[mapserver-commits] r7341 - trunk/mapserver
Sat Feb 2 23:51:38 EST 2008
Author: warmerdam
Date: 2008-02-02 23:51:37 -0500 (Sat, 02 Feb 2008)
New Revision: 7341
   trunk/mapserver/mapows.c
add imageCRS urn support
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2008-02-02 23:42:18 UTC (rev 7340)
+++ trunk/mapserver/mapows.c	2008-02-03 04:51:37 UTC (rev 7341)
@@ -1524,20 +1524,28 @@
         char urn[100];
-        if( strncmp(tokens[i],"EPSG:",5) != 0 )
-            continue;
-        ** Should we eventually use OGC "epsg-like" coordinate systems
-        ** with our normal axis orientation?  Fix later.
-        sprintf( urn, "urn:ogc:def:crs:EPSG::%s", tokens[i]+5 );
+        if( strncmp(tokens[i],"EPSG:",5) == 0 )
+            sprintf( urn, "urn:ogc:def:crs:EPSG::%s", tokens[i]+5 );
+        else if( strcasecmp(tokens[i],"imageCRS") == 0 )
+            sprintf( urn, "urn:ogc:def:crs:OGC::imageCRS" );
+        else if( strncmp(tokens[i],"urn:ogc:def:crs:",16) == 0 )
+            sprintf( urn, tokens[i] );
+        else
+            strcpy( urn, "" );
-        result = (char *) realloc(result,strlen(result)+strlen(urn)+2);
-        if( strlen(result) > 0 )
-            strcat( result, " " );
-        strcat( result, urn );
+        if( strlen(urn) > 0 )
+            result = (char *) realloc(result,strlen(result)+strlen(urn)+2);
+            if( strlen(result) > 0 )
+                strcat( result, " " );
+            strcat( result, urn );
+        else
+            msDebug( "msOWSGetProjURN(): Failed to process SRS '%s', ignored.",
+                     tokens[i] );
     msFreeCharArray(tokens, numtokens);
