[mapserver-commits] r7759 - trunk/mapserver/mapscript/php3
svn at osgeo.org
svn at osgeo.org
Fri Jun 27 11:54:40 EDT 2008
Author: jmckenna
Date: 2008-06-27 11:54:39 -0400 (Fri, 27 Jun 2008)
New Revision: 7759
trunk/mapserver/mapscript/php3/nmake.opt
set default to a php5 build
Modified: trunk/mapserver/mapscript/php3/nmake.opt
--- trunk/mapserver/mapscript/php3/nmake.opt 2008-06-27 07:28:15 UTC (rev 7758)
+++ trunk/mapserver/mapscript/php3/nmake.opt 2008-06-27 15:54:39 UTC (rev 7759)
@@ -16,20 +16,20 @@
#Use PHP4 flag when building with PHP4. Default is assumed to be PHP5
-PHP4=1
+#PHP4=1
#name of the file that will be used when doing make install
-#it will be copied in the directory specified by the
+#it will be copied in the directory specified by the
PHP_INSTALL_DLL_NAME = php_mapscript_48.dll
!IFDEF PHP4
# Install directory for PHP4
-PHP_INSTALL_DIR=c:\php\php4\extensions
+PHP_INSTALL_DIR=c:\php\php4\extensions
# PHP TS library for PHP4
PHP_TS_LIB_NAME=php4ts.lib
!ELSE
# Install directory for PHP5
-#PHP_INSTALL_DIR=c:\php\php5\ext
+#PHP_INSTALL_DIR=c:\php\php5\ext
# PHP TS library for PHP5
-#PHP_TS_LIB_NAME=php5ts.lib
+PHP_TS_LIB_NAME=php5ts.lib
!ENDIF
More information about the mapserver-commits
