[mapserver-commits] r7338 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Feb 1 14:08:25 EST 2008
Author: sdlime
Date: 2008-02-01 14:08:25 -0500 (Fri, 01 Feb 2008)
New Revision: 7338
trunk/mapserver/mapprimitive.c
Updated copyright date, clean out all tabs.
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2008-02-01 18:27:45 UTC (rev 7337)
+++ trunk/mapserver/mapprimitive.c 2008-02-01 19:08:25 UTC (rev 7338)
@@ -5,7 +5,7 @@
* Author: Steve Lime and the MapServer team.
- * Copyright (c) 1996-2005 Regents of the University of Minnesota.
+ * Copyright (c) 1996-2008 Regents of the University of Minnesota.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
@@ -41,9 +41,9 @@
#define EDGE_CHECK( x0, x, x1) ((x) < MS_MIN( (x0), (x1)) ? CLIP_LEFT : ((x) > MS_MAX( (x0), (x1)) ? CLIP_RIGHT : CLIP_MIDDLE ))
#ifndef INFINITY
-#define INFINITY (1.0e+30)
+#define INFINITY (1.0e+30)
#endif
-#define NEARZERO (1.0e-30) /* 1/INFINITY */
+#define NEARZERO (1.0e-30) /* 1/INFINITY */
void msPrintShape(shapeObj *p)
@@ -167,22 +167,19 @@
void msShapeDeleteLine( shapeObj *shape, int line )
- if( line < 0 || line >= shape->numlines )
- assert( 0 );
- return;
+ if( line < 0 || line >= shape->numlines ) {
+ assert( 0 );
+ return;
- free( shape->line[line].point );
- if( line < shape->numlines - 1 )
- memmove( shape->line + line,
- shape->line + line + 1,
- sizeof(lineObj) * (shape->numlines - line - 1) );
- shape->numlines--;
+ free( shape->line[line].point );
+ if( line < shape->numlines - 1 ) {
+ memmove( shape->line + line,
+ shape->line + line + 1,
+ sizeof(lineObj) * (shape->numlines - line - 1) );
+ shape->numlines--;
void msComputeBounds(shapeObj *shape)
@@ -227,7 +224,7 @@
if(result1 == MS_TRUE) status = !status;
} else { /* one of the first 2 points were on the edge of the ring, the next one isn't */
if(msPointInPolygon(&(shape->line[r].point[2]), &(shape->line[i])) == MS_TRUE)
- status = !status;
+ status = !status;
@@ -288,32 +285,28 @@
int msAddPointToLine(lineObj *line, pointObj *point )
- line->numpoints += 1;
+ line->numpoints += 1;
- line->point = (pointObj *)
- realloc(line->point, sizeof(pointObj) * line->numpoints);
+ line->point = (pointObj *) realloc(line->point, sizeof(pointObj) * line->numpoints);
+ line->point[line->numpoints-1] = *point;
- line->point[line->numpoints-1] = *point;
- return MS_SUCCESS;
+ return MS_SUCCESS;
int msAddLine(shapeObj *p, lineObj *new_line)
- lineObj lineCopy;
+ lineObj lineCopy;
- lineCopy.numpoints = new_line->numpoints;
- lineCopy.point = (pointObj *) malloc(new_line->numpoints*sizeof(pointObj));
- if( lineCopy.point == NULL )
- msSetError(MS_MEMERR, NULL, "msAddLine()");
- return(MS_FAILURE);
+ lineCopy.numpoints = new_line->numpoints;
+ lineCopy.point = (pointObj *) malloc(new_line->numpoints*sizeof(pointObj));
+ if( lineCopy.point == NULL ) {
+ msSetError(MS_MEMERR, NULL, "msAddLine()");
+ return(MS_FAILURE);
- memcpy( lineCopy.point, new_line->point,
- sizeof(pointObj) * new_line->numpoints );
+ memcpy( lineCopy.point, new_line->point, sizeof(pointObj) * new_line->numpoints );
- return msAddLineDirectly( p, &lineCopy );
+ return msAddLineDirectly( p, &lineCopy );
@@ -325,9 +318,9 @@
int c;
if( p->numlines == 0 )
- p->line = (lineObj *) malloc(sizeof(lineObj));
+ p->line = (lineObj *) malloc(sizeof(lineObj));
else
- p->line = (lineObj *) realloc(p->line, (p->numlines+1)*sizeof(lineObj));
+ p->line = (lineObj *) realloc(p->line, (p->numlines+1)*sizeof(lineObj));
/* Copy the new line onto the end of the extended line array */
c= p->numlines;
@@ -497,22 +490,22 @@
y2 = shape->line[i].point[j].y;
if(clipLine(&x1,&y1,&x2,&y2,rect) == MS_TRUE) {
- if(line.numpoints == 0) { /* first segment, add both points */
- line.point[0].x = x1;
- line.point[0].y = y1;
- line.point[1].x = x2;
- line.point[1].y = y2;
- line.numpoints = 2;
- } else { /* add just the last point */
- line.point[line.numpoints].x = x2;
- line.point[line.numpoints].y = y2;
- line.numpoints++;
+ if(line.numpoints == 0) { /* first segment, add both points */
+ line.point[0].x = x1;
+ line.point[0].y = y1;
+ line.point[1].x = x2;
+ line.point[1].y = y2;
+ line.numpoints = 2;
+ } else { /* add just the last point */
+ line.point[line.numpoints].x = x2;
+ line.point[line.numpoints].y = y2;
+ line.numpoints++;
- if((x2 != shape->line[i].point[j].x) || (y2 != shape->line[i].point[j].y)) {
- msAddLine(&tmp, &line);
- line.numpoints = 0; /* new line */
+ if((x2 != shape->line[i].point[j].x) || (y2 != shape->line[i].point[j].y)) {
+ msAddLine(&tmp, &line);
+ line.numpoints = 0; /* new line */
x1 = shape->line[i].point[j].x;
@@ -579,94 +572,92 @@
deltax = x2-x1;
if (deltax == 0) { /* bump off of the vertical */
- deltax = (x1 > rect.minx) ? -NEARZERO : NEARZERO ;
+ deltax = (x1 > rect.minx) ? -NEARZERO : NEARZERO ;
deltay = y2-y1;
if (deltay == 0) { /* bump off of the horizontal */
- deltay = (y1 > rect.miny) ? -NEARZERO : NEARZERO ;
+ deltay = (y1 > rect.miny) ? -NEARZERO : NEARZERO ;
- if (deltax > 0) { /* points to right */
- xin = rect.minx;
- xout = rect.maxx;
+ if (deltax > 0) { /* points to right */
+ xin = rect.minx;
+ xout = rect.maxx;
+ } else {
+ xin = rect.maxx;
+ xout = rect.minx;
- else {
- xin = rect.maxx;
- xout = rect.minx;
+ if (deltay > 0) { /* points up */
+ yin = rect.miny;
+ yout = rect.maxy;
+ } else {
+ yin = rect.maxy;
+ yout = rect.miny;
- if (deltay > 0) { /* points up */
- yin = rect.miny;
- yout = rect.maxy;
- else {
- yin = rect.maxy;
- yout = rect.miny;
tinx = (xin - x1)/deltax;
tiny = (yin - y1)/deltay;
- if (tinx < tiny) { /* hits x first */
- tin1 = tinx;
- tin2 = tiny;
- } else { /* hits y first */
- tin1 = tiny;
- tin2 = tinx;
+ if (tinx < tiny) { /* hits x first */
+ tin1 = tinx;
+ tin2 = tiny;
+ } else { /* hits y first */
+ tin1 = tiny;
+ tin2 = tinx;
if (1 >= tin1) {
- if (0 < tin1) {
- line.point[line.numpoints].x = xin;
- line.point[line.numpoints].y = yin;
- line.numpoints++;
- if (1 >= tin2) {
- toutx = (xout - x1)/deltax;
- touty = (yout - y1)/deltay;
- tout = (toutx < touty) ? toutx : touty ;
- if (0 < tin2 || 0 < tout) {
- if (tin2 <= tout) {
- if (0 < tin2) {
- if (tinx > tiny) {
- line.point[line.numpoints].y = y1 + tinx*deltay;
- line.numpoints++;
- } else {
- line.point[line.numpoints].x = x1 + tiny*deltax;
- line.numpoints++;
- if (1 > tout) {
- if (toutx < touty) {
- line.point[line.numpoints].x = xout;
- line.point[line.numpoints].y = y1 + toutx*deltay;
- line.numpoints++;
- } else {
- line.point[line.numpoints].x = x1 + touty*deltax;
- line.point[line.numpoints].y = yout;
- line.numpoints++;
- } else {
- line.numpoints++;
- } else {
- line.numpoints++;
- } else {
- line.numpoints++;
+ if (0 < tin1) {
+ line.point[line.numpoints].x = xin;
+ line.point[line.numpoints].y = yin;
+ line.numpoints++;
+ if (1 >= tin2) {
+ toutx = (xout - x1)/deltax;
+ touty = (yout - y1)/deltay;
+ tout = (toutx < touty) ? toutx : touty ;
+ if (0 < tin2 || 0 < tout) {
+ if (tin2 <= tout) {
+ if (0 < tin2) {
+ if (tinx > tiny) {
+ line.point[line.numpoints].y = y1 + tinx*deltay;
+ line.numpoints++;
+ } else {
+ line.point[line.numpoints].x = x1 + tiny*deltax;
+ line.numpoints++;
+ if (1 > tout) {
+ if (toutx < touty) {
+ line.point[line.numpoints].x = xout;
+ line.point[line.numpoints].y = y1 + toutx*deltay;
+ line.numpoints++;
+ } else {
+ line.point[line.numpoints].x = x1 + touty*deltax;
+ line.point[line.numpoints].y = yout;
+ line.numpoints++;
+ } else {
+ line.numpoints++;
+ } else {
+ line.numpoints++;
+ } else {
+ line.numpoints++;
@@ -696,7 +687,7 @@
double x=0, y=0;
if ( msCheckParentPointer(layer->map,"map")==MS_FAILURE )
- return;
+ return;
if(layer->transform == MS_TRUE) return; /* nothing to do */
@@ -759,7 +750,7 @@
- return;
+ return;
if(layer->units == MS_PERCENTAGES) {
@@ -829,60 +820,55 @@
if(shape->numlines == 0) return; /* nothing to transform */
if(shape->type == MS_SHAPE_LINE || shape->type == MS_SHAPE_POLYGON) { /* remove duplicate vertices */
- for(i=0; i<shape->numlines; i++) { /* for each part */
- shape->line[i].point[0].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[0].x, extent.minx, inv_cs);
- shape->line[i].point[0].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[0].y, extent.maxy, inv_cs);
- for(j=1, k=1; j < shape->line[i].numpoints; j++ ) {
- shape->line[i].point[k].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[j].x, extent.minx, inv_cs);
- shape->line[i].point[k].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[j].y, extent.maxy, inv_cs);
- if(shape->line[i].point[k].x!=shape->line[i].point[k-1].x ||
- shape->line[i].point[k].y!=shape->line[i].point[k-1].y)
- k++;
- shape->line[i].numpoints = k; /* save actual number kept */
+ for(i=0; i<shape->numlines; i++) { /* for each part */
+ shape->line[i].point[0].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[0].x, extent.minx, inv_cs);
+ shape->line[i].point[0].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[0].y, extent.maxy, inv_cs);
+ for(j=1, k=1; j < shape->line[i].numpoints; j++ ) {
+ shape->line[i].point[k].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[j].x, extent.minx, inv_cs);
+ shape->line[i].point[k].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[j].y, extent.maxy, inv_cs);
+ if(shape->line[i].point[k].x!=shape->line[i].point[k-1].x || shape->line[i].point[k].y!=shape->line[i].point[k-1].y)
+ k++;
+ shape->line[i].numpoints = k; /* save actual number kept */
} else { /* points or untyped shapes */
for(j=1; j < shape->line[i].numpoints; j++ ) {
- shape->line[i].point[j].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[j].x, extent.minx, inv_cs);
- shape->line[i].point[j].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[j].y, extent.maxy, inv_cs);
+ shape->line[i].point[j].x = MS_MAP2IMAGE_X_IC(shape->line[i].point[j].x, extent.minx, inv_cs);
+ shape->line[i].point[j].y = MS_MAP2IMAGE_Y_IC(shape->line[i].point[j].y, extent.maxy, inv_cs);
** Converts from map coordinates to image coordinates
void msTransformPixelToShape(shapeObj *shape, rectObj extent, double cellsize)
- int i,j; /* loop counters */
+ int i,j; /* loop counters */
- if(shape->numlines == 0) return; /* nothing to transform */
+ if(shape->numlines == 0) return; /* nothing to transform */
- if(shape->type == MS_SHAPE_LINE || shape->type == MS_SHAPE_POLYGON) /* remove co-linear vertices */
- for(i=0; i<shape->numlines; i++) /* for each part */
- for(j=0; j < shape->line[i].numpoints; j++ )
- shape->line[i].point[j].x = MS_IMAGE2MAP_X(shape->line[i].point[j].x, extent.minx, cellsize);
- shape->line[i].point[j].y = MS_IMAGE2MAP_Y(shape->line[i].point[j].y, extent.maxy, cellsize);
- else /* points or untyped shapes */
- for(j=1; j < shape->line[i].numpoints; j++ )
+ if(shape->type == MS_SHAPE_LINE || shape->type == MS_SHAPE_POLYGON) { /* remove co-linear vertices */
- return;
+ for(j=0; j < shape->line[i].numpoints; j++ ) {
+ shape->line[i].point[j].x = MS_IMAGE2MAP_X(shape->line[i].point[j].x, extent.minx, cellsize);
+ shape->line[i].point[j].y = MS_IMAGE2MAP_Y(shape->line[i].point[j].y, extent.maxy, cellsize);
+ } else { /* points or untyped shapes */
+ for(j=1; j < shape->line[i].numpoints; j++ ) {
+ return;
@@ -946,11 +932,11 @@
angle = asin(MS_ABS(p->line[i].point[j].x - p->line[i].point[j-1].x)/sqrt((pow((p->line[i].point[j].x - p->line[i].point[j-1].x),2.0) + pow((p->line[i].point[j].y - p->line[i].point[j-1].y),2.0))));
if(p->line[i].point[j-1].x < p->line[i].point[j].x)
- dy = sin(angle) * (w/2);
+ dy = sin(angle) * (w/2);
else
- dy = -sin(angle) * (w/2);
+ dy = -sin(angle) * (w/2);
if(p->line[i].point[j-1].y < p->line[i].point[j].y)
- dx = -cos(angle) * (w/2);
+ dx = -cos(angle) * (w/2);
else
dx = cos(angle) * (w/2);
@@ -1058,25 +1044,25 @@
lo_y = y + 1;
for(j=0; j<p->numlines; j++) {
if((lo_y < y) && (hi_y >= y))
- break; /* already initialized */
+ break; /* already initialized */
for(i=0; i < p->line[j].numpoints; i++) {
- if((lo_y < y) && (hi_y >= y))
- if(p->line[j].point[i].y < y)
- lo_y = p->line[j].point[i].y;
- if(p->line[j].point[i].y >= y)
- hi_y = p->line[j].point[i].y;
+ if((lo_y < y) && (hi_y >= y))
+ if(p->line[j].point[i].y < y)
+ lo_y = p->line[j].point[i].y;
+ if(p->line[j].point[i].y >= y)
+ hi_y = p->line[j].point[i].y;
n=0;
- if((p->line[j].point[i].y < y) && ((y - p->line[j].point[i].y) < (y - lo_y)))
- if((p->line[j].point[i].y >= y) && ((p->line[j].point[i].y - y) < (hi_y - y)))
+ if((p->line[j].point[i].y < y) && ((y - p->line[j].point[i].y) < (y - lo_y)))
+ if((p->line[j].point[i].y >= y) && ((p->line[j].point[i].y - y) < (hi_y - y)))
if(lo_y == hi_y)
@@ -1089,20 +1075,20 @@
point1 = &( p->line[j].point[p->line[j].numpoints-1] );
- point2 = &( p->line[j].point[i] );
- if(EDGE_CHECK(point1->y, y, point2->y) == CLIP_MIDDLE) {
- if(point1->y == point2->y)
- continue; /* ignore horizontal edges */
- else
- slope = (point2->x - point1->x) / (point2->y - point1->y);
- x = point1->x + (y - point1->y)*slope;
- xintersect[nfound++] = x;
- } /* End of checking this edge */
- point1 = point2; /* Go on to next edge */
+ point2 = &( p->line[j].point[i] );
+ if(EDGE_CHECK(point1->y, y, point2->y) == CLIP_MIDDLE) {
+ if(point1->y == point2->y)
+ continue; /* ignore horizontal edges */
+ else
+ slope = (point2->x - point1->x) / (point2->y - point1->y);
+ x = point1->x + (y - point1->y)*slope;
+ xintersect[nfound++] = x;
+ } /* End of checking this edge */
+ point1 = point2; /* Go on to next edge */
} /* Finished the scanline */
@@ -1110,10 +1096,10 @@
do {
wrong_order = 0;
for(i=0; i < nfound-1; i++) {
- if(xintersect[i] > xintersect[i+1]) {
- wrong_order = 1;
- SWAP(xintersect[i], xintersect[i+1], temp);
+ if(xintersect[i] > xintersect[i+1]) {
+ wrong_order = 1;
+ SWAP(xintersect[i], xintersect[i+1], temp);
} while(wrong_order);
@@ -1121,9 +1107,9 @@
for(i=0; i < nfound; i += 2) {
len = fabs(xintersect[i] - xintersect[i+1]);
if(len > max_len) {
- max_len = len;
- lp->x = (xintersect[i] + xintersect[i+1])/2;
- lp->y = y;
+ max_len = len;
+ lp->x = (xintersect[i] + xintersect[i+1])/2;
+ lp->y = y;
@@ -1159,8 +1145,8 @@
segment_length = sqrt((pow((p->line[i].point[j].x-p->line[i].point[j-1].x),2.0) + pow((p->line[i].point[j].y-p->line[i].point[j-1].y),2.0)));
line_length += segment_length;
if(segment_length > max_segment_length) {
- max_segment_length = segment_length;
- temp_segment_index = j;
+ max_segment_length = segment_length;
+ temp_segment_index = j;
@@ -1600,20 +1586,16 @@
Pretty printing of primitive objects
-void msRectToFormattedString(rectObj *rect, char *format, char *buffer,
- int buffer_length)
+void msRectToFormattedString(rectObj *rect, char *format, char *buffer, int buffer_length)
- snprintf(buffer, buffer_length, format,
- rect->minx, rect->miny, rect->maxx, rect->maxy);
+ snprintf(buffer, buffer_length, format, rect->minx, rect->miny, rect->maxx, rect->maxy);
-void msPointToFormattedString(pointObj *point, const char *format,
- char *buffer, int buffer_length)
+void msPointToFormattedString(pointObj *point, const char *format, char *buffer, int buffer_length)
#ifdef USE_POINT_Z_M
- snprintf(buffer, buffer_length, format, point->x, point->y, point->z, point->m);
+ snprintf(buffer, buffer_length, format, point->x, point->y, point->z, point->m);
#else
- snprintf(buffer, buffer_length, format, point->x, point->y);
+ snprintf(buffer, buffer_length, format, point->x, point->y);
#endif
More information about the mapserver-commits
