[mapserver-commits] r7685 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Jun 17 12:01:49 EDT 2008
Author: tomkralidis
Date: 2008-06-17 12:01:49 -0400 (Tue, 17 Jun 2008)
New Revision: 7685
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maplibxml2.c
trunk/mapserver/maplibxml2.h
helper functions XML POST fix (#2379)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-16 23:22:39 UTC (rev 7684)
+++ trunk/mapserver/HISTORY.TXT 2008-06-17 16:01:49 UTC (rev 7685)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- maplibxml2.c: helper functions XML POST fix (#2379)
- mapwfs.c: fix segfault when srsName is not passed on BBOX Filter (#2644)
- mapwfs.c: do not return error for empty query results (#2444)
Modified: trunk/mapserver/maplibxml2.c
--- trunk/mapserver/maplibxml2.c 2008-06-16 23:22:39 UTC (rev 7684)
+++ trunk/mapserver/maplibxml2.c 2008-06-17 16:01:49 UTC (rev 7685)
@@ -75,10 +75,9 @@
* @return result xmlXPathObjectPtr pointer
-xmlXPathObjectPtr msLibXml2GetXPath(xmlDocPtr doc, xmlXPathContextPtr context, xmlChar *xpath){
+xmlXPathObjectPtr msLibXml2GetXPath(xmlDocPtr doc, xmlXPathContextPtr context, xmlChar *xpath) {
xmlXPathObjectPtr result;
result = xmlXPathEval(xpath, context);
if (result == NULL) {
@@ -91,4 +90,32 @@
return result;
+ * msLibXml2GetXPathTree
+ * Convenience function to fetch an XPath and children
+ * @param xmlDocPtr doc the XML doc pointer
+ * @param xmlXPathObjectPtr the xpath object
+ * @return result string
+const char *msLibXml2GetXPathTree(xmlDocPtr doc, xmlXPathObjectPtr xpath) {
+ xmlBufferPtr xbuf;
+ const char *result = NULL;
+ xbuf = xmlBufferCreate();
+ if (xpath) {
+ if (xmlNodeDump(xbuf, doc, xpath->nodesetval->nodeTab[0], 0, 0) == -1) {
+ return NULL;
+ result = strdup((char *)xbuf->content);
+ xmlBufferFree(xbuf);
+ return result;
#endif /* defined(USE_LIBXML2) */
Modified: trunk/mapserver/maplibxml2.h
--- trunk/mapserver/maplibxml2.h 2008-06-16 23:22:39 UTC (rev 7684)
+++ trunk/mapserver/maplibxml2.h 2008-06-17 16:01:49 UTC (rev 7685)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
* Project: MapServer
* Purpose: libxml2 convenience wrapper functions include file
@@ -41,6 +41,8 @@
void msLibXml2GenerateList(xmlNodePtr psParent, xmlNsPtr psNs, const char *elname, const char *values, char delim);
+const char *msLibXml2GetXPathTree(xmlDocPtr doc, xmlXPathObjectPtr xpath);
#endif /* MAPLIBXML2_H */
More information about the mapserver-commits
