[mapserver-commits] r7654 - trunk/mapserver
Sat Jun 7 02:08:57 EDT 2008
Author: sdlime
Date: 2008-06-07 02:08:55 -0400 (Sat, 07 Jun 2008)
New Revision: 7654
   trunk/mapserver/maptemplate.c
Added -buffer option to [shpxy ...] as suggested by Jim Klassen. Only available if MapServer is compiled with GEOS support.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2008-06-07 05:22:07 UTC (rev 7653)
+++ trunk/mapserver/maptemplate.c	2008-06-07 06:08:55 UTC (rev 7654)
@@ -1421,6 +1421,9 @@
   int centroid=MS_FALSE; /* output just the centroid */
   int precision=0;
+  double buffer=0; /* no buffer */
+  int bufferUnits=-1;
   shapeObj tShape;
   char *projectionString=NULL;
@@ -1476,6 +1479,12 @@
       argValue = msLookupHashTable(tagArgs, "sf");
       if(argValue) sf = argValue;
+      argValue = msLookupHashTable(tagArgs, "buffer");
+      if(argValue) {
+        buffer = atof(argValue);
+        if(strstr(argValue, "px")) bufferUnits = MS_PIXELS; /* may support others at some point */
       argValue = msLookupHashTable(tagArgs, "precision");
       if(argValue) precision = atoi(argValue);
@@ -1509,13 +1518,24 @@
       tShape.line[0].numpoints = 0;
       msAddPointToLine(&(tShape.line[0]), &p);
-    } else {
+#ifdef USE_GEOS
+    else if(buffer != 0 && bufferUnits != MS_PIXELS) {
+      shapeObj bufferShape=NULL;
+      bufferShape = msGEOSBuffer(shape, buffer);
+      if(!bufferShape) return(MS_FAILURE); /* buffer failed */
+      msCopyShape(bufferShape, &tShape);
+      msFreeShape(bufferShape);
+#endif
+    else {
       status = msCopyShape(shape, &tShape);
       if(status != 0) return(MS_FAILURE); /* copy failed */
     /* no big deal to convert from file to image coordinates, but what are the image parameters */
-    if(projectionString && strcasecmp(projectionString,"image") ==0) {
+    if(projectionString && strcasecmp(projectionString,"image") == 0) {
       precision = 0;
       /* if necessary, project the shape to match the map */
@@ -1540,6 +1560,19 @@
         break;
       msTransformShapeToPixel(&tShape, layer->map->extent, layer->map->cellsize);
+#ifdef USE_GEOS
+      if(buffer != 0 && bufferUnits == MS_PIXELS) {
+	bufferShape = msGEOSBuffer(tShape, buffer);
+	msFreeShape(&tShape); /* avoid memory leak */
+#endif
     } else if(projectionString) {
        projectionObj projection;
        msInitProjection(&projection);
