[mapserver-commits] r7479 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Mar 24 21:01:02 EDT 2008
Author: tomkralidis
Date: 2008-03-24 21:01:02 -0400 (Mon, 24 Mar 2008)
New Revision: 7479
trunk/mapserver/mapwfs11.c
change wfs:Keywords to ows:Keywords and add wfs:MetadataURL support (#2547)
Modified: trunk/mapserver/mapwfs11.c
--- trunk/mapserver/mapwfs11.c 2008-03-24 21:48:30 UTC (rev 7478)
+++ trunk/mapserver/mapwfs11.c 2008-03-25 01:01:02 UTC (rev 7479)
@@ -96,7 +96,7 @@
rectObj ext;
- xmlNodePtr psRootNode, psNode, psSubNode;
+ xmlNodePtr psRootNode, psNode;
const char *value = NULL;
psRootNode = xmlNewNode(NULL, BAD_CAST "FeatureType");
@@ -121,26 +121,13 @@
psNode = xmlNewChild(psRootNode, NULL, BAD_CAST "Abstract", BAD_CAST value);
- value = msOWSLookupMetadata(&(lp->metadata), "O", "keywordlist");
+ value = msOWSLookupMetadata(&(lp->metadata), "FO", "keywordlist");
- if (value)
- char **tokens = NULL;
- int n = 0;
- int i = 0;
+ if (value)
+ msLibXml2GenerateList(
+ xmlNewChild(psRootNode, psOwsNs, BAD_CAST "Keywords", NULL),
+ NULL, "Keyword", value, ',' );
- psNode = xmlNewChild(psRootNode, NULL, BAD_CAST "Keywords", NULL);
- tokens = msStringSplit(value, ',', &n);
- if (tokens && n > 0)
- for (i=0; i<n; i++)
- psSubNode = xmlNewChild(psNode, NULL, BAD_CAST "Keyword", BAD_CAST tokens[i]);
- msFreeCharArray(tokens, n);
/*srs only supposrt DefaultSRS with the same logic as for wfs1.0
TODO support OtherSRS*/
value = msOWSGetEPSGProj(&(map->projection),&(map->web.metadata),"FO",MS_TRUE);
@@ -179,13 +166,30 @@
xmlNewChild(psRootNode, psOwsNs, BAD_CAST "WGS84BoundingBox", NULL);
xmlAddSibling(psNode,
xmlNewComment(BAD_CAST "WARNING: Mandatory WGS84BoundingBox could not be established for this layer. Consider setting LAYER.EXTENT or wfs_extent metadata."));
+ value = msOWSLookupMetadata(&(lp->metadata), "FO", "metadataurl_href");
+ if (value)
+ psNode = xmlNewChild(psRootNode, NULL, BAD_CAST "MetadataURL", BAD_CAST value);
+ value = msOWSLookupMetadata(&(lp->metadata), "FO", "metadataurl_format");
+ if (!value)
+ value = strdup("text/html"); // default
+ xmlNewProp(psNode, BAD_CAST "format", BAD_CAST value);
+ value = msOWSLookupMetadata(&(lp->metadata), "FO", "metadataurl_type");
+ if (!value)
+ value = strdup("FGDC"); // default
+ xmlNewProp(psNode, BAD_CAST "type", BAD_CAST value);
return psRootNode;
More information about the mapserver-commits
