[mapserver-commits] r8030 - trunk/docs/howto
Fri Nov 21 11:32:17 EST 2008
Author: hobu
Date: 2008-11-21 11:32:17 -0500 (Fri, 21 Nov 2008)
New Revision: 8030
Added:
   trunk/docs/howto/map.vim
add Andreas' VIM syntax file to svn.  Probably needs quite a bit of updating
Added: trunk/docs/howto/map.vim
--- trunk/docs/howto/map.vim	                        (rev 0)
+++ trunk/docs/howto/map.vim	2008-11-21 16:32:17 UTC (rev 8030)
@@ -0,0 +1,99 @@
+" Vim syntax file
+" Language:     map (umn mapserver config file)
+" Maintainer:   Andreas Hirner <andreas.hirner at dlr.de>
+" Last Change:  $Date: 2004/05/25 19:19:37 $
+" Filenames:    *.map
+" Note:         The definitions below are taken from TextPad syntax definitions (*.syn) by Chris Thorne (thorne at dmsolutions.ca) as of May 2004, for version 4.0 Mapserver
+" For version 5.x: Clear all syntax items
+" For version 6.x: Quit when a syntax file was already loaded
+if version < 600
+  syntax clear
+elseif exists("b:current_syntax")
+  finish
+endif
+" Always ignore case
+syn case ignore
+" General keywords first order
+syn keyword mapDefine       CLASS END JOIN LABEL LAYER LEGEND MAP METADATA OUTPUTFORMAT
+syn keyword mapDefine       PROJECTION QUERYMAP REFERENCE SCALEBAR STYLE SYMBOL WEB
+" General keywords second order
+syn keyword mapIdentifier   ALPHACOLOR ANGLE ANTIALIAS
+syn keyword mapIdentifier   BACKGROUNDCOLOR BACKGROUNDSHADOWCOLOR BACKGROUNDSHADOWSIZE BUFFER
+syn keyword mapIdentifier   CHARACTER CLASSITEM COLOR CONNECTION CONNECTIONTYPE
+syn keyword mapIdentifier   DATA DATAPATTERN DEBUG DRIVER DUMP
+syn keyword mapIdentifier   EMPTY ERROR EXPRESSION EXTENSION EXTENT
+syn keyword mapIdentifier   FEATURE FILLED FILTER FILTERITEM FONT FONTSET FOOTER FORCE FORMATOPTION FROM
+syn keyword mapIdentifier   GAP GRATICULE GRID GROUP HEADER
+syn keyword mapIdentifier   IMAGE IMAGECOLOR IMAGEMODE IMAGEPATH IMAGEQUALITY IMAGETYPE IMAGEURL INDEX INTERLACE INTERVALS
+syn keyword mapIdentifier   KEYIMAGE KEYSIZE KEYSPACING
+syn keyword mapIdentifier   LABELANGLEITEM LABELCACHE LABELFORMAT LABELITEM LABELMAXSCALE LABELMINSCALE LABELREQUIRES LABELSIZEITEM LATLON LINECAP LINEJOIN LINEJOINMAXSIZE LOG
+syn keyword mapIdentifier   MARKER MARKERSIZE MAXARCS MAXBOXSIZE MAXFEATURES MAXINTERVAL MAXSCALE MAXSIZE MAXSUBDIVIDE MAXTEMPLATE MIMETYPE
+syn keyword mapIdentifier   MINARCS MINBOXSIZE MINDISTANCE MINFEATURESIZE MININTERVAL MINSCALE MINSIZE MINSUBDIVIDE MINTEMPLATE
+syn keyword mapIdentifier   NAME
+syn keyword mapIdentifier   OFFSET OFFSITE OUTLINECOLOR OVERLAYBACKGROUNDCOLOR OVERLAYCOLOR OVERLAYMAXSIZE OVERLAYMINSIZE OVERLAYOUTLINECOLOR OVERLAYSIZE OVERLAYSYMBOL
+syn keyword mapIdentifier   PARTIALS POINTS POSITION POSTLABELCACHE PROCESSING
+syn keyword mapIdentifier   REQUIRES RESOLUTION
+syn keyword mapIdentifier   SCALE SHADOWCOLOR SHADOWSIZE SHAPEPATH SIZE SIZEUNITS STATUS STYLEITEM SYMBOLSCALE SYMBOLSET
+syn keyword mapIdentifier   TABLE TEMPLATE TEMPLATEPATTERN TEXT TILEINDEX TILEITEM TITLE TO TOLERANCE TOLERANCEUNITS TRANSFORM TRANSPARENCY TRANSPAREN[T] TYPE
+syn keyword mapIdentifier   UNITS WMS_ABSTRACT WMS_ACCESSCONSTRAINTS WMS_ONLINERESOURCE WMS_SRS WMS_TITLE WRAP
+" General keywords third order
+syn keyword mapKeyword      ANNOTATION AUTO BEVEL BITMAP BUTT
+syn keyword mapKeyword      CARTOLINE CC CIRCLE CL CR CSV DD DEFAULT
+syn keyword mapKeyword      ELLIPSE EMBED FALSE FEET GIANT HILITE INCHES
+syn keyword mapKeyword      KILOMETERS LARGE LC LINE LL LR
+syn keyword mapKeyword      MEDIUM METERS MILES MITER MULTIPLE MYGIS NORMAL
+syn keyword mapKeyword      OFF OGR ON ONE-TO-MANY ONE-TO-ONE ORACLESPATIAL
+syn keyword mapKeyword      PIXELS PIXMAP POINT POLYGON POSTGIS QUERY RASTER ROUND
+syn keyword mapKeyword      SDE SELECTED SIMPLE SINGLE SMALL SQUARE
+syn keyword mapKeyword      TINY TRIANGLE TRUE TRUETYPE UC UL UR VECTOR WFS WMS
+" keywords for other purposes
+syn keyword mapTypedef      SELECTION
+" Comment
+syn match mapComment      "#.*"
+" Strings (single- and double-quote)
+syn region mapString       start=+"+  skip=+\\\\\|\\"+  end=+"+
+syn region mapString       start=+'+  skip=+\\\\\|\\'+  end=+'+
+" Numbers and hexidecimal values
+syn match mapNumber         "-\=\<[0-9]*\>"
+syn match mapNumber         "\<0x[abcdefABCDEF0-9]*\>"
+" Operators
+syn match mapOperator      "EQ"
+syn match mapOperator      "[><|\=&!$/\\()\[\]]"
+" Define the default highlighting.
+" For version 5.7 and earlier: only when not done already
+" For version 5.8 and later: only when an item doesn't have highlighting yet
+if version >= 508 || !exists("did_map_syn_inits")
+  if version < 508
+    let did_map_syn_inits = 1
+    command -nargs=+ HiLink hi link <args>
+  else
+    command -nargs=+ HiLink hi def link <args>
+  endif
+  HiLink mapComment      Comment
+  HiLink mapKeyword      Keyword
+  HiLink mapIdentifier   Identifier
+  HiLink mapDefine      Define
+  HiLink mapTypedef      Typedef
+  HiLink mapNumber      Number
+  HiLink mapString      String
+  HiLink mapOperator   Operator
+  delcommand HiLink
+endif
+let b:current_syntax = "map"
+" vim: ts=8
