txt)
--- trunk/docs/input/vector/oracle.txt	                        (rev 0)
+++ trunk/docs/input/vector/oracle.txt	2008-12-10 02:26:54 UTC (rev 8232)
@@ -0,0 +1,62 @@
+.. _oci:
+ Oracle Spatial
+MapServer can support Oracle Spatial through OGR. With this method, OGR must
+be compiled with Oracle Spatial support and MapServer must be compiled to use
+OGR. In addition, MapServer also supports Oracle Spatial natively.
+Map file example using OGR Support
+	LAYER
+		CONNECTION "OCI:user/pwd at service"
+		CONNECTIONTYPE OGR
+		DATA "Tablename"
+	END
+Example:
+	LAYER
+		NAME "Ottawa"
+		CONNECTION "OCI:jeff/blah at ora_cities"
+		DATA "CITIES"
+		TYPE POINT
+	END
+Map file example Using Native Support
+	LAYER
+		CONNECTIONTYPE oraclespatial
+		CONNECTION "user/pwd at service"
+		DATA "GEOMETRY FROM tablename"
+	END
+Example using Oracle 10g:
+        LAYER
+                CONNECTION "jeff/pass at dmsg"
+                DATA "ORA_GEOMETRY FROM (SELECT ORA_GEOMETRY FROM PARK)"
+        END
\ No newline at end of file
Deleted: trunk/docs/input/vector/oracle_spatial.txt
--- trunk/docs/input/vector/oracle_spatial.txt	2008-12-10 02:21:50 UTC (rev 8231)
+++ trunk/docs/input/vector/oracle_spatial.txt	2008-12-10 02:26:54 UTC (rev 8232)
@@ -1,62 +0,0 @@
-.. _oci:
- Oracle Spatial
-MapServer can support Oracle Spatial through OGR. With this method, OGR must
-be compiled with Oracle Spatial support and MapServer must be compiled to use
-OGR. In addition, MapServer also supports Oracle Spatial natively.
-Map file example using OGR Support
-	LAYER
-		CONNECTION "OCI:user/pwd at service"
-		CONNECTIONTYPE OGR
-		DATA "Tablename"
-	END
-Example:
-	LAYER
-		NAME "Ottawa"
-		CONNECTION "OCI:jeff/blah at ora_cities"
-		DATA "CITIES"
-		TYPE POINT
-	END
-Map file example Using Native Support
-	LAYER
-		CONNECTIONTYPE oraclespatial
-		CONNECTION "user/pwd at service"
-		DATA "GEOMETRY FROM tablename"
-	END
-Example using Oracle 10g:
-        LAYER
-                CONNECTION "jeff/pass at dmsg"
-                DATA "ORA_GEOMETRY FROM (SELECT ORA_GEOMETRY FROM PARK)"
-        END
