[mapserver-commits] r8071 - trunk/docs/references/mapfile
    svn at osgeo.org
    svn at osgeo.org
    Sun Nov 23 20:09:45 EST 2008
Author: hobu
Date: 2008-11-23 20:09:45 -0500 (Sun, 23 Nov 2008)
New Revision: 8071
Added:
   trunk/docs/references/mapfile/map.txt
Removed:
   trunk/docs/references/mapfile/mapObj.txt
rename
Copied: trunk/docs/references/mapfile/map.txt (from rev 8070, trunk/docs/references/mapfile/mapObj.txt)
--- trunk/docs/references/mapfile/map.txt	                        (rev 0)
+++ trunk/docs/references/mapfile/map.txt	2008-11-24 01:09:45 UTC (rev 8071)
@@ -0,0 +1,307 @@
+.. _map:
+ MAP
+ANGLE [double]
+   Angle, given in degrees, to rotate the map. Default is 0. The rendered
+   map will rotate in a clockwise direction. The following are important notes:
+   - Requires a :ref:`PROJECTION` object specified at the MAP level and for each
+     :ref:`LAYER` object (even if all layers are in the same projection).
+   - Requires MapScript (SWIG, PHPMapscript). Does not work with CGI mode.
+   - If using the :ref:`LABEL` object's ANGLE or the :ref:`LAYER` object's LABELANGLEITEM
+     parameters as well, these parameters are relative to the map's orientation
+     (i.e. they are computed after the MAP object's ANGLE). For example, if you
+     have specified an ANGLE for the map of 45, and then have a layer
+     LABELANGLEITEM value of 45, the resulting label will not appear rotated
+     (because the resulting map is rotated clockwise 45 degrees and the label
+     is rotated counter-clockwise 45 degrees).
+   - More information can be found on the MapRotation `Wiki Page`_.
+.. _`Wiki Page`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapRotation
+CONFIG [key] [value]
+    This can be used to specify several values at run-time, for both MapServer and GDAL/OGR
+    libraries.  Developers: values will be passed on to CPLSetConfigOption().  Details on
+    GDAL/OGR options are found in their associated driver documentation pages
+    (`GDAL`_/`OGR`_).  The following
+    options are available specifically for MapServer:
+    .. _`GDAL`: http://www.gdal.org/formats_list.html
+    .. _`OGR`: http://www.gdal.org/ogr/ogr_formats.html
+    CGI_CONTEXT_URL [value]
+       The CONFIG parameter can be used to enable loading a map context from a URL.  See the
+       `Map Context howto`_ for more info.
+       .. _`Map Context howto`: /docs/howto/mapcontext
+    MS_ENCRYPTION_KEY [filename]
+       The CONFIG parameter can be used to specify an encryption key that is used with
+       MapServer's `msencypt utility`_.
+       .. _`msencypt utility`: /docs/reference/utilityreference/msencrypt
+    MS_ERRORFILE [filename]
+       The CONFIG parameter can be used to write MapServer errors to a file (as of MapServer
+       5.0).  For more on this see the DEBUG parameter below.
+    MS_NONSQUARE [yes|no]
+       The CONFIG parameter can be used to allow non-square WMS requests.
+    MS_PROJ_LIB [path]
+       The CONFIG parameter can be used to define the location of your EPSG files.  For more
+       info see the 'PROJ_LIB' parameter below.
+    ON_MISSING_DATA [FAIL|LOG|IGNORE]
+       The CONFIG parameter can be used to tell MapServer how to handle missing data in tile
+       indexes (as of MapServer 5.3-dev, r8015). Previous MapServer versions required a
+       compile-time switch ("IGNORE_MISSING_DATA"), but this is no longer required.
+       FAIL
+           This will cause MapServer to throw an error and exit (to crash, in other words) on
+           a missing file in a tile index.  This is the default.
+             CONFIG "ON_MISSING_DATA" "FAIL"
+       LOG
+           This will cause MapServer to log the error message for a missing file in a tile
+           index, and continue with the map creation.  Note: DEBUG parameter and CONFIG
+           "MS_ERRORFILE" need to be set for logging to occur, so please see the DEBUG
+           parameter below for more information.
+             CONFIG "ON_MISSING_DATA" "LOG"
+       IGNORE
+           This will cause MapServer to not report or log any errors for missing files, and
+           map creation will occur normally.
+             CONFIG "ON_MISSING_DATA" "IGNORE"
+    PROJ_LIB [path]
+        The CONFIG parameter can be used to define the location of your EPSG files for the
+        PROJ.4 library. Setting the [key] to PROJ_LIB and the [value] to the location of
+        your EPSG files will force PROJ.4 to use this value. Using CONFIG allows
+        you to avoid setting environment variables to point to your PROJ_LIB
+        directory. Here are some examples:
+        1. Unix
+             CONFIG "PROJ_LIB" "/usr/local/share/proj/"
+        2. Windows
+             CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
+.. _DATAPATTERN:
+DATAPATTERN [regular expression]
+    This defines a regular expression to be applied to requests to change DATA
+    parameters via URL requests (i.e. map_layername_data=...). If a pattern
+    doesn't exist then web users can't monkey with support files via URLs.
+    This allows you to isolate one application from another if you desire,
+    with the default operation being very conservative. See also
+    TEMPLATEPATTERN_.
+DEBUG [off|on|0|1|2|3|4|5]
+    Enables debugging of all of the layers in the current map.
+    *Debugging with MapServer versions >= 5.0:*
+    Verbose output is generated and sent to the standard error output (STDERR)
+    or the MapServer errorfile if one is set using the "MS_ERRORFILE" environment
+    variable.  You can set the environment variable by using the CONFIG parameter
+    at the MAP level of the mapfile, such as:
+      CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
+    You can also set the environment variable in Apache by adding the following
+    to your httpd.conf:
+      SetEnv MS_ERRORFILE "/ms4w/tmp/ms_error.txt"
+    Once the environment variable is set, the DEBUG mapfile parameter can be
+    used to control the level of debugging output.  Here is a description of the
+    possible DEBUG values:
+      DEBUG O or OFF - only msSetError() calls are logged to MS_ERRORFILE. No
+                       msDebug() output at all. This is the default and
+                       corresponds to the original behavior of MS_ERRORFILE in
+                       MapServer 4.x
+      DEBUG 1 or ON  - includes all output from DEBUG 0 plus msDebug() warnings
+                       about common pitfalls, failed assertions or non-fatal
+                       error situations (e.g. missing or invalid values for some
+                       parameters, missing shapefiles in tileindex, timeout
+                       error from remote WMS/WFS servers, etc.)
+      DEBUG 2        - includes all output from DEBUG 1 plus notices and timing
+                       information useful for tuning mapfiles and applications
+      DEBUG 3        - all of DEBUG 2 plus some debug output useful in
+                       troubleshooting problems such as WMS connection URLs
+                       being called, database connection calls, etc.  This is
+                       the recommended level for debugging mapfiles.
+      DEBUG 4        - DEBUG 3 plus even more details...
+      DEBUG 5        - DEBUG 4 plus any msDebug() output that might be more
+                       useful to the developers than to the users.
+    You can also set the debug level by using the "MS_DEBUGLEVEL" environment
+    variable.
+    The DEBUG setting can also be specified for a layer, by setting the DEBUG
+    parameter in the `LAYER`_ object.
+    For more details on this debugging mechanism, please see `RFC 28`_.
+    .. _`RFC 28`: /development/rfc/ms-rfc-28
+    *Debugging with MapServer versions < 5:*
+    or the MapServer logfile if one is set using the LOG parameter in the WEB
+    object.  Apache users will see timing details for drawing in Apache's
+    error_log file.  Requires MapServer to be built with the DEBUG=MSDEBUG
+    option (--with-debug configure option).
+EXTENT [minx] [miny] [maxx] [maxy]
+    The spatial extent of the map to be created. In most cases you will need
+    to specify this, although mapserver can sometimes (expensively)
+    calculate one if it is not specified.
+FONTSET [filename]
+    Filename of fontset file to use.  Can be a path relative to the mapfile, or a full path.
+IMAGECOLOR [r] [g] [b]
+    Color to initialize the map with (i.e. background color). When
+    transparency is enabled (TRANSPARENT ON) for the typical case of 8-bit
+    pseudocolored map generation, this color will be marked as transparent
+    in the output file palette. Any other map components drawn in this color
+    will also be transparenct, so for map generation with transparency it is
+    best to use an otherwise unused color as the background color.
+IMAGEQUALITY [int]
+    *Deprecated* Use FORMATOPTION "QUALITY=n" in the OUTPUTFORMAT declaration
+    to specify compression quality for JPEG output.
+IMAGETYPE [gif|png|jpeg|wbmp|gtiff|swf|userdefined]
+    Output format to generate. See details in the `OUTPUTFORMAT`_ section for
+    available formats. The name here must match the 'NAME' of a user defined
+    or internally generated OUTPUTFORMAT section.
+.. _`OUTPUTFORMAT`: /docs/reference/mapfile/outputformat
+INTERLACE [on|off]
+    *Deprecated* Use FORMATOPTION "INTERLACE=ON" in the `OUTPUTFORMAT`_
+    declaration to specify if the output images should be interlaced.
+LAYER
+    Signals the start of a `LAYER`_ object.
+.. _`LAYER`: /docs/reference/mapfile/layer
+LEGEND
+    Signals the start of a `LEGEND`_ object.
+.. _`LEGEND`: /docs/reference/mapfile/legend
+MAXSIZE [integer]
+    Sets the maximum size of the map image. This will override the default value. For example, setting this to 2048 means that you can have up to 2048 pixels in both dimensions (i.e. max of 2048x2048).
+NAME [name]
+    Prefix attached to map, scalebar and legend GIF filenames created using
+    this MapFile. It should be kept short.
+PROJECTION
+    Signals the start of a `PROJECTION`_ object.
+.. _`PROJECTION`: /docs/reference/mapfile/projection
+QUERYMAP
+    Signals the start of a `QUERYMAP`_ object.
+.. _`QUERYMAP`: /docs/reference/mapfile/querymap
+REFERENCE
+    Signals the start of a `REFERENCE MAP`_ object.
+.. _`REFERENCE MAP`: /docs/reference/mapfile/reference
+RESOLUTION [int]
+    Sets the pixels per inch for output, only affects scale computations
+    and nothing else, default is 72.
+SCALEDENOM [double]
+    Computed scale of the map. Set most often by the application.  Scale is
+    given as the denominator of the actual scale fraction, for example for a map
+    at a scale of 1:24,000 use 24000.  Implemented in MapServer 5.0, to replace
+    the deprecated SCALE parameter.
+SCALE [double] - deprecated
+    Since MapServer 5.0 the proper parameter to use is SCALEDENOM
+    instead.  The deprecated SCALE is the computed scale of the map. Set most
+    often by the application.  Scale is given as the denominator of the actual
+    scale fraction, for example for a map at a scale of 1:24,000 use 24000.
+SCALEBAR
+    Signals the start of a `SCALEBAR`_ object.
+.. _`SCALEBAR`: /docs/reference/mapfile/scalebar
+SHAPEPATH [filename]
+    Path to the directory holding the shapefiles or tiles. There can be
+    further subdirectories under SHAPEPATH.
+SIZE [x][y]
+    Size in pixels of the output image (i.e. the map).
+STATUS [on|off]
+    Is the map active? Sometimes you may wish to turn this off to use only the
+    reference map or scale bar.
+SYMBOLSET [filename]
+    Filename of the symbolset to use.  Can be a path relative to the mapfile, or a full path.
+SYMBOL
+    Signals the start of a `SYMBOL`_ object.
+.. _TEMPLATEPATTERN:
+TEMPLATEPATTERN [regular expression]
+    TEMPLATE parameters via URL requests (i.e. map_layername_template=...). If
+    a pattern doesn't exist then web users can't monkey with support files via
+    URLs. This allows you to isolate one application from another if you
+    desire, with the default operation being very conservative. See also
+    DATAPATTERN_.
+TRANSPARENT [on|off]
+    *Deprecated* Use FORMATOPTION "TRANSPARENT=ON" in the OUTPUTFORMAT
+    declaration to specify if the output images should be transparent.
+UNITS [feet|inches|kilometers|meters|miles|dd]
+    Units of the map coordinates. Used for scalebar and scale computations.
+WEB
+    Signals the start of a `WEB`_ object.
\ No newline at end of file
Deleted: trunk/docs/references/mapfile/mapObj.txt
--- trunk/docs/references/mapfile/mapObj.txt	2008-11-24 01:08:16 UTC (rev 8070)
+++ trunk/docs/references/mapfile/mapObj.txt	2008-11-24 01:09:45 UTC (rev 8071)
@@ -1,307 +0,0 @@
-.. _map:
- MAP
-ANGLE [double]
-   Angle, given in degrees, to rotate the map. Default is 0. The rendered
-   map will rotate in a clockwise direction. The following are important notes:
-   - Requires a :ref:`PROJECTION` object specified at the MAP level and for each
-     :ref:`LAYER` object (even if all layers are in the same projection).
-   - Requires MapScript (SWIG, PHPMapscript). Does not work with CGI mode.
-   - If using the :ref:`LABEL` object's ANGLE or the :ref:`LAYER` object's LABELANGLEITEM
-     parameters as well, these parameters are relative to the map's orientation
-     (i.e. they are computed after the MAP object's ANGLE). For example, if you
-     have specified an ANGLE for the map of 45, and then have a layer
-     LABELANGLEITEM value of 45, the resulting label will not appear rotated
-     (because the resulting map is rotated clockwise 45 degrees and the label
-     is rotated counter-clockwise 45 degrees).
-   - More information can be found on the MapRotation `Wiki Page`_.
-.. _`Wiki Page`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapRotation
-CONFIG [key] [value]
-    This can be used to specify several values at run-time, for both MapServer and GDAL/OGR
-    libraries.  Developers: values will be passed on to CPLSetConfigOption().  Details on
-    GDAL/OGR options are found in their associated driver documentation pages
-    (`GDAL`_/`OGR`_).  The following
-    options are available specifically for MapServer:
-    .. _`GDAL`: http://www.gdal.org/formats_list.html
-    .. _`OGR`: http://www.gdal.org/ogr/ogr_formats.html
-    CGI_CONTEXT_URL [value]
-       The CONFIG parameter can be used to enable loading a map context from a URL.  See the
-       `Map Context howto`_ for more info.
-       .. _`Map Context howto`: /docs/howto/mapcontext
-    MS_ENCRYPTION_KEY [filename]
-       The CONFIG parameter can be used to specify an encryption key that is used with
-       MapServer's `msencypt utility`_.
-       .. _`msencypt utility`: /docs/reference/utilityreference/msencrypt
-    MS_ERRORFILE [filename]
-       The CONFIG parameter can be used to write MapServer errors to a file (as of MapServer
-       5.0).  For more on this see the DEBUG parameter below.
-    MS_NONSQUARE [yes|no]
-       The CONFIG parameter can be used to allow non-square WMS requests.
-    MS_PROJ_LIB [path]
-       The CONFIG parameter can be used to define the location of your EPSG files.  For more
-       info see the 'PROJ_LIB' parameter below.
-    ON_MISSING_DATA [FAIL|LOG|IGNORE]
-       The CONFIG parameter can be used to tell MapServer how to handle missing data in tile
-       indexes (as of MapServer 5.3-dev, r8015). Previous MapServer versions required a
-       compile-time switch ("IGNORE_MISSING_DATA"), but this is no longer required.
-       FAIL
-           This will cause MapServer to throw an error and exit (to crash, in other words) on
-           a missing file in a tile index.  This is the default.
-             CONFIG "ON_MISSING_DATA" "FAIL"
-       LOG
-           This will cause MapServer to log the error message for a missing file in a tile
-           index, and continue with the map creation.  Note: DEBUG parameter and CONFIG
-           "MS_ERRORFILE" need to be set for logging to occur, so please see the DEBUG
-           parameter below for more information.
-             CONFIG "ON_MISSING_DATA" "LOG"
-       IGNORE
-           This will cause MapServer to not report or log any errors for missing files, and
-           map creation will occur normally.
-             CONFIG "ON_MISSING_DATA" "IGNORE"
-    PROJ_LIB [path]
-        The CONFIG parameter can be used to define the location of your EPSG files for the
-        PROJ.4 library. Setting the [key] to PROJ_LIB and the [value] to the location of
-        your EPSG files will force PROJ.4 to use this value. Using CONFIG allows
-        you to avoid setting environment variables to point to your PROJ_LIB
-        directory. Here are some examples:
-        1. Unix
-             CONFIG "PROJ_LIB" "/usr/local/share/proj/"
-        2. Windows
-             CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
-.. _DATAPATTERN:
-DATAPATTERN [regular expression]
-    This defines a regular expression to be applied to requests to change DATA
-    parameters via URL requests (i.e. map_layername_data=...). If a pattern
-    doesn't exist then web users can't monkey with support files via URLs.
-    This allows you to isolate one application from another if you desire,
-    with the default operation being very conservative. See also
-    TEMPLATEPATTERN_.
-DEBUG [off|on|0|1|2|3|4|5]
-    Enables debugging of all of the layers in the current map.
-    *Debugging with MapServer versions >= 5.0:*
-    Verbose output is generated and sent to the standard error output (STDERR)
-    or the MapServer errorfile if one is set using the "MS_ERRORFILE" environment
-    variable.  You can set the environment variable by using the CONFIG parameter
-    at the MAP level of the mapfile, such as:
-      CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
-    You can also set the environment variable in Apache by adding the following
-    to your httpd.conf:
-      SetEnv MS_ERRORFILE "/ms4w/tmp/ms_error.txt"
-    Once the environment variable is set, the DEBUG mapfile parameter can be
-    used to control the level of debugging output.  Here is a description of the
-    possible DEBUG values:
-      DEBUG O or OFF - only msSetError() calls are logged to MS_ERRORFILE. No
-                       msDebug() output at all. This is the default and
-                       corresponds to the original behavior of MS_ERRORFILE in
-                       MapServer 4.x
-      DEBUG 1 or ON  - includes all output from DEBUG 0 plus msDebug() warnings
-                       about common pitfalls, failed assertions or non-fatal
-                       error situations (e.g. missing or invalid values for some
-                       parameters, missing shapefiles in tileindex, timeout
-                       error from remote WMS/WFS servers, etc.)
-      DEBUG 2        - includes all output from DEBUG 1 plus notices and timing
-                       information useful for tuning mapfiles and applications
-      DEBUG 3        - all of DEBUG 2 plus some debug output useful in
-                       troubleshooting problems such as WMS connection URLs
-                       being called, database connection calls, etc.  This is
-                       the recommended level for debugging mapfiles.
-      DEBUG 4        - DEBUG 3 plus even more details...
-      DEBUG 5        - DEBUG 4 plus any msDebug() output that might be more
-                       useful to the developers than to the users.
-    You can also set the debug level by using the "MS_DEBUGLEVEL" environment
-    variable.
-    The DEBUG setting can also be specified for a layer, by setting the DEBUG
-    parameter in the `LAYER`_ object.
-    For more details on this debugging mechanism, please see `RFC 28`_.
-    .. _`RFC 28`: /development/rfc/ms-rfc-28
-    *Debugging with MapServer versions < 5:*
-    or the MapServer logfile if one is set using the LOG parameter in the WEB
-    object.  Apache users will see timing details for drawing in Apache's
-    error_log file.  Requires MapServer to be built with the DEBUG=MSDEBUG
-    option (--with-debug configure option).
-EXTENT [minx] [miny] [maxx] [maxy]
-    The spatial extent of the map to be created. In most cases you will need
-    to specify this, although mapserver can sometimes (expensively)
-    calculate one if it is not specified.
-FONTSET [filename]
-    Filename of fontset file to use.  Can be a path relative to the mapfile, or a full path.
-IMAGECOLOR [r] [g] [b]
-    Color to initialize the map with (i.e. background color). When
-    transparency is enabled (TRANSPARENT ON) for the typical case of 8-bit
-    pseudocolored map generation, this color will be marked as transparent
-    in the output file palette. Any other map components drawn in this color
-    will also be transparenct, so for map generation with transparency it is
-    best to use an otherwise unused color as the background color.
-IMAGEQUALITY [int]
-    *Deprecated* Use FORMATOPTION "QUALITY=n" in the OUTPUTFORMAT declaration
-    to specify compression quality for JPEG output.
-IMAGETYPE [gif|png|jpeg|wbmp|gtiff|swf|userdefined]
-    Output format to generate. See details in the `OUTPUTFORMAT`_ section for
-    available formats. The name here must match the 'NAME' of a user defined
-    or internally generated OUTPUTFORMAT section.
-.. _`OUTPUTFORMAT`: /docs/reference/mapfile/outputformat
-INTERLACE [on|off]
-    *Deprecated* Use FORMATOPTION "INTERLACE=ON" in the `OUTPUTFORMAT`_
-    declaration to specify if the output images should be interlaced.
-LAYER
-    Signals the start of a `LAYER`_ object.
-.. _`LAYER`: /docs/reference/mapfile/layer
-LEGEND
-    Signals the start of a `LEGEND`_ object.
-.. _`LEGEND`: /docs/reference/mapfile/legend
-MAXSIZE [integer]
-    Sets the maximum size of the map image. This will override the default value. For example, setting this to 2048 means that you can have up to 2048 pixels in both dimensions (i.e. max of 2048x2048).
-NAME [name]
-    Prefix attached to map, scalebar and legend GIF filenames created using
-    this MapFile. It should be kept short.
-PROJECTION
-    Signals the start of a `PROJECTION`_ object.
-.. _`PROJECTION`: /docs/reference/mapfile/projection
-QUERYMAP
-    Signals the start of a `QUERYMAP`_ object.
-.. _`QUERYMAP`: /docs/reference/mapfile/querymap
-REFERENCE
-    Signals the start of a `REFERENCE MAP`_ object.
-.. _`REFERENCE MAP`: /docs/reference/mapfile/reference
-RESOLUTION [int]
-    Sets the pixels per inch for output, only affects scale computations
-    and nothing else, default is 72.
-SCALEDENOM [double]
-    Computed scale of the map. Set most often by the application.  Scale is
-    given as the denominator of the actual scale fraction, for example for a map
-    at a scale of 1:24,000 use 24000.  Implemented in MapServer 5.0, to replace
-    the deprecated SCALE parameter.
-SCALE [double] - deprecated
-    Since MapServer 5.0 the proper parameter to use is SCALEDENOM
-    instead.  The deprecated SCALE is the computed scale of the map. Set most
-    often by the application.  Scale is given as the denominator of the actual
-    scale fraction, for example for a map at a scale of 1:24,000 use 24000.
-SCALEBAR
-    Signals the start of a `SCALEBAR`_ object.
-.. _`SCALEBAR`: /docs/reference/mapfile/scalebar
-SHAPEPATH [filename]
-    Path to the directory holding the shapefiles or tiles. There can be
-    further subdirectories under SHAPEPATH.
-SIZE [x][y]
-    Size in pixels of the output image (i.e. the map).
-STATUS [on|off]
-    Is the map active? Sometimes you may wish to turn this off to use only the
-    reference map or scale bar.
-SYMBOLSET [filename]
-    Filename of the symbolset to use.  Can be a path relative to the mapfile, or a full path.
-SYMBOL
-    Signals the start of a `SYMBOL`_ object.
-.. _TEMPLATEPATTERN:
-TEMPLATEPATTERN [regular expression]
-    TEMPLATE parameters via URL requests (i.e. map_layername_template=...). If
-    a pattern doesn't exist then web users can't monkey with support files via
-    URLs. This allows you to isolate one application from another if you
-    desire, with the default operation being very conservative. See also
-    DATAPATTERN_.
-TRANSPARENT [on|off]
-    *Deprecated* Use FORMATOPTION "TRANSPARENT=ON" in the OUTPUTFORMAT
-    declaration to specify if the output images should be transparent.
-UNITS [feet|inches|kilometers|meters|miles|dd]
-    Units of the map coordinates. Used for scalebar and scale computations.
-WEB
-    Signals the start of a `WEB`_ object.
More information about the mapserver-commits
