[mapserver-commits] r8233 - in trunk/docs: . input/vector
installation
svn at osgeo.org
svn at osgeo.org
Tue Dec 9 22:09:54 EST 2008
Author: hobu
Date: 2008-12-09 22:09:54 -0500 (Tue, 09 Dec 2008)
New Revision: 8233
trunk/docs/download.txt
trunk/docs/input/vector/oracle.txt
trunk/docs/installation/oracle.txt
convert to ReST
Modified: trunk/docs/download.txt
--- trunk/docs/download.txt 2008-12-10 02:26:54 UTC (rev 8232)
+++ trunk/docs/download.txt 2008-12-10 03:09:54 UTC (rev 8233)
@@ -42,9 +42,13 @@
Binaries
+.. _windows:
Windows
`MS4W`_
MapServer for Windows from MapTools.org. If you are a beginner looking for
a complete MapServer solution in the Windows platform, or an advanced user
Modified: trunk/docs/input/vector/oracle.txt
--- trunk/docs/input/vector/oracle.txt 2008-12-10 02:26:54 UTC (rev 8232)
+++ trunk/docs/input/vector/oracle.txt 2008-12-10 03:09:54 UTC (rev 8233)
@@ -4,59 +4,354 @@
Oracle Spatial
-MapServer can support Oracle Spatial through OGR. With this method, OGR must
-be compiled with Oracle Spatial support and MapServer must be compiled to use
-OGR. In addition, MapServer also supports Oracle Spatial natively.
+:Author: Bart van den Eijnden
+:Last Updated: 2005/12/12
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
-Map file example using OGR Support
+.. index:: Oracle
+Oracle Spatial is a spatial cartridge for the Oracle database. Remember
+that all Oracle databases come with Locator, which has less features than
+Oracle Spatial. The differences between Locator and Spatial can be found in
+the `Oracle Spatial FAQ`_.
+What MapServer 5.2 with Oracle Spatial
+* mode=map
+* query modes: query, nquery, itemnquery
+* :ref:`mapscript` query functions such as querybyattributes
+* :ref:`OGC:WMS <wms_server>`: GetCapabilities, GetMap, GetFeatureInfo, DescribeLayer
+* :ref:`OGC:WFS <wfs_server>`, GetCapabilities, DescribeFeatureType, GetFeature
+Binaries
+MapServer Windows plugins with Oracle spatial support can be downloaded from
+:ref:`MS4W <windows>`. But you need Oracle client software in the server on which you
+are running MapServer. Oracle client software can be obtained for development
+purposes from the Oracle website, but you need to register, which by the way
+is free. The most recent version is Oracle Database 10g Release 1 Client. The
+ORACLE TECHNOLOGY NETWORK DEVELOPMENT LICENSE AGREEMENT applies to this
+software. The instant client will be satisfactory, and you can download the
+`instant client`_. Make sure though your MapServer is compiled against the
+same version as your Oracle client, for compiling you need a full client
+install, not just the instant client.
+Installation
+See :ref:`oci_install` for more configuration and installation information
+for MapServer's native Oracle support
+.. note::
+ If you receive error messages like "Error: .". It's likely related to
+ MapServer being unable access or locate the ORACLE_HOME.
+Two options for using Oracle Spatial with MapServer
+Oracle Spatial layers in MapServer can be used through 2 interfaces:
+* The native built-in support through maporaclespatial.c
+* OGR, but watch out: OGR is not compiled with Oracle Spatial support so it
+ won't work without compiling in OCI (Oracle client) yourself. This requires
+ both recompiling GDAL/OGR as well as recompiling MapServer itself against
+ the new GDAL/OGR !!!!
+Mapfile syntax for native Oracle Spatial support
+The DATA statement for a LAYER of CONNECTIONTYPE oraclespatial can now have 4
+options. This change is backwards compatible, i.e. the old ways of specifying
+DATA still work. The new options are an extension to the old DATA statements,
+as they needed to include identification of the primary key to be used for the
+query modes (UNIQUE).
+The following options are valid DATA statements:
- LAYER
- CONNECTION "OCI:user/pwd at service"
- CONNECTIONTYPE OGR
- DATA "Tablename"
- END
+ "[geom_column]
+ FROM
+ [table]| [(
+ SELECT [...]
+ FROM [table]|[Spatial Operator]
+ [WHERE condition] )]
+ [USING [UNIQUE column]
+ | [SRID #srid]
+ | [FUNCTION]
+ | [VERSION #version]
-Example:
+Example 1
+The most simple DATA statement, in this case you only need to define one
+geometry column and one table. This option assumes you do not have an SRID
+defined.
- LAYER
- NAME "Ottawa"
- CONNECTION "OCI:jeff/blah at ora_cities"
- DATA "CITIES"
- TYPE POINT
- END
+ LAYER
+ CONNECTIONTYPE oraclespatial
+ DATA "MYGEOMETRY FROM MYTABLE"
+ END
-Map file example Using Native Support
+Example 2
+It's composed of the first option plus the USING UNIQUE parameter. These new
+features are necessary when you want to use any query function. When it is
+used you must pass a numeric column type. This option assumes you do not have
+an SRID defined.
+ LAYER
+ DATA "MYGEOMETRY FROM MYTABLE USING UNIQUE MYTABLE_ID"
+ END
+Example 3
- LAYER
- CONNECTIONTYPE oraclespatial
- CONNECTION "user/pwd at service"
- DATA "GEOMETRY FROM tablename"
- END
+This option is an extension to the first option. In this
+mode you must define the USING SRID parameter when the SRID value in your data
+is different from NULL.
-Example using Oracle 10g:
+ LAYER
+ DATA "MYGEOMETRY FROM MYTABLE USING SRID 90112"
+ END
+Example 4
+This option is a combination of examples 2 and 3.
- LAYER
- CONNECTION "jeff/pass at dmsg"
- DATA "ORA_GEOMETRY FROM (SELECT ORA_GEOMETRY FROM PARK)"
- END
\ No newline at end of file
+ LAYER
+ DATA "MYGEOMETRY FROM MYTABLE USING UNIQUE MYTABLE_ID SRID 90112"
+ END
+Using subselects in the DATA statement
+It is possible to define the source of the date as a subselect and not only as
+a table. As source of data, used in FROM token, you can define any SQL, table,
+function, or operator that returns a SDO_GEOMETRY. For example:
+ DATA "[geom_column] FROM (SELECT [columns] FROM [table]|[Spatial function])"
+If the LAYER definition contains a CLASSITEM, LABELITEM or FILTER, it is
+necessary that the fields used are returned by the query. When you define
+CLASSITEM you can use an expression without any problems.
+Additional keywords - [FUNCTION]
+You can add three keywords to the DATA statement for [FUNCTION] option that
+influence the query which will be executed in Oracle:
+USING FILTER
+ "[geom_column] FROM [table]|([Subselect]) USING FILTER"
+Using this keyword triggers MapServer to use the Oracle Spatial SDO_FILTER
+operator. This operator executes only the Oracle Spatial primary filter over
+your query data. In the Oracle User guide they explain: The primary filter
+compares geometric approximations, it returns a superset of exact result. The
+primary filter therefore should be as efficient (that is, selective yet fast)
+as possible. This operator uses the spatial index, so you need to define your
+spatial index correctly to retrieve an exact result. If the result of the
+query is not exact you can try the next option.
+USING RELATE
+ "[geom_column] FROM [table]|([Subselect]) USING RELATE"
+Using this keyword triggers MapServer to use the Oracle Spatial SDO_RELATE
+operator. This operator applies the primary and secondary Oracle Spatial
+filters. It's performance can be slightly slow but the result is extremely
+correct. You can use this mode when you want a perfect result or when you
+can't readjust the spatial index.
+USING GEOMRELATE
+ "[geom_column] FROM [table]|([Subselect]) USING GEOMRELATE"
+Using this keyword triggers MapServer to use the geometry function
+SDO_GEOM.RELATE, a function that searches the relations between geometries.
+SDO_GEOM.RELATE does not use the spatial index and your performance is more
+slow than operators but it's very accurate. You can use this mode when you
+can't use the spatial index or when it doesn't exist.
+USING NONE
+ "[geom_column] FROM [table]|([Subselect]) USING NONE"
+Using this keyword triggers MapServer to don't use any geometry function or
+spatial operator. So, the internal SQL don't retrict, bases in the extent, the
+data from source. All the data from source will be returned for MapServer. The
+NONE token is very useful when the source of the data don't contains any
+spatial index. It's usually occur when the source is a function like
+SDO_BUFFER, SDO_XOR, SDO_INTERSECTION...... So this mode is recomended when
+you can't use the spatial index or when it doesn't exist.
+Additional keywords - [VERSION]
+You can define what version of database you are using to improve the internal
+sql. This is very useful when using geodetic SRIDs and MapServer functions
+that retrieve the extent from data.
+USING VERSION 8i
+ "[geom_column] FROM [table]|([Subselect]) USING VERSION 8i"
+This indicates MapServer to use a internal SQL that it's compatible with
+Oracle 8i version.
+USING VERSION 9i
+ "[geom_column] FROM [table]|([Subselect]) USING VERSION 9i"
+The second indicates MapServer to use 9i version, is recommended to use this
+parameter if you are using 9i version because the internal SQL will use
+specific spatial functions that is need to retrieve data correctly from 9i
+Oracle Spatial versions.
+USING VERSION 10g
+ "[geom_column] FROM [table]|([Subselect]) USING VERSION 10g"
+Oracle 10g version.
+More information
+* You can define any :ref:`PROJECTION` to your :ref:`LAYER` without problem,
+ can be used for data with or without an SRID in Oracle.
+* The native support for Oracle Spatial supports the defaults definition for
+ SDO_GEOMETRY in database, the Oracle Spatial SDO package.
+* Information about the primary and secondary Oracle Spatial filters can be
+ found in the Oracle Spatial User Guide (the "Query Model" section).
+ Information about the SDO_FILTER and SDO_RELATE operators can be found in
+ the "Spatial Operators" section, and information about the SDO_GEOM.RELATE
+ function can be found in the "Geometry Function" section of the Oracle
+ Spatial User Guide.
+Example of a :ref:`LAYER`
+ LAYER
+ NAME kwadranten
+ TYPE POLYGON
+ CONNECTION "user/pwd"
+ DATA "GEOMETRIE FROM KWADRANTEN USING SRID 90112"
+ DUMP TRUE
+ CLASS
+ STYLE
+ OUTLINECOLOR 0 0 0
+ COLOR 0 128 128
+ END
+ END
+ END
+You can specify the SID for your database, the SID alias needs to be supplied
+in the tnsnames.ora file of the Oracle client, e.g.
+Example for tnsnames.ora:
+ MYDB =
+ (DESCRIPTION =
+ (ADDRESS_LIST =
+ (ADDRESS = (PROTOCOL = TCP)(HOST = server_ip)(PORT = 1521))
+ (CONNECT_DATA =
+ (SERVICE_NAME = DB1)
+So after this you can define you layer connection as:
+ CONNECTION "user/pwd at MYDB"
+:ref:`Mapfile <mapfile>` syntax for OGR Oracle Spatial support
+Syntax for your MAP file:
+ CONNECTION "OCI:user/pwd at service"
+ CONNECTIONTYPE OGR
+ DATA "Tablename"
+.. note::
+ Make sure you set the wms_extent METADATA for the LAYER, as otherwise the
+ "Getcapabilities" request takes a lot of time.
+.. _`Oracle Spatial FAQ`: http://www.orafaq.com/faqsdo.htm
+.. _`instant client`: http://www.oracle.com/technology/software/tech/oci/instantclient/index.html
Modified: trunk/docs/installation/oracle.txt
--- trunk/docs/installation/oracle.txt 2008-12-10 02:26:54 UTC (rev 8232)
+++ trunk/docs/installation/oracle.txt 2008-12-10 03:09:54 UTC (rev 8233)
@@ -13,7 +13,7 @@
.. index::
- pair: Oracle, install
+ pair: Oracle; install
Preface
@@ -224,7 +224,7 @@
This points us towards, that there might be a problem with the connection to
the database. First of all, let's check, if the mapfile is all right.
-Therefore we use the MapServer utility program :ref:`shp2img_utility`.
+Therefore we use the MapServer utility program :ref:`shp2img`.
Let's assume you are in the directory, where you compiled MapServer and run
shp2img:
More information about the mapserver-commits
