[mapserver-commits] r8031 - trunk/docs/howto
Fri Nov 21 11:34:30 EST 2008
Author: hobu
Date: 2008-11-21 11:34:30 -0500 (Fri, 21 Nov 2008)
New Revision: 8031
Added:
   trunk/docs/howto/map_fold.vim
add Schuyler's VIM folding stuff to svn
Added: trunk/docs/howto/map_fold.vim
--- trunk/docs/howto/map_fold.vim	                        (rev 0)
+++ trunk/docs/howto/map_fold.vim	2008-11-21 16:34:30 UTC (rev 8031)
@@ -0,0 +1,54 @@
+" Vim folding mode for UMN MapServer .map files
+" Author:	Schuyler Erle <schuyler at nocat.net>
+" Last Change:	2006 May 04
+" Version:	1.0
+" Based on an indent folding mode by Jorrit Wiersma and Max Ischenko
+" To use, copy to your ~/.vim directory and then add the following
+" to your .vimrc:
+" autocmd BufRead *.map source ~/.vim/map_fold.vim
+setlocal foldmethod=expr
+setlocal foldexpr=GetMapFileFold(v:lnum)
+setlocal foldtext=MapFileFoldText()
+highlight Folded term=bold ctermfg=white ctermbg=black
+function! GetMapFileFold(lnum)
+    " If it's a group statement, fold one level
+    let line = getline(a:lnum)
+    if line =~ '\c^\s*\(CLASS\|JOIN\|LABEL\|LAYER\|LEGEND\|METADATA\|OUTPUTFORMAT\|PROJECTION\|QUERYMAP\|REFERENCE\|SCALEBAR\|STYLE\|SYMBOL\|WEB\)\s*\(#.*\)*$'
+	return "a1"
+    endif
+    " if it's an END, unfold one level
+    if line =~ '\c^\s*END\s*\(#.*\)*$'
+	return "s1"
+    endif
+    " otherwise...
+    return "="
+endfunction
+function! MapFileFoldText()
+  let line = getline(v:foldstart)
+  let line3 = substitute(line, '\t', '        ', 'g')
+  let line2 = substitute(line3, '^\( *\)', '&+ ', '')
+  let i = v:foldstart
+  let name = ""
+  while i < v:foldend
+    let iline = getline(i)
+    if iline =~ '\c^\s*\(NAME\|EXPRESSION\)\s\s*'
+      let name = substitute(iline, '\c\s*\(NAME\|EXPRESSION\)\s*', '', '')
+      break
+    endif
+    let i = i + 1
+  endwhile
+  if name != ""
+    let line2 = line2 . " " . name
+  endif
+  return line2 . " "
+endfunction
