[mapserver-commits] r7669 - in trunk/msautotest/wxs: . expected
Thu Jun 12 18:52:04 EDT 2008
Author: tomkralidis
Date: 2008-06-12 18:52:04 -0400 (Thu, 12 Jun 2008)
New Revision: 7669
   trunk/msautotest/wxs/expected/wfs_caps_updatesequence.xml
   trunk/msautotest/wxs/wfs_simple.map
remove version from expected result
Modified: trunk/msautotest/wxs/expected/wfs_caps_updatesequence.xml
--- trunk/msautotest/wxs/expected/wfs_caps_updatesequence.xml	2008-06-11 21:36:45 UTC (rev 7668)
+++ trunk/msautotest/wxs/expected/wfs_caps_updatesequence.xml	2008-06-12 22:52:04 UTC (rev 7669)
@@ -9,8 +9,6 @@
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://www.opengis.net/wfs http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-capabilities.xsd">
-<!-- MapServer version 5.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
 <Service>
   <Name>MapServer WFS</Name>
   <Title>Test simple wfs</Title>
Modified: trunk/msautotest/wxs/wfs_simple.map
--- trunk/msautotest/wxs/wfs_simple.map	2008-06-11 21:36:45 UTC (rev 7668)
+++ trunk/msautotest/wxs/wfs_simple.map	2008-06-12 22:52:04 UTC (rev 7669)
@@ -7,7 +7,7 @@
 # RUN_PARMS: wfs_exception.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0" > [RESULT]
 # Capabilities updatesequence (less than)
-# RUN_PARMS: wfs_caps_updatesequence.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities&updatesequence=12" > [RESULT]
+# RUN_PARMS: wfs_caps_updatesequence.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities&updatesequence=12" > [RESULT_DEVERSION]
 # Capabilities updatesequence exception (equal)
 # RUN_PARMS: wfs_exception_updatesequence1.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities&updatesequence=123" > [RESULT]
