[mapserver-commits] r7565 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed May 7 00:08:16 EDT 2008
Author: pramsey
Date: 2008-05-07 00:08:16 -0400 (Wed, 07 May 2008)
New Revision: 7565
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapshape.c
Don't ignore .qix file when DATA reference includes .shp extension (#590)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-05-07 04:03:45 UTC (rev 7564)
+++ trunk/mapserver/HISTORY.TXT 2008-05-07 04:08:16 UTC (rev 7565)
@@ -13,6 +13,8 @@
Current Version (5.1-dev, SVN trunk):
+- Don't ignore .qix file when DATA reference includes .shp extension (#590)
- CGI able to alter layers with space and underscores (#2516)
- WFS Multipoint query with PostGIS bug fixed (#2443)
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c 2008-05-07 04:03:45 UTC (rev 7564)
+++ trunk/mapserver/mapshape.c 2008-05-07 04:08:16 UTC (rev 7565)
@@ -1718,7 +1718,9 @@
int i;
rectObj shaperect;
char *filename;
+ char *sourcename = 0; /* shape file source string from map file */
+ char *s = 0; /* pointer to start of '.shp' in source string */
if(shpfile->status) {
free(shpfile->status);
shpfile->status = NULL;
@@ -1736,17 +1738,27 @@
msSetError(MS_MEMERR, NULL, "msShapefileWhichShapes()");
return(MS_FAILURE);
- for(i=0;i<shpfile->numshapes;i++)
+ for(i=0;i<shpfile->numshapes;i++) {
msSetBit(shpfile->status, i, 1);
- } else {
- if((filename = (char *)malloc(strlen(shpfile->source)+strlen(MS_INDEX_EXTENSION)+1)) == NULL) {
+ else {
+ /* deal with case where sourcename is of the form 'file.shp' */
+ sourcename = strdup(shpfile->source);
+ s = strcasestr(sourcename, ".shp");
+ if( s ) *s = '\0';
+ if((filename = (char *)malloc(strlen(sourcename)+strlen(MS_INDEX_EXTENSION)+1)) == NULL) {
return(MS_FAILURE);
- sprintf(filename, "%s%s", shpfile->source, MS_INDEX_EXTENSION);
+ sprintf(filename, "%s%s", sourcename, MS_INDEX_EXTENSION);
shpfile->status = msSearchDiskTree(filename, rect, debug);
free(filename);
+ free(sourcename);
if(shpfile->status) { /* index */
msFilterTreeSearch(shpfile, shpfile->status, rect);
More information about the mapserver-commits
