[mapserver-commits] r8063 - in trunk/docs: howto
references/templatereference
svn at osgeo.org
svn at osgeo.org
Sun Nov 23 18:29:54 EST 2008
Author: hobu
Date: 2008-11-23 18:29:54 -0500 (Sun, 23 Nov 2008)
New Revision: 8063
trunk/docs/howto/fastcgi.txt
trunk/docs/howto/pdf-output.txt
trunk/docs/references/templatereference/templatereference.txt
more titling
Modified: trunk/docs/howto/fastcgi.txt
--- trunk/docs/howto/fastcgi.txt 2008-11-23 20:19:10 UTC (rev 8062)
+++ trunk/docs/howto/fastcgi.txt 2008-11-23 23:29:54 UTC (rev 8063)
@@ -1,40 +1,19 @@
-.. $Id$
+ FastCGI
- RULE #1: No tabs in this document!
- RULE #2: Indent is 4 characters.
- RULE #3: There is no rule 3.
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Author: Howard Butler
+:Contact: hobu.inc at gmail.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2008/07/15
- Thank you.
- reStructured Text is part of the Python docutils module
- http://docutils.sourceforge.net/
- Documentation on reStructured Text is found at
+.. sectnum::
- http://docutils.sourceforge.net/rst.html
- First reST note is about comments: a double period begins a comment
- block (like a /* in C) and a double period on a line all by itself
- closes the comment block.
-.. Below is our main heading (becomes H1). Note that we require empty
- lines between every different reST element such as the empty line
- between the end of this comment and the begining of the heading.
-:Release: 4.4.2
-:Last Updated: $Date$
-:Author: Frank Warmerdam and Howard Butler
-:Contact: hobu at iastate.edu
.. contents:: Table of Contents
- :depth: 3
+ :depth: 2
:backlinks: top
Modified: trunk/docs/howto/pdf-output.txt
--- trunk/docs/howto/pdf-output.txt 2008-11-23 20:19:10 UTC (rev 8062)
+++ trunk/docs/howto/pdf-output.txt 2008-11-23 23:29:54 UTC (rev 8063)
@@ -1,14 +1,13 @@
+ PDF Output
:Author: Yewondwossen Assefa
-:Contact: yassefa(at)dmsolutions.ca
+:Contact: yassefa at dmsolutions.ca
+:Date: $Date$
:Last Updated: 2006/01/12
-.. The next heading encountered becomes our H2
.. sectnum::
Modified: trunk/docs/references/templatereference/templatereference.txt
--- trunk/docs/references/templatereference/templatereference.txt 2008-11-23 20:19:10 UTC (rev 8062)
+++ trunk/docs/references/templatereference/templatereference.txt 2008-11-23 23:29:54 UTC (rev 8063)
@@ -1,16 +1,15 @@
+ Templating
:Author: Frank Koormann
-:Contact: frank.koormann(at)intevation.de
+:Contact: frank.koormann at intevation.de
:Author: Jeff McKenna
-:Contact: jmckenna(at)gatewaygeomatics.com
+:Contact: jmckenna at gatewaygeomatics.com
+:Date: $Date$
:Last Updated: 2008/07/18
.. sectnum::
More information about the mapserver-commits
