[mapserver-commits] r7670 - in trunk/msautotest/wxs: . expected
svn at osgeo.org
svn at osgeo.org
Thu Jun 12 20:55:16 EDT 2008
Author: tomkralidis
Date: 2008-06-12 20:55:16 -0400 (Thu, 12 Jun 2008)
New Revision: 7670
trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml
trunk/msautotest/wxs/wms_simple.map
remove version from test
Modified: trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml
--- trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml 2008-06-12 22:52:04 UTC (rev 7669)
+++ trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml 2008-06-13 00:55:16 UTC (rev 7670)
@@ -8,8 +8,6 @@
<WMT_MS_Capabilities version="1.1.1" updateSequence="123">
-<!-- MapServer version 5.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>Test simple wms</Title>
Modified: trunk/msautotest/wxs/wms_simple.map
--- trunk/msautotest/wxs/wms_simple.map 2008-06-12 22:52:04 UTC (rev 7669)
+++ trunk/msautotest/wxs/wms_simple.map 2008-06-13 00:55:16 UTC (rev 7670)
@@ -11,7 +11,7 @@
# RUN_PARMS: wms_version_exception.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1" > [RESULT]
# Capabilities updatesequence (less than)
-# RUN_PARMS: wms_caps_updatesequence.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities&updatesequence=15" > [RESULT]
+# RUN_PARMS: wms_caps_updatesequence.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities&updatesequence=15" > [RESULT_DEVERSION]
# Capabilities updatesequence exception (equal)
# RUN_PARMS: wms_exception_updatesequence1.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities&updatesequence=123" > [RESULT]
More information about the mapserver-commits
