[mapserver-commits] r7340 - trunk/mapserver/mapscript/csharp
svn at osgeo.org
svn at osgeo.org
Sat Feb 2 18:42:18 EST 2008
Author: tamas
Date: 2008-02-02 18:42:18 -0500 (Sat, 02 Feb 2008)
New Revision: 7340
trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
Update SVN props
Modified: trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
--- trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2008-02-01 20:42:02 UTC (rev 7339)
+++ trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2008-02-02 23:42:18 UTC (rev 7340)
@@ -1,186 +1,186 @@
- * $Id: $
- * Name: swig_csharp_extensions.i
- * Purpose: Fix for the SWIG Interface problems (early GC)
- * and implementing SWIGTYPE *DISOWN
- * Author: Tamas Szekeres
-%typemap(csout, excode=SWIGEXCODE) SWIGTYPE {
- $&csclassname ret = new $&csclassname($imcall, true, null);$excode
- return ret;
-%typemap(csout, excode=SWIGEXCODE, new="1") SWIGTYPE & {
- $csclassname ret = new $csclassname($imcall, $owner, ThisOwn_$owner());$excode
- return ret;
-%typemap(csout, excode=SWIGEXCODE, new="1") SWIGTYPE *, SWIGTYPE [], SWIGTYPE (CLASS::*) {
- IntPtr cPtr = $imcall;
- $csclassname ret = (cPtr == IntPtr.Zero) ? null : new $csclassname(cPtr, $owner, ThisOwn_$owner());$excode
- return ret;
-%typemap(csvarout, excode=SWIGEXCODE2) SWIGTYPE & %{
- get {
- return ret;
-%typemap(csvarout, excode=SWIGEXCODE2) SWIGTYPE *, SWIGTYPE [], SWIGTYPE (CLASS::*) %{
- get {
- return ret;
-%typemap(csout, excode=SWIGEXCODE) SWIGTYPE *& {
- $*csclassname ret = (cPtr == IntPtr.Zero) ? null : new $*csclassname(cPtr, $owner, ThisOwn_$owner());$excode
- return ret;
-// Proxy classes (base classes, ie, not derived classes)
-%typemap(csbody) SWIGTYPE %{
- private HandleRef swigCPtr;
- protected bool swigCMemOwn;
- protected object swigParentRef;
- protected static object ThisOwn_true() { return null; }
- protected object ThisOwn_false() { return this; }
- internal $csclassname(IntPtr cPtr, bool cMemoryOwn, object parent) {
- swigCMemOwn = cMemoryOwn;
- swigParentRef = parent;
- swigCPtr = new HandleRef(this, cPtr);
- internal static HandleRef getCPtr($csclassname obj) {
- return (obj == null) ? new HandleRef(null, IntPtr.Zero) : obj.swigCPtr;
- internal static HandleRef getCPtrAndDisown($csclassname obj, object parent) {
- if (obj != null)
- obj.swigCMemOwn = false;
- obj.swigParentRef = parent;
- return obj.swigCPtr;
- else
- return new HandleRef(null, IntPtr.Zero);
- internal static HandleRef getCPtrAndSetReference($csclassname obj, object parent) {
- if (obj != null)
- else
-// Derived proxy classes
-%typemap(csbody_derived) SWIGTYPE %{
- internal $csclassname(IntPtr cPtr, bool cMemoryOwn, object parent) : base($modulePINVOKE.$csclassnameUpcast(cPtr), cMemoryOwn, parent) {
- if (obj != null)
- else
- if (obj != null)
- else
-// Typewrapper classes
-%typemap(csbody) SWIGTYPE *, SWIGTYPE &, SWIGTYPE [], SWIGTYPE (CLASS::*) %{
- internal $csclassname(IntPtr cPtr, bool futureUse, object parent) {
- protected $csclassname() {
- swigCPtr = new HandleRef(null, IntPtr.Zero);
-%typemap(csfinalize) SWIGTYPE %{
- ~$csclassname() {
- Dispose();
-%typemap(csconstruct, excode=SWIGEXCODE) SWIGTYPE %{: this($imcall, true, null) {$excode
-%typemap(csdestruct, methodname="Dispose", methodmodifiers="public") SWIGTYPE {
- lock(this) {
- if(swigCPtr.Handle != IntPtr.Zero && swigCMemOwn) {
- swigCMemOwn = false;
- $imcall;
- swigParentRef = null;
- GC.SuppressFinalize(this);
-%typemap(csdestruct_derived, methodname="Dispose", methodmodifiers="public") TYPE {
- lock(this) {
- $imcall;
- base.Dispose();
-%typemap(csin) SWIGTYPE *DISOWN "$csclassname.getCPtrAndDisown($csinput, ThisOwn_false())"
-%typemap(csin) SWIGTYPE *SETREFERENCE "$csclassname.getCPtrAndSetReference($csinput, ThisOwn_false())"
-%pragma(csharp) modulecode=%{
- internal class $moduleObject : IDisposable {
- public virtual void Dispose() {
- internal static $moduleObject the$moduleObject = new $moduleObject();
- protected static object ThisOwn_false() { return the$moduleObject; }
+ * $Id$
+ * Name: swig_csharp_extensions.i
+ * Purpose: Fix for the SWIG Interface problems (early GC)
+ * and implementing SWIGTYPE *DISOWN
+ * Author: Tamas Szekeres
+%typemap(csout, excode=SWIGEXCODE) SWIGTYPE {
+ $&csclassname ret = new $&csclassname($imcall, true, null);$excode
+ return ret;
+%typemap(csout, excode=SWIGEXCODE, new="1") SWIGTYPE & {
+ $csclassname ret = new $csclassname($imcall, $owner, ThisOwn_$owner());$excode
+ return ret;
+%typemap(csout, excode=SWIGEXCODE, new="1") SWIGTYPE *, SWIGTYPE [], SWIGTYPE (CLASS::*) {
+ IntPtr cPtr = $imcall;
+ $csclassname ret = (cPtr == IntPtr.Zero) ? null : new $csclassname(cPtr, $owner, ThisOwn_$owner());$excode
+ return ret;
+%typemap(csvarout, excode=SWIGEXCODE2) SWIGTYPE & %{
+ get {
+ return ret;
+%typemap(csvarout, excode=SWIGEXCODE2) SWIGTYPE *, SWIGTYPE [], SWIGTYPE (CLASS::*) %{
+ get {
+ return ret;
+%typemap(csout, excode=SWIGEXCODE) SWIGTYPE *& {
+ $*csclassname ret = (cPtr == IntPtr.Zero) ? null : new $*csclassname(cPtr, $owner, ThisOwn_$owner());$excode
+ return ret;
+// Proxy classes (base classes, ie, not derived classes)
+%typemap(csbody) SWIGTYPE %{
+ private HandleRef swigCPtr;
+ protected bool swigCMemOwn;
+ protected object swigParentRef;
+ protected static object ThisOwn_true() { return null; }
+ protected object ThisOwn_false() { return this; }
+ internal $csclassname(IntPtr cPtr, bool cMemoryOwn, object parent) {
+ swigCMemOwn = cMemoryOwn;
+ swigParentRef = parent;
+ swigCPtr = new HandleRef(this, cPtr);
+ internal static HandleRef getCPtr($csclassname obj) {
+ return (obj == null) ? new HandleRef(null, IntPtr.Zero) : obj.swigCPtr;
+ internal static HandleRef getCPtrAndDisown($csclassname obj, object parent) {
+ if (obj != null)
+ obj.swigCMemOwn = false;
+ obj.swigParentRef = parent;
+ return obj.swigCPtr;
+ else
+ return new HandleRef(null, IntPtr.Zero);
+ internal static HandleRef getCPtrAndSetReference($csclassname obj, object parent) {
+ if (obj != null)
+ else
+// Derived proxy classes
+%typemap(csbody_derived) SWIGTYPE %{
+ internal $csclassname(IntPtr cPtr, bool cMemoryOwn, object parent) : base($modulePINVOKE.$csclassnameUpcast(cPtr), cMemoryOwn, parent) {
+ if (obj != null)
+ else
+ if (obj != null)
+ else
+// Typewrapper classes
+%typemap(csbody) SWIGTYPE *, SWIGTYPE &, SWIGTYPE [], SWIGTYPE (CLASS::*) %{
+ internal $csclassname(IntPtr cPtr, bool futureUse, object parent) {
+ protected $csclassname() {
+ swigCPtr = new HandleRef(null, IntPtr.Zero);
+%typemap(csfinalize) SWIGTYPE %{
+ ~$csclassname() {
+ Dispose();
+%typemap(csconstruct, excode=SWIGEXCODE) SWIGTYPE %{: this($imcall, true, null) {$excode
+%typemap(csdestruct, methodname="Dispose", methodmodifiers="public") SWIGTYPE {
+ lock(this) {
+ if(swigCPtr.Handle != IntPtr.Zero && swigCMemOwn) {
+ swigCMemOwn = false;
+ $imcall;
+ swigParentRef = null;
+ GC.SuppressFinalize(this);
+%typemap(csdestruct_derived, methodname="Dispose", methodmodifiers="public") TYPE {
+ lock(this) {
+ $imcall;
+ base.Dispose();
+%typemap(csin) SWIGTYPE *DISOWN "$csclassname.getCPtrAndDisown($csinput, ThisOwn_false())"
+%typemap(csin) SWIGTYPE *SETREFERENCE "$csclassname.getCPtrAndSetReference($csinput, ThisOwn_false())"
+%pragma(csharp) modulecode=%{
+ internal class $moduleObject : IDisposable {
+ public virtual void Dispose() {
+ internal static $moduleObject the$moduleObject = new $moduleObject();
+ protected static object ThisOwn_false() { return the$moduleObject; }
Property changes on: trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
___________________________________________________________________
+ Author Date Id Revision
+ native
More information about the mapserver-commits
