[mapserver-commits] r7653 - trunk/mapserver
Sat Jun 7 01:22:07 EDT 2008
Author: sdlime
Date: 2008-06-07 01:22:07 -0400 (Sat, 07 Jun 2008)
New Revision: 7653
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapserv.c
   trunk/mapserver/maptemplate.c
   trunk/mapserver/maptemplate.h
Fixed output when map->web->queryformat references a image format (e.g. PNG), RFC36 work...
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-06 19:34:34 UTC (rev 7652)
+++ trunk/mapserver/HISTORY.TXT	2008-06-07 05:22:07 UTC (rev 7653)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- WMS/WFS layers can now specify a proxy servert (#571)
 - mapwmslayer.c: set QUERY_LAYERS correctly (#2001)
 - mapwcs.c: handle PARAMETER values correctly (#2509)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2008-06-06 19:34:34 UTC (rev 7652)
+++ trunk/mapserver/mapserv.c	2008-06-07 05:22:07 UTC (rev 7653)
@@ -1361,7 +1361,7 @@
         writeError();
       if(QueryFile) {
-        if(msReturnQuery(mapserv, mapserv->map->web.queryformat, NULL) != MS_SUCCESS)
+        if(msReturnTemplateQuery(mapserv, mapserv->map->web.queryformat, NULL) != MS_SUCCESS)
           writeError();
       } else {
         if(TEMPLATE_TYPE(mapserv->map->web.template) == MS_FILE) { /* if thers's an html template, then use it */
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2008-06-06 19:34:34 UTC (rev 7652)
+++ trunk/mapserver/maptemplate.c	2008-06-07 05:22:07 UTC (rev 7653)
@@ -182,7 +182,6 @@
   imageObj *img = NULL;
   int i, status;
-  char buffer[1024];
   outputFormatObj *outputFormat=NULL;
@@ -202,53 +201,34 @@
   if(outputFormat) {
      if( !MS_RENDERER_TEMPLATE(outputFormat) ) { /* got an image format, return the query results that way */
-      printf("got an image output format\n");
-      return MS_SUCCESS;
+       outputFormatObj *tempOutputFormat = mapserv->map->outputformat; /* save format */
+       checkWebScale(mapserv);
+       mapserv->map->outputformat = outputFormat; /* override what was given for IMAGETYPE */
+       img = msDrawMap(mapserv->map, MS_TRUE);
+       if(!img) return MS_FAILURE;
+       mapserv->map->outputformat = tempOutputFormat; /* restore format */
+       if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(outputFormat), 10,10);
+       status = msSaveImage(mapserv->map, img, NULL);
+       msFreeImage(img);
+       return status;
   ** At this point we know we have a template of some sort, either the new style that references a or the old
   ** style made up of external files slammed together. Either way we may have to compute a query map and other
-  ** images potentially.
+  ** images. We only create support images IF the querymap has status=MS_ON.
   if(mapserv->map->querymap.status) {
-    img = msDrawMap(mapserv->map, MS_TRUE);
-    if(!img) return MS_FAILURE;
-    snprintf(buffer, 1024, "%s%s%s.%s", mapserv->map->web.imagepath, mapserv->map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->map->outputformat));
-    status = msSaveImage(mapserv->map, img, buffer);
-    if(status != MS_SUCCESS) return status;
-    msFreeImage(img);
-    if((mapserv->map->legend.status == MS_ON || mapserv->UseShapes) && mapserv->map->legend.template == NULL) {
-      img = msDrawLegend(mapserv->map, MS_FALSE);
-      snprintf(buffer, 1024, "%s%sleg%s.%s", mapserv->map->web.imagepath, mapserv->map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->map->outputformat));
-      msFreeImage(img);
-    if(mapserv->map->scalebar.status == MS_ON) {
-      img = msDrawScalebar(mapserv->map);
-      snprintf(buffer, 1024, "%s%ssb%s.%s", mapserv->map->web.imagepath, mapserv->map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->map->outputformat));
-      status = msSaveImage( mapserv->map, img, buffer);
-      msFreeImage(img);
-    if(mapserv->map->reference.status == MS_ON) {
-      img = msDrawReferenceMap(mapserv->map);
-      snprintf(buffer, 1024, "%s%sref%s.%s", mapserv->map->web.imagepath, mapserv->map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->map->outputformat));
-      msFreeImage(img);
+    msGenerateImages(mapserv, MS_FALSE, MS_TRUE);
+  /* initialize the buffer if necessary */
   if(outputFormat) {
     const char *file = msGetOutputFormatOption( outputFormat, "FILE", NULL );
@@ -261,7 +241,7 @@
     if((status = msReturnPage(mapserv, (char *) file, BROWSE, papszBuffer)) != MS_SUCCESS)
       return status;
   } else {
-    if((status = msReturnQuery(mapserv, queryFormat, papszBuffer)) != MS_SUCCESS)
+    if((status = msReturnNestedTemplateQuery(mapserv, queryFormat, papszBuffer)) != MS_SUCCESS)
       return status;
@@ -3499,7 +3479,10 @@
   return MS_SUCCESS;
-int msReturnQuery(mapservObj* mapserv, char* pszMimeType, char **papszBuffer)
+** Legacy query template parsing where you use headers, footers and such...
+int msReturnNestedTemplateQuery(mapservObj* mapserv, char* pszMimeType, char **papszBuffer)
   int status;
   int i,j,k;
@@ -3518,7 +3501,7 @@
   /* if(!pszMimeType) {
-    msSetError(MS_WEBERR, "Mime type not specified.", "msReturnQuery()");
+    msSetError(MS_WEBERR, "Mime type not specified.", "msReturnNestedTemplateQuery()");
     return MS_FAILURE;
@@ -3549,7 +3532,7 @@
         template = lp->template;
       if( template == NULL ) {
-        msSetError(MS_WEBERR, "No template for layer %s or it's classes.", "msReturnQuery()", lp->name );
+        msSetError(MS_WEBERR, "No template for layer %s or it's classes.", "msReturnNestedTemplateQuery()", lp->name );
         return MS_FAILURE;
@@ -3999,7 +3982,7 @@
 ** Utility function that process a template file(s) used in the
-** query and retrun the processed template(s) in a bufffer.
+** query and return the processed template(s) in a buffer.
 char *msProcessQueryTemplate(mapObj *map, int bGenerateImages, char **names, char **values, int numentries)
@@ -4021,9 +4004,9 @@
     if(bGenerateImages)
-      msGenerateImages(mapserv, MS_FALSE, MS_FALSE); /* second parameter should be MS_TRUE I believe - SDL - */
-    msReturnQuery(mapserv, NULL, &pszBuffer );
+    msReturnTemplateQuery(mapserv, NULL, &pszBuffer );
     mapserv->map = NULL;
     mapserv->request->ParamNames = mapserv->request->ParamValues = NULL;
Modified: trunk/mapserver/maptemplate.h
--- trunk/mapserver/maptemplate.h	2008-06-06 19:34:34 UTC (rev 7652)
+++ trunk/mapserver/maptemplate.h	2008-06-07 05:22:07 UTC (rev 7653)
@@ -136,11 +136,9 @@
 MS_DLL_EXPORT int msReturnPage(mapservObj* msObj, char* , int, char **);
 MS_DLL_EXPORT int msReturnURL(mapservObj* msObj, char*, int);
-MS_DLL_EXPORT int msReturnQuery(mapservObj* msObj, char* pszMimeType, char **papszBuffer);
+MS_DLL_EXPORT int msReturnNestedTemplateQuery(mapservObj* msObj, char* pszMimeType, char **papszBuffer);
+MS_DLL_EXPORT int msReturnTemplateQuery(mapservObj *msObj, char* pszMimeType,  char **papszBuffer);
-MS_DLL_EXPORT int msReturnTemplateQuery(mapservObj *msObj, char* pszMimeType,
-                          char **papszBuffer);
 MS_DLL_EXPORT int msRedirect(char* url);
 MS_DLL_EXPORT char *generateLegendTemplate(mapservObj *msObj);
