[mapserver-commits] r7686 - trunk/mapserver
Tue Jun 17 12:30:38 EDT 2008
Author: tomkralidis
Date: 2008-06-17 12:30:38 -0400 (Tue, 17 Jun 2008)
New Revision: 7686
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcsos.c
fix POST support (#2379)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-17 16:01:49 UTC (rev 7685)
+++ trunk/mapserver/HISTORY.TXT	2008-06-17 16:30:38 UTC (rev 7686)
@@ -13,6 +13,8 @@
 Current Version (SVN trunk):
+- mapogcsos.c: fix POST support (#2379)
 - maplibxml2.c: helper functions XML POST fix (#2379)
 - mapwfs.c: fix segfault when srsName is not passed on BBOX Filter (#2644)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2008-06-17 16:01:49 UTC (rev 7685)
+++ trunk/mapserver/mapogcsos.c	2008-06-17 16:30:38 UTC (rev 7686)
@@ -1978,7 +1978,7 @@
       msFreeCharArray(apszTimes, numtimes);
     if (!pszTimeString) {
-      msSetError(MS_SOSERR, "Invalid time value given for the eventTime parameter", "msSOSGetObservation()", sosparams->pszObservedProperty);
+      msSetError(MS_SOSERR, "Invalid time value given for the eventTime parameter %s", "msSOSGetObservation()", sosparams->pszEventTime);
       return msSOSException(map, "eventtime", "InvalidParameterValue");
     for (i=0; i<map->numlayers; i++) {
@@ -2030,34 +2030,27 @@
       return msSOSException(map, "featureofinterest", "InvalidParameterValue");
     CPLStripXMLNamespace(psRoot, "gml", 1);
     bValid = FLTParseGMLEnvelope(psRoot, &sBbox, &pszSRS);
-    /*TODO we should reproject the bbox to the map projection if there is an srs defined*/
+    /* TODO we should reproject the bbox to the map projection if there is an srs defined */
     if (!bValid) {
-            msSetError(MS_SOSERR, "Invalid gml:Envelope value given for featureOfInterest .", "msSOSGetObservation()");
+            msSetError(MS_SOSERR, "Invalid gml:Envelope value given for featureOfInterest %s.", "msSOSGetObservation()", sosparams->pszEventTime);
         map->extent.minx = sBbox.minx;
         map->extent.miny = sBbox.miny;
         map->extent.maxx = sBbox.maxx;
         map->extent.maxy = sBbox.maxy;
-  if (sosparams->pszSrsName) {
-    // validate SRS
-    // reproject output to this SRS later on..
   /* apply filter */
   if (sosparams->pszResult) {
     psFilterNode = FLTParseFilterEncoding(sosparams->pszResult);
     if (!psFilterNode) {
-      msSetError(MS_SOSERR, "Invalid or Unsupported FILTER in GetObservation", "msSOSGetObservation()");
-      return msSOSException(map, "filter", "InvalidParameterValue");
+      msSetError(MS_SOSERR, "Invalid or Unsupported RESULT in GetObservation: %s", "msSOSGetObservation()", sosparams->pszResult);
+      return msSOSException(map, "result", "InvalidParameterValue");
     /* apply the filter to all layers that are on */
@@ -2069,8 +2062,8 @@
           (there is a corresponding layer attribute) */
         if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS) {
           if (msSOSValidateFilter(psFilterNode, lp)== MS_FALSE) {
-            msSetError(MS_SOSERR, "Invalid component name in ogc filter statement", "msSOSGetObservation()");
+            msSetError(MS_SOSERR, "Invalid component name in RESULT statement", "msSOSGetObservation()");
           msLayerClose(lp);
@@ -2126,7 +2119,7 @@
     xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/swe/1.0.1", BAD_CAST "swe"));
     xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX));
     xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX));
-    xmlSetNs(psRootNode,   xmlNewNs(psRootNode, BAD_CAST pszSOSNamespaceUri, BAD_CAST pszSOSNamespacePrefix));
+    xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST pszSOSNamespaceUri, BAD_CAST pszSOSNamespacePrefix));
     xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/om/1.0", BAD_CAST "om"));
     xmlNewNsProp(psRootNode, psNsGml, BAD_CAST "id", BAD_CAST sosparams->pszOffering);
@@ -2579,6 +2572,7 @@
   xmlXPathContextPtr context;
   xmlNodeSetPtr nodeset;
   xmlXPathObjectPtr psXPathTmp;
+  char *pszTmp = NULL;
   if (request->NumParams) { /* this is a GET request */
     for(i=0; i<request->NumParams; i++) {
@@ -2637,7 +2631,10 @@
     /* register namespaces */
-    if(xmlXPathRegisterNs(context, (xmlChar *)"sos", (xmlChar *)"http://www.opengis.net/sos/1.0") != 0 || xmlXPathRegisterNs(context, (xmlChar *)"ows", (xmlChar *)"http://www.opengis.net/ows/1.1") != 0) {
+    if(xmlXPathRegisterNs(context, (xmlChar *)"sos", (xmlChar *)"http://www.opengis.net/sos/1.0") != 0 ||
+       xmlXPathRegisterNs(context, (xmlChar *)"ows", (xmlChar *)"http://www.opengis.net/ows/1.1") != 0 ||
+       xmlXPathRegisterNs(context, (xmlChar *)"ogc", (xmlChar *)"http://www.opengis.net/ogc") != 0 ||
+       xmlXPathRegisterNs(context, (xmlChar *)"gml", (xmlChar *)"http://www.opengis.net/gml") != 0) {
       msSetError(MS_SOSERR, "Could not register namespaces (xmlXPathRegisterNs)", "msSOSParseRequest()");
       return msSOSException(map, "request", "NoApplicableCode");
@@ -2780,6 +2777,39 @@
     xmlXPathFreeObject(psXPathTmp);
+    /* check for result (chunk of XML) */
+    psXPathTmp = msLibXml2GetXPath(doc, context, (xmlChar *)"/sos:GetObservation/sos:result/child::*");
+    if (psXPathTmp) {
+      sosparams->pszResult = strdup(msLibXml2GetXPathTree(doc, psXPathTmp));
+      pszTmp = msStringConcatenate(pszTmp, "<ogc:Filter>");
+      pszTmp = msStringConcatenate(pszTmp, sosparams->pszResult);
+      pszTmp = msStringConcatenate(pszTmp, "</ogc:Filter>");
+      msFree(sosparams->pszResult);
+      sosparams->pszResult = strdup(pszTmp);
+      msFree(pszTmp);
+    xmlXPathFreeObject(psXPathTmp);
+    /* check for featureOfInterest (chunk of XML) */
+    psXPathTmp = msLibXml2GetXPath(doc, context, (xmlChar *)"/sos:GetObservation/sos:featureOfInterest/ogc:BBOX/gml:Envelope");
+    if (psXPathTmp) {
+      sosparams->pszFeatureOfInterest = (char *)msLibXml2GetXPathTree(doc, psXPathTmp);
+    /* check for eventTime (chunk of XML) */
+    psXPathTmp = msLibXml2GetXPath(doc, context, (xmlChar *)"/sos:GetObservation/sos:eventTime/ogc:TM_Equals/gml:TimeInstant|/sos:GetObservation/sos:eventTime/ogc:TM_Equals/gml:TimePeriod");
+    if (psXPathTmp) {
+      sosparams->pszEventTime = (char *)msLibXml2GetXPathTree(doc, psXPathTmp);
     xmlXPathFreeContext(context);
     xmlFreeDoc(doc);
     xmlCleanupParser();
