[mapserver-commits] r7478 - trunk/mapserver
Mon Mar 24 17:48:30 EDT 2008
Author: Assefa
Date: 2008-03-24 17:48:30 -0400 (Mon, 24 Mar 2008)
New Revision: 7478
   trunk/mapserver/mapows.h
   trunk/mapserver/mapwfs.c
   trunk/mapserver/mapwfs11.c
wfs1.1 getcapabilities and describefeaturetype support
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2008-03-24 18:39:11 UTC (rev 7477)
+++ trunk/mapserver/mapows.h	2008-03-24 21:48:30 UTC (rev 7478)
@@ -382,7 +382,8 @@
 wfsParamsObj *msWFSCreateParamsObj(void);
 void msWFSFreeParamsObj(wfsParamsObj *wfsparams);
 int msWFSIsLayerSupported(layerObj *lp);
-int msWFSException(mapObj *map, const char *locator, const char *code);
+int msWFSException(mapObj *map, const char *locator, const char *code,
+                   const char *version);
 #ifdef USE_WFS_SVR
 const char *msWFSGetGeomElementName(mapObj *map, layerObj *lp);
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2008-03-24 18:39:11 UTC (rev 7477)
+++ trunk/mapserver/mapwfs.c	2008-03-24 21:48:30 UTC (rev 7478)
@@ -43,11 +43,19 @@
 ** Report current MapServer error in XML exception format.
+                   const char *version )
     char *schemalocation = NULL;
     /* In WFS, exceptions are always XML.
+    if( version == NULL )
+      version = "1.0.0";
+    if( msOWSParseVersionString(version) >= OWS_1_1_0 )
+      return msWFSException11( map, code, locator, version );
     msIO_printf("Content-type: text/xml%c%c",10,10);
     msOWSPrintEncodeMetadata(stdout, &(map->web.metadata), "FO", "encoding", OWS_NOERR,
                 "<?xml version='1.0' encoding=\"%s\" ?>\n", "ISO-8859-1");
@@ -288,12 +296,23 @@
   char *script_url=NULL, *script_url_encoded;
   const char *updatesequence=NULL;
   const char *wmtver=NULL;
+  char tmpString[OWS_VERSION_MAXLEN];
+  int wfsSupportedVersions[] = {OWS_1_1_0, OWS_1_0_0};
+  int wfsNumSupportedVersions = 2;
-  int i=0;
+  int i=0, tmpInt=0;
-  //TODO Add version negociation. Default version to be switched to 1.1.0 when complete
+  /* negotiate version */
+  tmpInt = msOWSNegotiateVersion(msOWSParseVersionString(wfsparams->pszVersion), wfsSupportedVersions,
+                                 wfsNumSupportedVersions);
-  if( strncmp(wfsparams->pszVersion,"1.1",3) == 0 )
+  /* set result as string and carry on */
+  if (wfsparams->pszVersion)
+    msFree(wfsparams->pszVersion);
+  wfsparams->pszVersion = strdup(msOWSGetVersionString(tmpInt, tmpString));
+  if( wfsparams->pszVersion == NULL ||  strncmp(wfsparams->pszVersion,"1.1",3) == 0 )
     return msWFSGetCapabilities11( map, wfsparams, req );
   /* Decide which version we're going to return... only 1.0.0 for now */
@@ -304,7 +323,7 @@
       (script_url_encoded = msEncodeHTMLEntities(script_url)) == NULL)
       msSetError(MS_WFSERR, "Server URL not found", "msWFSGetCapabilities()");
-      return msWFSException(map, "mapserv", "NoApplicableCode");
+      return msWFSException(map, "mapserv", "NoApplicableCode", wmtver);
   updatesequence = msOWSLookupMetadata(&(map->web.metadata), "FO", "updatesequence");
@@ -316,11 +335,11 @@
       i = msOWSNegotiateUpdateSequence(wfsparams->pszUpdateSequence, updatesequence);
       if (i == 0) { // current
           msSetError(MS_WFSERR, "UPDATESEQUENCE parameter (%s) is equal to server (%s)", "msWFSGetCapabilities()", wfsparams->pszUpdateSequence, updatesequence);
-          return msWFSException(map, "updatesequence", "CurrentUpdateSequence");
+          return msWFSException(map, "updatesequence", "CurrentUpdateSequence", wmtver);
       if (i > 0) { // invalid
           msSetError(MS_WFSERR, "UPDATESEQUENCE parameter (%s) is higher than server (%s)", "msWFSGetCapabilities()", wfsparams->pszUpdateSequence, updatesequence);
-          return msWFSException(map, "updatesequence", "InvalidUpdateSequence");
+          return msWFSException(map, "updatesequence", "InvalidUpdateSequence", wmtver);
@@ -698,14 +717,20 @@
+  /*set the output format to gml3 for wfs1.1*/
+  if(paramsObj->pszVersion == NULL || strncmp(paramsObj->pszVersion,"1.1",3) == 0 )
+    outputformat = OWS_SFE_SCHEMA;
   if (paramsObj->pszOutputFormat) {
-    if(strcasecmp(paramsObj->pszOutputFormat, "XMLSCHEMA") == 0)
+    if(strcasecmp(paramsObj->pszOutputFormat, "XMLSCHEMA") == 0 ||
+       strstr(paramsObj->pszOutputFormat, "gml/2")!= NULL)
       outputformat = OWS_DEFAULT_SCHEMA;
-    else if(strcasecmp(paramsObj->pszOutputFormat, "SFE_XMLSCHEMA") == 0)
+    else if(strcasecmp(paramsObj->pszOutputFormat, "SFE_XMLSCHEMA") == 0 ||
+            strstr(paramsObj->pszOutputFormat, "gml/3")!= NULL)
     else {
       msSetError(MS_WFSERR, "Unsupported DescribeFeatureType outputFormat (%s).", "msWFSDescribeFeatureType()", paramsObj->pszOutputFormat);
-      return msWFSException(map, "outputformat", "InvalidParameterValue");
+      return msWFSException(map, "outputformat", "InvalidParameterValue", paramsObj->pszVersion);
@@ -714,7 +739,7 @@
     for (i=0; i<numlayers; i++) {
       if (msGetLayerIndex(map, layers[i]) < 0) {
 	      msSetError(MS_WFSERR, "Invalid typename (%s).", "msWFSDescribeFeatureType()", layers[i]);/* paramsObj->pszTypeName); */
-        return msWFSException(map, "typename", "InvalidParameterValue");
+              return msWFSException(map, "typename", "InvalidParameterValue", paramsObj->pszVersion);
@@ -766,8 +791,10 @@
   encoded = msEncodeHTMLEntities( msOWSGetSchemasLocation(map) );
   if(outputformat == OWS_SFE_SCHEMA) /* reference GML 3.1.1 schema */
+    //msIO_printf("\n  <import namespace=\"http://www.opengis.net/gml\"\n"
+    //	"          schemaLocation=\"%s/gml/3.1.1/base/feature.xsd\" />\n", encoded);
-		"          schemaLocation=\"%s/gml/3.1.1/base/feature.xsd\" />\n", encoded);
+		"          schemaLocation=\"%s/gml/3.1.1/base/gml.xsd\" />\n", encoded);
   else /* default GML 2.1.x schema */
 	      "          schemaLocation=\"%s/gml/2.1.2/feature.xsd\" />\n", encoded);
@@ -984,7 +1011,7 @@
                  "Incomplete WFS request: TYPENAME parameter missing",
                  "msWFSGetFeature()");
-      return msWFSException(map, "typename", "MissingParameterValue");
+      return msWFSException(map, "typename", "MissingParameterValue", paramsObj->pszVersion);
@@ -1010,7 +1037,7 @@
     if (layers==NULL || numlayers < 1) {
       msSetError(MS_WFSERR, "At least one type name required in TYPENAME parameter.", "msWFSGetFeature()");
     tokens = msStringSplit(layers[0], ':', &n);
@@ -1070,7 +1097,7 @@
 		       "Server config error: SRS must be set at least at the map or at the layer level.",
+	    return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
 	  /* Keep track of output SRS.  If different from value */
@@ -1083,7 +1110,7 @@
 		       "Invalid GetFeature Request: All TYPENAMES in a single GetFeature request must have been advertized in the same SRS.  Please check the capabilities and reformulate your request.",
@@ -1096,7 +1123,7 @@
 		   "TYPENAME '%s' doesn't exist in this server.  Please check the capabilities and reformulate your request.",
 		   "msWFSGetFeature()", layers[k]);
@@ -1144,7 +1171,7 @@
     tokens = msStringSplit(paramsObj->pszBbox, ',', &n);
     if (tokens==NULL || n != 4) {
       msSetError(MS_WFSERR, "Wrong number of arguments for BBOX.", "msWFSGetFeature()");
-      return msWFSException(map, "bbox", "InvalidParameterValue");
+      return msWFSException(map, "bbox", "InvalidParameterValue", paramsObj->pszVersion);
     bbox.minx = atof(tokens[0]);
     bbox.miny = atof(tokens[1]);
@@ -1179,21 +1206,21 @@
                    "Required TYPENAME parameter missing for GetFeature with a FILTER parameter.",
       if (bBBOXSet) {
                    "BBOX parameter and FILTER parameter are mutually exclusive in GetFeature.",
       if (bFeatureIdSet) {
                    "FEATUREID parameter and FILTER parameter are mutually exclusive in GetFeature.",
@@ -1213,7 +1240,7 @@
 	if (tokens == NULL || nFilters <=0 || nFilters != numlayers) {
 	  msSetError(MS_WFSERR, "Wrong number of FILTER attributes",
-	  return msWFSException(map, "filter", "InvalidParameterValue");
+	  return msWFSException(map, "filter", "InvalidParameterValue", paramsObj->pszVersion);
 	paszFilter = (char **)malloc(sizeof(char *)*nFilters);
@@ -1237,7 +1264,7 @@
 	iLayerIndex = msGetLayerIndex(map, layers[i]);
 	if (iLayerIndex < 0) {
 	  msSetError(MS_WFSERR, "Invalid Typename in GetFeature : %s", "msWFSGetFeature()", layers[i]);
 	psNode = FLTParseFilterEncoding(paszFilter[i]);
@@ -1245,12 +1272,12 @@
 		     "Invalid or Unsupported FILTER in GetFeature : %s",
 		     "msWFSGetFeature()", pszFilter);
 	if( FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE) != MS_SUCCESS ) {
           msSetError(MS_WFSERR, "FLTApplyFilterToLayer() failed", "msWFSGetFeature()", pszFilter);
         FLTFreeFilterEncodingNode( psNode );
@@ -1317,7 +1344,7 @@
                        msFreeCharArray(tokens, nTokens);
                      if (tokens1)
                        msFreeCharArray(tokens1, nTokens1);
-                     return msWFSException(map, "featureid", "InvalidParameterValue");
+                     return msWFSException(map, "featureid", "InvalidParameterValue", paramsObj->pszVersion);
                  if (tokens1)
@@ -1344,7 +1371,7 @@
                      if( FLTApplyFilterToLayer(psNode, map, lp->index, MS_FALSE) != MS_SUCCESS ) {
                        msSetError(MS_WFSERR, "FLTApplyFilterToLayer() failed", "msWFSGetFeature");
-                       return msWFSException(map, "mapserv", "InvalidMapfile");
+                       return msWFSException(map, "mapserv", "InvalidMapfile", paramsObj->pszVersion);
@@ -1368,7 +1395,7 @@
                      msFree(aFIDLayers);
                      msFree(aFIDValues);
@@ -1396,7 +1423,7 @@
       if (msLoadProjectionString(&(map->projection), szBuf) != 0) {
         msSetError(MS_WFSERR, "msLoadProjectionString() failed", "msWFSGetFeature()");
@@ -1412,7 +1439,7 @@
 	if(ms_error->code != MS_NOTFOUND) {
           msSetError(MS_WFSERR, "ms_error->code not found", "msWFSGetFeature()");
@@ -1424,7 +1451,7 @@
     if ((script_url=msOWSGetOnlineResource(map,"FO","onlineresource",req)) ==NULL ||
         (script_url_encoded = msEncodeHTMLEntities(script_url)) == NULL) {
       msSetError(MS_WFSERR, "Server URL not found", "msWFSGetFeature()");
@@ -1602,7 +1629,7 @@
                  "Incomplete WFS request: VERSION parameter missing",
                  "msWFSDispatch()");
-      returnvalue = msWFSException(map, "version", "MissingParameterValue");
+      returnvalue = msWFSException11(map, "version", "MissingParameterValue", "1.1.0");
       msWFSFreeParamsObj(paramsObj);
       free(paramsObj);
       paramsObj = NULL;
@@ -1614,7 +1641,7 @@
                  "Incomplete WFS request: REQUEST parameter missing",
                  "msWFSDispatch()");
-      returnvalue = msWFSException(map, "request", "MissingParameterValue");
+      returnvalue = msWFSException(map, "request", "MissingParameterValue", paramsObj->pszVersion);
       free(paramsObj);
       paramsObj = NULL;
@@ -1627,7 +1654,7 @@
                  "Incomplete WFS request: SERVICE parameter missing",
                  "msWFSDispatch()");
-      returnvalue = msWFSException(map, "service", "MissingParameterValue");
+      returnvalue = msWFSException(map, "service", "MissingParameterValue", paramsObj->pszVersion);
       free(paramsObj);
       paramsObj = NULL;
@@ -1637,7 +1664,7 @@
   if ((status = msOWSMakeAllLayersUnique(map)) != MS_SUCCESS)
       msSetError(MS_WFSERR, "msOWSMakeAllLayersUnique() failed", "msWFSDispatch()");
-      returnvalue = msWFSException(map, "mapserv", "NoApplicableCode");
+      returnvalue = msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
       free(paramsObj);
       paramsObj = NULL;
@@ -1659,12 +1686,13 @@
   ** Validate VERSION against the versions that we support... we don't do this
   ** for GetCapabilities in order to allow version negociation.
-  if (strcmp(paramsObj->pszVersion, "1.0.0") != 0)
+  if (strcmp(paramsObj->pszVersion, "1.0.0") != 0 &&
+      strcmp(paramsObj->pszVersion, "1.1.0") != 0)
                  "WFS Server does not support VERSION %s.",
                  "msWFSDispatch()", paramsObj->pszVersion);
-      returnvalue = msWFSException(map, "version", "InvalidParameterValue");
+      returnvalue = msWFSException11(map, "version", "InvalidParameterValue","1.1.0");
       free(paramsObj);
       paramsObj = NULL;
@@ -1689,14 +1717,14 @@
       /* Unsupported WFS request */
       msSetError(MS_WFSERR, "Unsupported WFS request: %s", "msWFSDispatch()",
                  paramsObj->pszRequest);
-      returnvalue = msWFSException(map, "request", "InvalidParameterValue");
+      returnvalue = msWFSException(map, "request", "InvalidParameterValue", paramsObj->pszVersion);
   else if (strcasecmp(paramsObj->pszService, "WFS") == 0)
       /* Invalid WFS request */
       msSetError(MS_WFSERR, "Invalid WFS request: %s", "msWFSDispatch()",
   /* This was not detected as a WFS request... let MapServer handle it */
@@ -1810,11 +1838,11 @@
         /* version is optional is the GetCapabilities. If not */
-        /* provided, set it. */
+        /* provided, set it. Default it to 1.1.0*/
         if (wfsparams->pszVersion == NULL &&
             wfsparams->pszRequest &&
             strcasecmp(wfsparams->pszRequest, "GetCapabilities") == 0)
-          wfsparams->pszVersion = strdup("1.0.0");
+          wfsparams->pszVersion = strdup("1.1.0");
 /*      Parse the post request. It is assumed to be an XML document.    */
Modified: trunk/mapserver/mapwfs11.c
--- trunk/mapserver/mapwfs11.c	2008-03-24 18:39:11 UTC (rev 7477)
+++ trunk/mapserver/mapwfs11.c	2008-03-24 21:48:30 UTC (rev 7478)
@@ -27,14 +27,15 @@
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
-#include "mapogcfilter.h"
-#include "mapowscommon.h"
+#include "mapserver.h"
 #include "mapows.h"
-#include "maplibxml2.h"
 MS_CVSID("$Id: $")
 #if defined(USE_WFS_SVR) && defined(USE_LIBXML2)
+#include "maplibxml2.h"
+#include "mapowscommon.h"
+#include "mapogcfilter.h"
 int msWFSException11(mapObj *map, const char *locator,
@@ -49,7 +50,12 @@
     xmlNodePtr psRootNode = NULL;
     xmlNsPtr   psNsOws    = NULL;
     xmlChar *buffer       = NULL;
+    if (version == NULL)
+       version = "1.1.0";
     psNsOws = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/ows/1.1", BAD_CAST "ows");
     errorString = msGetErrorString("\n");
@@ -322,7 +328,7 @@
      /*output format*/
       xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psOwsNs,
        "Parameter", "outputFormat",
-        "text/gml; subtype=gml/3.1.1"));
+        "XMLSCHEMA,text/xml; subtype=gml/2.1.2,text/gml; subtype=gml/3.1.1"));
 /*      GetFeatureType                                                  */
