[mapserver-commits] r7681 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jun 16 10:07:18 EDT 2008
Author: tomkralidis
Date: 2008-06-16 10:07:18 -0400 (Mon, 16 Jun 2008)
New Revision: 7681
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.h
trunk/mapserver/mapmssql2008.c
trunk/mapserver/mapows.c
trunk/mapserver/mapparser.c
Remove C++-style comments and most other warnings thrown by -pedantic (#2598)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-14 18:49:39 UTC (rev 7680)
+++ trunk/mapserver/HISTORY.TXT 2008-06-16 14:07:18 UTC (rev 7681)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- Remove C++-style comments and most other warnings thrown by -pedantic (#2598)
- mapwfs.c/mapwfs11.c: set GML MIME type correctly
- mapogcsos.c: advertise supported SRS list via
Modified: trunk/mapserver/mapagg.h
--- trunk/mapserver/mapagg.h 2008-06-14 18:49:39 UTC (rev 7680)
+++ trunk/mapserver/mapagg.h 2008-06-16 14:07:18 UTC (rev 7681)
@@ -75,7 +75,7 @@
AGG_INLINE T* buf() { return m_buf; }
AGG_INLINE const T* buf() const { return m_buf; }
AGG_INLINE unsigned width() const { return m_width; }
@@ -86,7 +86,7 @@
return (m_stride < 0) ? unsigned(-m_stride) : unsigned(m_stride);
AGG_INLINE T* row_ptr(int, int y, unsigned)
return m_rows[y];
@@ -98,10 +98,10 @@
return row_data(0, m_width-1, m_rows[y]);
T const* const* rows() const { return &m_rows[0]; }
template<class RenBuf>
void copy_from(const RenBuf& src)
@@ -121,7 +121,7 @@
void clear(T value)
unsigned y;
@@ -139,12 +139,12 @@
private:
- T* m_buf; // Pointer to rendering buffer
- agg::pod_array<T*> m_rows; // Pointers to each row of the buffer
- unsigned m_width; // Width in pixels
- unsigned m_height; // Height in pixels
- int m_stride; // Number of bytes per row. Can be < 0
+ T* m_buf; /* Pointer to rendering buffer */
+ agg::pod_array<T*> m_rows; /* Pointers to each row of the buffer */
+ unsigned m_width; /* Width in pixels */
+ unsigned m_height; /* Height in pixels */
+ int m_stride; /* Number of bytes per row. Can be < 0 */
@@ -161,7 +161,7 @@
m_pend=&(m_line->point[m_line->numpoints]); /*pointer to after last vertex of first line*/
- //a class with virtual functions should also provide a virtual destructor
+ /* a class with virtual functions should also provide a virtual destructor */
virtual ~line_adaptor() {}
void rewind(unsigned) {
@@ -232,7 +232,7 @@
virtual ~polygon_adaptor() {}
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c 2008-06-14 18:49:39 UTC (rev 7680)
+++ trunk/mapserver/mapmssql2008.c 2008-06-16 14:07:18 UTC (rev 7681)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
* Project: MapServer
* Purpose: MS SQL 2008 (Katmai) Layer Connector
@@ -51,7 +51,7 @@
MS_CVSID("$Id$")
-// Structure for connection to an ODBC database (Microsoft preferred way to connect to SQL Server 2005 from c/c++)
+/* Structure for connection to an ODBC database (Microsoft preferred way to connect to SQL Server 2005 from c/c++) */
typedef struct msODBCconn_t
SQLHENV henv; /* ODBC HENV */
@@ -84,7 +84,7 @@
"For more help, please see http://www.mapdotnet.com \n\n<br><br>" \
"mapmssql2008.c - version of 2007/7/1.\n"
-// Little dummy buffer used to clean up memory allocation
+/* Little dummy buffer used to clean up memory allocation */
char dummyBuffer[1];
msMSSQL2008LayerInfo *getMSSQL2008LayerInfo(const layerObj *layer)
@@ -164,7 +164,7 @@
static int msMSSQL2008LayerParseData(layerObj *layer, char **geom_column_name, char **table_name, char **urid_name, char **user_srid, char **index_name, int debug);
-// Close connection and handles
+/* Close connection and handles */
static void msMSSQL2008CloseConnection(void *conn_handle)
msODBCconn * conn = (msODBCconn *) conn_handle;
@@ -191,7 +191,7 @@
free(conn);
-// Set the error string for the connection
+/* Set the error string for the connection */
static void setConnError(msODBCconn *conn)
SQLSMALLINT len;
@@ -201,7 +201,7 @@
conn->errorMessage[len] = 0;
-// Connect to db
+/* Connect to db */
static msODBCconn * mssql2008Connect(const char * connString)
char fullConnString[1024];
@@ -242,7 +242,7 @@
return conn;
-// Set the error string for the statement execution
+/* Set the error string for the statement execution */
static void setStmntError(msODBCconn *conn)
SQLSMALLINT len;
@@ -252,7 +252,7 @@
-// Execute SQL against connection. Set error string if failed
+/* Execute SQL against connection. Set error string if failed */
static int executeSQL(msODBCconn *conn, const char * sql)
SQLRETURN rc;
@@ -272,7 +272,7 @@
-// Get columns name from query results
+/* Get columns name from query results */
static int columnName(msODBCconn *conn, int index, char *buffer, int bufferLength)
SQLRETURN rc;
@@ -474,7 +474,7 @@
return MS_SUCCESS;
-// Prepare and execute the SQL statement for this layer
+/* Prepare and execute the SQL statement for this layer */
static int prepare_database(layerObj *layer, rectObj rect, char **query_string)
msMSSQL2008LayerInfo *layerinfo;
@@ -489,7 +489,7 @@
Plus SRID + comma - if SRID is a long...we'll be safe with 10 chars
char box3d[40 + 10 * 17 + 11];
- char query_string_temp[10000]; // Should be big enough
+ char query_string_temp[10000]; /* Should be big enough */
int t;
char *pos_from, *pos_ftab, *pos_space, *pos_paren;
@@ -564,7 +564,7 @@
columns_wanted = _strdup(buffer);
- sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", // %s.STSrid)",
+ sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", /* %s.STSrid)", */
rect.minx, rect.miny,
rect.maxx, rect.miny,
rect.maxx, rect.maxy,
@@ -608,10 +608,10 @@
data_source = (char *)geom_table;
- // use the index hint if provided
+ /* use the index hint if provided */
if ( layerinfo->index_name )
- // given the template - figure out how much to malloc and malloc it
+ /* given the template - figure out how much to malloc and malloc it */
char *with_template = "%s WITH (INDEX(%s))";
int need_len = strlen(data_source) + strlen(with_template) + strlen(layerinfo->index_name);
char *tmp = (char*) malloc( need_len + 1 );
@@ -653,7 +653,7 @@
-// Execute SQL query for this layer
+/* Execute SQL query for this layer */
int msMSSQL2008LayerWhichShapes(layerObj *layer, rectObj rect)
msMSSQL2008LayerInfo *layerinfo = 0;
@@ -1213,11 +1213,11 @@
char *wkbBuffer;
char *valueBuffer;
- char oidBuffer[ 16 ]; // assuming the OID will always be a long this should be enough
+ char oidBuffer[ 16 ]; /* assuming the OID will always be a long this should be enough */
long record_oid;
int t;
- // for coercing single types into geometry collections
+ /* for coercing single types into geometry collections */
char *wkbTemp;
int geomType;
@@ -1239,12 +1239,12 @@
while(shape->type == MS_SHAPE_NULL)
- // SQLRETURN rc = SQLFetchScroll(layerinfo->conn->hstmt, SQL_FETCH_ABSOLUTE, (SQLINTEGER) (*record) + 1);
+ /* SQLRETURN rc = SQLFetchScroll(layerinfo->conn->hstmt, SQL_FETCH_ABSOLUTE, (SQLINTEGER) (*record) + 1); */
- // We only do forward fetches. the parameter 'record' is ignored, but is incremented
+ /* We only do forward fetches. the parameter 'record' is ignored, but is incremented */
SQLRETURN rc = SQLFetch(layerinfo->conn->hstmt);
- // Any error assume out of recordset bounds
+ /* Any error assume out of recordset bounds */
if (rc != SQL_SUCCESS && rc != SQL_SUCCESS_WITH_INFO)
return MS_DONE;
@@ -1259,10 +1259,10 @@
for(t=0; t < layer->numitems; t++)
- // figure out how big the buffer needs to be
+ /* figure out how big the buffer needs to be */
rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
- // allocate the buffer - this will be a null-terminated string so alloc for the null too
+ /* allocate the buffer - this will be a null-terminated string so alloc for the null too */
valueBuffer = (char*) malloc( needLen + 1 );
if ( valueBuffer == NULL )
@@ -1270,25 +1270,25 @@
return MS_FAILURE;
- // Now grab the data
+ /* Now grab the data */
rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, valueBuffer, needLen, &retLen);
- // Terminate the buffer
+ /* Terminate the buffer */
valueBuffer[retLen] = 0; /* null terminate it */
- // Pop the value into the shape's value array
+ /* Pop the value into the shape's value array */
shape->values[t] = valueBuffer;
- // Get shape geometry
+ /* Get shape geometry */
- // Set up to request the size of the buffer needed
+ /* Set up to request the size of the buffer needed */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
- // allow space for coercion to geometry collection if needed
+ /* allow space for coercion to geometry collection if needed
wkbTemp = (char*)malloc(needLen+9);
- // write data above space allocated for geometry collection coercion
+ /* write data above space allocated for geometry collection coercion */
wkbBuffer = wkbTemp + 9;
if ( wkbBuffer == NULL )
@@ -1297,25 +1297,25 @@
return MS_FAILURE;
- // Grab the WKB
+ /* Grab the WKB */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, wkbBuffer, needLen, &retLen);
memcpy(&geomType, wkbBuffer + 1, 4);
- // is this a single type?
+ /* is this a single type? */
if (geomType < 4)
- // copy byte order marker (although we don't check it)
+ /* copy byte order marker (although we don't check it) */
wkbTemp[0] = wkbBuffer[0];
wkbBuffer = wkbTemp;
- // indicate type is geometry collection (although geomType + 3 would also work)
+ /* indicate type is geometry collection (although geomType + 3 would also work) */
wkbBuffer[1] = (char)7;
wkbBuffer[2] = (char)0;
wkbBuffer[3] = (char)0;
wkbBuffer[4] = (char)0;
- // indicate 1 shape
+ /* indicate 1 shape */
wkbBuffer[5] = (char)1;
wkbBuffer[6] = (char)0;
wkbBuffer[7] = (char)0;
@@ -1358,7 +1358,7 @@
free(wkbTemp);
- // Next get unique id for row - since the OID shouldn't be larger than a long we'll assume billions as a limit
+ /* Next get unique id for row - since the OID shouldn't be larger than a long we'll assume billions as a limit */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 2, SQL_C_BINARY, oidBuffer, sizeof(oidBuffer) - 1, &retLen);
oidBuffer[retLen] = 0;
record_oid = strtol(oidBuffer, NULL, 10);
@@ -1376,7 +1376,7 @@
msDebug("msMSSQL2008LayerGetShapeRandom bad shape: %d\n", *record);
- // if (layer->type == MS_LAYER_POINT) {return MS_DONE;}
+ /* if (layer->type == MS_LAYER_POINT) {return MS_DONE;} */
@@ -1448,7 +1448,7 @@
- // index_name is ignored here since the hint should be for the spatial index, not the PK index
+ /* index_name is ignored here since the hint should be for the spatial index, not the PK index */
snprintf(buffer, sizeof(buffer), "select %s from %s where %s = %d", columns_wanted, layerinfo->geom_table, layerinfo->urid_name, record);
query_str = _strdup(buffer);
@@ -1568,7 +1568,7 @@
return MS_SUCCESS;
-// Get primary key column of table
+/* Get primary key column of table */
int msMSSQL2008LayerRetrievePK(layerObj *layer, char **urid_name, char* table_name, int debug)
@@ -1601,7 +1601,7 @@
return(MS_FAILURE);
- // error somewhere above here in this method
+ /* error somewhere above here in this method */
if(!executeSQL(layerinfo->conn, sql))
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c 2008-06-14 18:49:39 UTC (rev 7680)
+++ trunk/mapserver/mapows.c 2008-06-16 14:07:18 UTC (rev 7681)
@@ -566,7 +566,7 @@
if ((result = msOWSLookupMetadata(pri, namespaces, name)) == NULL)
- // Try the secondary table
+ /* Try the secondary table */
result = msOWSLookupMetadata(sec, namespaces, name);
Modified: trunk/mapserver/mapparser.c
--- trunk/mapserver/mapparser.c 2008-06-14 18:49:39 UTC (rev 7680)
+++ trunk/mapserver/mapparser.c 2008-06-16 14:07:18 UTC (rev 7681)
@@ -1497,7 +1497,7 @@
bufferp=delim+1;
- if(strcmp(yyvsp[-2].strval,bufferp) == 0) // is this test necessary?
+ if(strcmp(yyvsp[-2].strval,bufferp) == 0) /* is this test necessary? */
yyval.intval = MS_TRUE;
free(yyvsp[-2].strval);
free(yyvsp[0].strval);
@@ -1522,7 +1522,7 @@
bufferp=delim+1;
- if(yyvsp[-2].dblval == atof(bufferp)) // is this test necessary?
+ if(yyvsp[-2].dblval == atof(bufferp)) /* is this test necessary? */
More information about the mapserver-commits
