[mapserver-commits] r8066 - trunk/docs/references/compilation
svn at osgeo.org
svn at osgeo.org
Sun Nov 23 19:07:53 EST 2008
Author: hobu
Date: 2008-11-23 19:07:53 -0500 (Sun, 23 Nov 2008)
New Revision: 8066
trunk/docs/references/compilation/unix.txt
oops
Modified: trunk/docs/references/compilation/unix.txt
--- trunk/docs/references/compilation/unix.txt 2008-11-24 00:04:37 UTC (rev 8065)
+++ trunk/docs/references/compilation/unix.txt 2008-11-24 00:07:53 UTC (rev 8066)
@@ -93,7 +93,11 @@
different vector formats.
* `GDAL <http://www.gdal.org/>`__: GDAL provides access to at least
42 different raster formats.
+* `AGG <http://antigrain.com>`__: AGG (Anti-Grain Geometry) is an optional
+ dependency to enable high quality antialiased output for vector data.
+ Currently versions 2.4 and 2.5 are identical featurewise, and only vary in
+ their licence (2.4 is BSD, 2.5 is GPL)
Optional External Libraries
@@ -259,6 +263,14 @@
libgd and TrueType support to be able to use this feature.
+Anti-Grain Geometry Support
+Since version 5.0 MapServer supports the AGG rendering backend.
+Download the 2.4 tarball from the antigrain website and just type make in
+the root directory. If you intend on using mapscript, you must beforehand
+tweak the agg makefile to add -fPIC to the compiler options.
OGC Support
MapServer provides support for many `OGC <http://www.opengeospatial.org>`__
@@ -379,9 +391,11 @@
database. In effect, PostGIS "spatially enables" the PostgreSQL server,
allowing it to be used as a backend spatial database for geographic
information systems (GIS), much like ESRI's SDE or Oracle's Spatial extension.
+PostGIS is included in many distributions' packaging system, but you can also
+roll your own if needed.
-MapServer can use PostGIS as a data source. In order to do so simply
-use "--with-postgis" when running your configure script.
+MapServer can use PostGIS as a data source. In order to do so simply use
+"--with-postgis" when running your configure script.
@@ -415,27 +429,6 @@
--with-oraclespatial=/opt/oracle
- MyGIS
-*NOTE* This driver has not been actively maintained since the 4.0 release
-of MapServer and is possibly broken. An excellent way to use MySQL data
-with MapServer is the utilize the MySQL spatial (and non-spatial through VRT)
-support available in OGR. More details about this method can be found in
-`this document </docs/howto/ogrmysql>`__.
-MapServer supports data from a non-spatially enabled
-`MySQL <http://www.mysql.com/>`__ server. Both 3.x and 4.x versions of MySQL
-should work. In order to connect to it, you need to compile MapServer
-against the MySQL libraries by passing the "--with-mygis" argument to
-your configure script. It is unknown as of 5.0 whether or not this
-driver still works.
- --with-mygis=/usr/local/bin/my_config
Compiling
@@ -455,7 +448,7 @@
2. Compile GDAL/OGR. Describing how to compile GDAL/OGR is beyond the scope
of this document. If you have requirements for lots of different formats,
make sure to install those libraries first. I often find that building
- up a GDAL/OGR library often takes as long as compiling MapServer itself!
+ up a GDAL/OGR library often takes as long as compiling MapServer itself!
3. Compile Proj.4. Proj.4 is a straight-forward configure/make/make install
library.
@@ -463,14 +456,15 @@
4. Compile libcurl. libcurl is a straight-forward configure/make/make install
library.
-5. Compile/install optional libraries. These might include SDE, PostGIS,
- Oracle Spatial, Ming, PDFlib, or MyGIS. Mix and match as you need them.
+5. Compile/install optional libraries. These might include SDE, PostGIS,
+ Oracle Spatial, AGG, Ming, PDFlib, or MyGIS. Mix and match as you need
+ them.
6. Unpack the MapServer tarball and cd into the mapserver directory:
- [user at host user]$ tar -zxvf mapserver-4.2.3.tar.gz
+ [user at host user]$ tar -zxvf mapserver-X.Y.Z.tar.gz
7. Configure your environment using "configure". I often place my configure
command in its own file and changes its mode to be executable (+x) to save
@@ -501,6 +495,7 @@
--with-libiconv=/usr \ # new in 4.8
--with-xml2-config=/usr/bin/xml2-config \ # new in 4.10
--with-sos \ # new in 4.10
+ --with-agg=/path/to/agg-2.4
8. Now that you have configured your build options and selected all the
@@ -600,4 +595,4 @@
with MapServer.
.. _`new users`: /new_users
-.. _`post to mapserver-users`: http://article.gmane.org/gmane.comp.gis.mapserver.user/17766
\ No newline at end of file
+.. _`post to mapserver-users`: http://article.gmane.org/gmane.comp.gis.mapserver.user/17766
More information about the mapserver-commits
