[mapserver-commits] r7760 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jun 27 17:49:58 EDT 2008
Author: pramsey
Date: 2008-06-27 17:49:58 -0400 (Fri, 27 Jun 2008)
New Revision: 7760
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapraster.c
Fix for tiled rasters with relative shape paths defined, from dfurhy (#2369)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-27 15:54:39 UTC (rev 7759)
+++ trunk/mapserver/HISTORY.TXT 2008-06-27 21:49:58 UTC (rev 7760)
@@ -13,7 +13,10 @@
- maputil.c: fix a bug for offset lines with agg, when the first segment
was horizontal (#2659)
+- mapraster.c: fix for tiled rasters with relative shape paths defined,
+ from dfurhy (#2369)
Version 5.2.0-beta3 (2008-06-26):
Modified: trunk/mapserver/mapraster.c
--- trunk/mapserver/mapraster.c 2008-06-27 15:54:39 UTC (rev 7759)
+++ trunk/mapserver/mapraster.c 2008-06-27 21:49:58 UTC (rev 7760)
@@ -1414,10 +1414,10 @@
** If using a tileindex then build the path relative to that file if SHAPEPATH is not set.
- if(layer->tileindex) {
+ if(layer->tileindex && !map->shapepath) {
msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex); /* absolute path to tileindex file */
tiAbsDirPath = msGetPath(tiAbsFilePath); /* tileindex file's directory */
- msBuildPath3(szPath, tiAbsDirPath, map->shapepath, filename);
+ msBuildPath(szPath, tiAbsDirPath, filename);
free(tiAbsDirPath);
} else {
msBuildPath3(szPath, map->mappath, map->shapepath, filename);
More information about the mapserver-commits
