[mapserver-commits] r7680 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Jun 14 14:49:40 EDT 2008
Author: tomkralidis
Date: 2008-06-14 14:49:39 -0400 (Sat, 14 Jun 2008)
New Revision: 7680
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwfs.c
trunk/mapserver/mapwfs11.c
set output GML MIME type correctly
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-14 17:41:11 UTC (rev 7679)
+++ trunk/mapserver/HISTORY.TXT 2008-06-14 18:49:39 UTC (rev 7680)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- mapwfs.c/mapwfs11.c: set GML MIME type correctly
- mapogcsos.c: advertise supported SRS list via
MAP.WEB.METADATA.sos_srs (#2414)
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c 2008-06-14 17:41:11 UTC (rev 7679)
+++ trunk/mapserver/mapwfs.c 2008-06-14 18:49:39 UTC (rev 7680)
@@ -1125,7 +1125,7 @@
if (szBuf != NULL) {
if (msLoadProjectionString(&(map->projection), szBuf) != 0) {
- msSetError(MS_WFSERR, "msLoadProjectionString() failed2: %s", "msWFSGetFeature()", szBuf);
+ msSetError(MS_WFSERR, "msLoadProjectionString() failed: %s", "msWFSGetFeature()", szBuf);
return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
@@ -1171,7 +1171,7 @@
if(paramsObj->pszVersion == NULL || strncmp(paramsObj->pszVersion,"1.1",3) == 0 )
outputformat = OWS_GML3;
- output_schema_format = "text/gml; subtype=gml/3.1.1";
+ output_schema_format = "text/xml; subtype=gml/3.1.1";
/* else if (strcasecmp(names[i], "PROPERTYNAME") == 0) */
Modified: trunk/mapserver/mapwfs11.c
--- trunk/mapserver/mapwfs11.c 2008-06-14 17:41:11 UTC (rev 7679)
+++ trunk/mapserver/mapwfs11.c 2008-06-14 18:49:39 UTC (rev 7680)
@@ -331,7 +331,7 @@
/*output format*/
xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,
"Parameter", "outputFormat",
- "XMLSCHEMA,text/xml; subtype=gml/2.1.2,text/gml; subtype=gml/3.1.1"));
+ "XMLSCHEMA,text/xml; subtype=gml/2.1.2,text/xml; subtype=gml/3.1.1"));
/* GetFeatureType */
@@ -352,7 +352,7 @@
- "text/gml; subtype=gml/3.1.1"));
+ "text/xml; subtype=gml/3.1.1"));
/* FeatureTypeList */
More information about the mapserver-commits
